Question about Saeco Nina Bar Espresso Machine
I don't have a manual for the Saeco Nina Bar Espresso, so I'm trying to figure out what it means by "...after switching ON immediately prime the water circuit."
    President:
  • 1,469 Answers
The manual if is somehow large for me to start giving you details.
You can follow this link to download the manual for your product.
When you enter into the site, scroll and select the particular product you are using.
coffeeitalia.co.uk/downl-manual.php
Take care.
Posted on May 05, 2010
How do u prime the pump for saeco talea giro plus expresso machine
Should be just a matter of switching the machine off, if it doesn't prime then switch off, leave a few minutes and try again *obviously making sure there's water in the tank....
Jul 16, 2014 | Saeco Talea Giro Espresso Machine
Hello The lights on the front of the machine wont stop flashing so I can't press the cup symbols to make coffee. The hot water is coming out though through the steamer spout. Thanks!
Circuit Priming
When the machine operates for the first time and when
all the water has been dispensed, the machine circuit
needs priming. In this case, the 4 buttons of the control
panel will flash at the same time.
• Press the ON/OFF button . The 4 buttons will
flash.
• Place a container under the cappuccinatore.
• Open the "hot water/steam" knob by turning
it anticlockwise.
• Press the hot water button.
• Wait for water dispensing to stop.
• Close the "hot water/steam" knob by turning it
clockwise. Remove the container.
When the first priming ends, the warming up
starts. Before brewing coffee, water and steam,
please wait for lights 15 and 16 to be permanently on.
The machine is now ready to brew coffee and dispense
steam. Please see related sections for operating details.
Note: if priming is not completed, the 4 buttons
will keep on fl ashing. The machine cannot be
used.
Jan 14, 2011 | Saeco Nina Bar Espresso Machine
Priming a new machine
Not sure what model you have, but here's a link to the Saeco web site where you can download your manual for free. If your's isn't listed, just use their contac info on the page to request a copy.
http://www.saeco-usa.com/en/home-page/home-page.html
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Saeco Vienna SuperAutomatica Coffee...
When brewwing the espresso it sprays out instead of flowing down. What's wrong?
this action can be come from limescale contamination in spout of coffee and the m/c to descalling
or if it done nearly it can come from air gab in pump internal so it must be to discharge this air out 1st and the stream of water it will begood!
thanks
Jul 12, 2009 | Saeco Nina Bar Espresso Machine
I have Saeco Royal Coffee Bar. Hot water and
Hi
You may have a flow meter that is bad. If its white plastic check for corrosion at the wire terminals. If your have corrosion change the meter and you should be good to go.
Apr 10, 2009 | Saeco Royal Coffee Bar Coffee Maker,...
I have a Saeco Incanto RS Espresso Machine. The prime light is on, but the machine won't prime. Very little water of steam comes out of the wand.
You need to manually prime it using the priming bulb that came with it. Instructions are in the manual. Remove water tank. Fill priming bulb. Hold priming bulb on water inlet. They don't inter-connect, so just hold it on there as best you can. Turn the machine on, turn steam knob on, and gently, slowly squeeze the bulb to force water into the machine. It works best when the machine is cold, because you want to get liquid water in there, and not have it displaced by steam.
Jun 30, 2008 | Saeco Incanto Classic Espresso Machine
Broken coffee maker
I don´t no realy what you mean, if you have the door open so will the machine be dead, there are a switch in the machine that power off when you open the door.
May 08, 2008 | Saeco Vienna De Luxe Espresso Machine
No instruction on how to prime a saeco caffe charisma machine. looked in the book that came with it but there is no instructions for this process
Prime = letting some water out from the water/steam nozzle. Priming means that the machine has not water in the lines. By letting water come out, you are making sure that water fills all the components and is ready to use.
Apr 28, 2008 | Saeco Caffe Charisma Espresso Machine
Water light blinking
ok you have a priming problem
press the warm water button and open the valve . Normally that should prime it.
Other wise you have in the box the primer tool of saeco.
Just press the button and push the water in after opening the knob. http://cerinicoffee.com/Saeco_User_manuals_free.asp
give you details.
Apr 07, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Magic De Luxe dregs light problem
Make sure that both the tray and dump box are placed correctly- otherwise the machine will not start. Both have a switch and when that switches are not engaged, the machine will not turn on.
Mar 09, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Nina Bar Espresso Machine Logo
75 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
