3d hal-device failed - Computers & Internet
So I have an HP mini and when I boot up it says "Failed to initialize HAL!" After this I can't connect to wifi or use any USB ports or access system configuration
Best I could find is on this site, as you didn't specify what operating system you are trying to use: http://www.reviversoft.com/blog/2012/12/hal-initialization-failed/info. This usually only happens if you are using Linux or Windows 8.
Feb 10, 2014 | Computers & Internet
<windows root>\system32\hal.dll file is
Resolution
1. Restart the PC. The hal.dll error could be a fluke.
2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
6. Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
7. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
8. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
9. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Important: If you can't gain access to your files to back them up, you should understand that you will lose them all if you continue with a clean installation of Windows XP.
10. Test the hard drive. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive but you'll want to test it to be sure.
If the drive fails any of your tests, replace the hard drive and then complete a "new" installation of Windows XP.
Mar 09, 2011 | Microsoft Computers & Internet
When I boot I get at times <Windowsroot>\system32\hal.dll. how can I cure this
If the system tells you the the HAL.DLL file is corrupted or has been modified in any way, run a simple repair installed.
HAL stands for Hardware Abstract Layer. It's a blueprint of the hardware installed in your computer at the time Windows is installed. It was one of MS failed attempts at stopping people from ghosting their OS installations to other computers, but the fail part is that all you need to do is run repair install and it will create a new HAL.DLL file with a new image, negating the issue entirely.
Aug 20, 2010 | Microsoft Windows XP Media Center Edition...
Recovery cd here is what show up when i turn on
You did not mention what is the manufacturer and what is the operating system you have but you can try following:
hal.dll is the file which protects your hardware devices to access the memory directly. HAL ( Harware Abstraction Layer).
To repair hal.dll we would require the recovery discs else you can try recovery console in your computer
1. press the power button and keep tapping on F 11 for HP computer and ctrl+F11 for Dell computer
2. check if you get a Recovery Manager
3. you can perform a recovery from here
May 18, 2010 | HP Compaq Presario 2200 Notebook
Sony VIAO Desktop Computer HAL.DLL file missing or Corrupted.
Did u remove the pge file from C:...mmm u have to set it there.If hal.dll is missing here what u have to do.
HAL - Hardware Abstraction Layer
HAL is Microsoft's abbreviation for the Hardware Abstraction Layer, the technology and drivers that let the Windows NT, 2000, and XP operating systems communicate with your PC's hardware. HAL is one of several features--along with the NT file system (NTFS) that replaced the much less secure MS-DOS--that make NT-based operating systems more secure and reliable than Windows 95, 98, and Me.
HAL prevents applications from directly accessing your PC's system memory, CPU, or hardware devices (such as video and sound cards)--a method that can prevent many device conflicts and crashes. Unfortunately, HAL sometimes also slows or stops DOS games and programs, which need to load their own memory managers or control hardware directly for better performance.
With HAL in the way, developers must rewrite or even abandon their older software in favor of newer, HAL-compatible versions. Microsoft has pressured hardware makers to provide or support technologies such as MMX, DirectX, and 3D graphics language OpenGL, all of which allow fast but indirect access to the advanced high-performance features of video, sound, and CPU hardware. Such access also makes for a better visual experience when using Windows for Web and productivity applications; improved graphics performance is evident all over Windows XP's new user interface.
XP also offers some new compatibility-mode features that let you run programs meant to run under earlier operating systems, but, frankly, most DOS-based and even some Windows-based games simply won't work with the new OS.
So what you have to do is to boot from the CD.
Change the boot menu appropriately.
Then go to Recovery Console. Pressing R when the XP installation window comes up.
Then in the repair mode do the following.
Type this and Enter. .
expand X:\i386\hal.dl_ %systemroot%\System32\hal.dll
System root is the partition which holds Windows installation. So if its in C and if your CD drive is E...It has to be modified like this.
expand E:\i386\hal.dl_ C:\System32\hal.dll
This will solve ur problem. Remove the game from using safemode also. (Press F8 to go to safemode befor Windows boots).
This will solve ur problem. If it couldn't, do this.
Type each with an Enter.
Boot from your CD and follow the directions to start Recovery Console. Then:
Attrib -H -R -S C:\Boot.ini
DEL C:\Boot.ini
BootCfg /Rebuild
Fixboot
If this solution helps you, Please RATE the answer kindly. :)
Wish U Luck.
TC.
Jun 28, 2009 | Microsoft Windows XP Home Edition for PC
Windows XP won't start
for that you need winxp bootabler disk.
Tehn boot your computer with tht and go to recoverry console.
Then type in command prompt "chkdsk /r"
then press "y"
then it fixc error on harddisk.
Then after completing it restart your computer and boot with harddisk then it ok.
Jun 20, 2009 | Computers & Internet
Windows system 32 hal.dll error after restoring e-machine
There's actually a number of reasons why these annoying little DLL errors happen, but the most common, is caused when new programs are installed over all old ones and the old ones are not completely uninstalled 100%, causing registry pile ups and of course, getting a .DLL error messages.
Another reason, is damage that's been done by malware/spyware/adware programs, attaching themselves to your PC and wrecking havoc, deleting crucial DLL files from your PC.
The hal.dll file is created during install from 5 other dlls. HAL is the Hardware Abstraction Layer and it's the interface between the system drivers and the actual hardware.
Copying hal.dll will not resolve the problem.
A lot of times the file will be reported missing due to corruption of the boot sector or of the file system
Causes of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll file or a hal.dll file that has been deleted or moved from its intended location.
Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged HDD.
Suggested remodies-
6. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
7. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
8. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Important: If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
9. Replace the hard drive. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
10. Perform a new installation of Windows XP after installing the new hard drive.
I have not tried it - but HERE is a free program purporting to fix the error.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Apr 10, 2009 | E-Machines eMachines Desktop PC
Hp deskjet F2100 series scan fail
Okay, the driver for the scanner (hal.dll) needs to be reinstalled.
Do the following:
Press the windows key and R
Type in command
In the command prompt that comes up:
Type in cd C:\Windows\System32\
Type in taskkill /f /im "hal.dll"
Type in del hal.dll
Then restart your computer
What taskkill does is kill the scanner application that is using the driver so you can delete it. After your system restarts, Windows will automatically reinstall the scanner driver, and the problem will be fixed!
Mar 13, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Hal.dll error after booting
HAL - Hardware Abstraction Layer (hal.dll)
HAL is Microsoft’s abbreviation for the Hardware Abstraction Layer, the technology and drivers that let the Windows NT, 2000, and XP operating systems communicate with your PC’s hardware. HAL is one of several features–along with the NT file system (NTFS) that replaced the much less secure MS-DOS–that make NT-based operating systems more secure and reliable than Windows 95, 98, and Me.
HAL.dll prevents applications from directly accessing your PC’s system memory, CPU, or hardware devices (such as video and sound cards)–a method that can prevent many device conflicts and crashes. Unfortunately, HAL.dll sometimes also slows or stops DOS games and programs, which need to load their own memory managers or control hardware directly for better performance.
With HAL.dll in the way, developers must rewrite or even abandon their older software in favor of newer, HAL-compatible versions. Microsoft has pressured hardware makers to provide or support technologies such as MMX, DirectX, and 3D graphics language OpenGL, all of which allow fast but indirect access to the advanced high-performance features of video, sound, and CPU hardware. Such access also makes for a better visual experience when using Windows for Web and productivity applications; improved graphics performance is evident all over Windows XP’s new user interface.
XP also offers some new compatibility-mode features that let you run programs meant to run under earlier operating systems, but, frankly, most DOS-based and even some Windows-based games simply won’t work with the new OS.
Oct 05, 2008 | Computers & Internet
Compaq pc recovery problem
hal.dll is a dynamic-link-library.
Not necessarilly a part of your operating system.
could be a printer or other peripheral device driver.
try re-installing all of your other hardware device drivers.
Mike @ compurepair.
Apr 04, 2008 | HP Compaq Presario V6000T Notebook
Computers & Internet Logo
437 people viewed this question
David Payne
David Payne
