Question about LG VX8300 Cellular Phone
Lg 8300 Hello i have to lg 8300 one is the one i use and all scuffed up the other doesnt work can you take these phones apart and change the outer shell? Thank you
  • 77 Answers
I wouldn't recommend taking this phone apart as the side buttons never seem to go back together correctly thus creating more problems then before.
What you can try to do is go to an auto parts store and look for Meguars PLASTIX or any kind of automotive plastic polish and try to buff the scratches out. But if we're talking deep gouches then it may be best to just grin and bear it :)
Hope this helps.
Posted on May 08, 2008
SOURCE:
The "rubber covering" on my fridge wheels is scuffed off and the new wheels they sent me don't have the rubber covering. How do I replace this covering?
Hello Jim;
My name is Peter. I am a retired field service refrigeration technician.
Refrigerator manufacturers do not field test their designs before putting them on the market. They make their design changes based on customer complaints and field technicians doing repairs under warrantee.
Now, neither your front or rear wheels have a rubber covering. I am not surprised. A refrigerator is a lot of weight to move even on hard rubber wheels.
Current front wheels:
The rear casters are hard to install. They have a history of cracking and falling apart and are difficult to replace. LG has a history of high service calls.
Feb 01, 2015 | Samsung RF217ACRS Bottom Freezer French...
How can i replace an LCD Screen Display a verizon LG extravert VN271?
Here's a video showing you how to take the phone apart: How to take apart lg phone It's not very professional, but you can use it anyway. Here's a replacement outer screen: Original OEM Verizon LG Extravert VN271 Outer Glass Front Digitizer... Lastly, here is the inner screen: Verizon LG Extravert VN271 LCD Display Screen Replacement Part Parts... Good luck!
Jun 20, 2014 | LG Cell Phones
Ive got a LGVX8300 flip phone that the carrier was verision and now i want to get unlocking codes so that it will work with cricket
Hello, You may contact to your network provider LG VX 8300 Unlock Code, they will provide an accurate code with easy to follow instructions on how to unlock your phone. I suggest to visit LG Unlock Code site, they can open up all networks for you where you want to use your phone. Once your phone is unlock it will work with any networks worldwide without sticking to one network only.
Hope this is helpful.
Thanks.
Mar 02, 2011 | Cell Phones
LG 8300 phone the display screen is distorted / scrambled
The problem with your phone is that the flex on your phone screen is malfunctioning, that is why the screen is distorted.
All you will need to do is to change the flex on your phone screen because it is now faulty.
Change the flex of your phone screen as advice and you will see that your phone screen will be back to normal.
Take care.
May 03, 2010 | LG VX8300 Cellular Phone
How do i remove / edit the start up screens? also, how is possible to upgrade the rubbish os on the LG secret when the LG website and software doesnt seem to support it? This is such a good...
hello, the fact that a phone looks so wonderful doesnt make it impeccable to criticism, theres always a problem. about the on screen display, it cant be changed, only the display which is on the setting can be changed. it cant be upgraded.
Jan 31, 2010 | LG Secret ? KF750 Cellular Phone
How to repair broken hinge of my Verizon LG Vx8350
I was able to take apart a VX8350 I have with a broken screen. I don't see any way to replace just the hinges with replacing the whole top part of the phone including the screen. The ribbon cable from the screen runs through the hinge part into the main assembly of the phone. It appears the cable can't be removed without cutting it.
Jan 11, 2009 | LG VX8350 Cellular Phone
Vzw lg 8300
If the phone was reported lost then the serial number has be locked in Verizon's system, and it cannot be activated. There's nothnig you can do to change that. Only Verizon can unlock the ESN of the phone, and since you're not the original owner of the phone they most likely won't do it but just ask you to return the phone to them.
Apr 28, 2008 | LG VX8300 Cellular Phone
Khms155lss1
The handle can only be changed by separating the outer and inner shells of the door. You can pull the outer shell off the inner shell by removing the three screws at the end of the door and then using firm force to pull the shells apart. It helps to gently pry along the bottom, top and inside (nearest the hinges) with a thin flathead screwdriver or other very thin metal object. You don't have to get it all the way loose; just a little is fine. You can then use the two clasps on the back of the door (that hold it shut when it's closed) to pull with. I found that inserting a slim screwdriver into the lower clasp and using that as a handle (not a lever!) gives you a better grip. Hold the outer shell of the door with your left hand while pulling the inner shell in the opposite direction. Be carefull not to twist or bend the clasps; they are plastic and will break. The shells will pull apart and then you can access the screws that hold the handle. Change the handle then press the door shells back together. Make sure they are snug all around. Replace the three end screws and you're done.
Jan 08, 2008 | GE JVM1650 1000 Watts Microwave Oven
LG VX8300 Cellular Phone Logo
96 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
