Question about Sony KP-43T70 43" Rear Projection Television
Green missing sony kp43t70 green lamp is on tv working, convergence ok
  • 160 Answers
Press the menu button, if the menu has green missing as well it's the tv. If you can't tell with the menu, use a second source, being a dvd or a gaming system. If the green is still missing make sure you use different cables, it will be the tv. if only one source is the issue it will be the source that is missing the green color.
Posted on May 06, 2010
I have a Sony KDF-E50A10 Grand WEGA LCD. The picture cuts in and out and the green standby light flashes. One expert said the STKs need to be replaced??? How can I do this...please advise in detail.
Replace your lamp. Your DLP set does not have Stk ic's in it. I don't know what expert told you that but I can assure you he has never worked on a TV. You can purchase the lamp from www.dlplamps.com
Jan 18, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
I NEED THREE LAMPS THE RED GREEN AND BLUE. MY TV COLORS ARE OFF
No you just need to install a convergence repair kit. Your model uses the Sony type 1 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions.
Jul 28, 2010 | Sony KP-51WS510 51" Rear Projection...
Installed new lamp ..tv turns on then shuts off standby light flashes for a few seconds then tv turns on then shuts off again
did you replace the all three lamp the red,green and blue lamp?if not what color of lamp did you replace?try to dis connect the lamp that you installed then power the tv again if it work there might be a problem on your compatibility of lamp u use..or you can replace the convergeance ic there are two big ic in there sometimes labelled STK replace them...hope this could help..good luck!!
May 21, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
I'm having a problem with the color green being distorted on my TV. Is this a color tube issue, bulb issue, lamp issue?
This is a picture tube type TV. No lamp.
You don't describe the distortion.
A colour green picture that is twisted and shifted away from the other colours is a convergence problem. see Projection TV Convergence on this site.
If the green is smeared, out of focus, larger than the other colours like a halo around objects, things like that, it is the green picture tube. Sony has discontinued most of the picture tubes so you may not be able to get this fixed.
Mar 31, 2010 | Sony KP-46WT520 46" Rear Projection...
Large blue blob in middle of screen on my 42" sony tv model # KDFE42A10
check to see if your green and red lamps are lighting. if they are not then go to your convergence board and check to see if you are getting the right voltages. the voltages are written on the circuit board on some tv's. i believe that you are having problems with your convergence.
Nov 10, 2009 | Sony KDF-E42A10 42 in. LCD Television
I've got 4 blinking lights on sony kp43t70 model
You got board problems....I have the same, so I turn on the tv with the diagnostic settings.....display, 5, vol+, then power on.....it will turn on and you'll have the diagnostic numbers in green on the screen. I have gotten use to them now, the m board needs work & it runs about 300...
Oct 16, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
TV will not come on
i have a sony rear projection TV, model number kp43t70 screen went black and there was still volume but no pic so I turned it off and now won't turn back on
Aug 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Converging green?
jaymz, you can`t move the green, the green tube is always mounted in the middle and is not adjustable from the convergence menu. red & blue should be converged one at a time on top of the green, once you have accomplished this the crosshatch grid will be white and that means your done :)
Nov 30, 2007 | Philips 43PP9202 43" Rear Projection...
Intermittent losing blue on SD-643HD5 Pioneer
check the convergence area for bad solder
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Nov 01, 2007 | Pioneer SD-643HD5 64" Rear Projection...
JVC MODEL # AV-48WP74 48 IN. BIGSCREEN TV.
I had a problem with my TV colors not lining up. One day I turned it on and the green was out of wack. I checked this message board and replaced the STK chips, bad soldering and all led to me just giving up on that and buying a whole new Convergence Board ($185). I just plugged this in and though now my Green lines up okay, my red is out of whack. Is there something I am doing wrong? Can anyone help me? Did i miss a step? Frustrated......Bruce
Jul 29, 2007 | JVC AV-48WP74 48" Rear Projection...
Sony KP-43T70 43" Rear Projection Television Logo
124 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
