Question about Poulan PP4218AV 18" Chain Saw
I have a poulan pp4218avhd chain saw that won't sart. I have cleaned the spark arrestor & the air filter. I have replaced the spark plug with a correct gap and checked that it is getting a spark. I have also tried utilizing some starting fluid all to no avail.
  • dontbother10
    dontbother10 May 11, 2010
    Open the choke; pour a teaspoon of mix into the throat; reinstall the air filter; turn it on; leave the choke open; attempt to start it; and reply with the results. Have you inspected the plug to see if it is wet (flooded)?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
I have this saw and really like it. Does the the primer seem to work? Most problems on these saws can be traced back to cracked fuel lines. Either tank to primer, primer to carb, or carb return back to tank. I would recommend it the saw it more than 3 years old to replace all the fuel lines. Total cost about $5. Buy your fuel line at Ace Hardware.
Posted on May 06, 2010
Is there a replacement clutch cover for the Poulan PP4218AVX?
Hello Dave;
If a Poulan PP4218 your answer follows; if not post back with the correct model number and we can replace that too.
Poulan “PP4218AVX” IPL (exploded parts list)
We are going to replace this page 1; item 47
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2010/NIUS2010_545103408.pdf
Poulan “PP4218AVHD” IPL
http://www.ordertree.com/modelinfo/PWE/PP4218AVHD-Gas-Saw-Type-2/75.PP4218AVHD-Gas-Saw-Type-2.1.59.1.html
With this; “Handle, Chassis & Bar Assembly” print; item 44; Clutch Cover Assembly; $9.50.
You also need;
• Item 43; Bar Mounting Nut; $0.56 each (need 2) and
• “Engine Assembly” print; Item 44; Scrench; $9.75.
This is the configuration professionals have used forever. The only thing to remember here is to hold the nose of the bar up when adjusting and tightening the bar nuts.
You will need retain the original model number IPL, there may be internal differences.
Down loadable PP218AVHD IPL
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2006/NIUS2006_545014325.pdf
Poulan “PP4218AVHD” OM
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2005/NOUS2005_545047503.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
May 16, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Can you please tell me what the carb adjustments are for the Poulan 18in. wild thing chain saw?
"L", "H", and "T" adjustments are all explained on the link. It is a very good carburetor setting procedure.
Start with “L” & “H” needle valves 1.5 CCW from lightly seated, then adjust for performance as follows.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
I am going to inject a little philosophy here. Undetected air leaks and defective fuel delivery systems account for most chainsaw failures. Constant adjustment of needle valves can easily camouflage more serious problems that result in burning up your saw. A sudden need for an adjustment may be indicative of a larger problem.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
May 11, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 2375 carburetor adjustment, please explian red abd blue adjustments and procedure
Blue = "L"ow, Red = "H"igh If running just do the following:
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If not running start with "H" and "L" 1.5 turns from lightly seated.
Lou
May 02, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Bogs down?
Try turning the "H" needle CCW a little. Cleaning the muffler and spark arrestor is a good idea too (if it cannot exhale it cannot inhale).
I do not think you need this but something to save for later.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 08, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
The chainsaw boggs down immediately when it contacts the wood. It runs somewhat choppy as well at idle. It is new to me and this is the first time I ran the saw. Is this a carb adjustment thing? plugged...
Clean the air filter. Remove, clean, and reinstall the muffler and spark arrestor.
If my new saw I would consider a Stihl mechanic tune up $40±. New plug, new fuel filter, pressure/vacuum tests and carburetor adjustment.
Lou
Mar 22, 2010 | Husqvarna Chain Saw 20" Bar
142 chain saw. Starts but will not pick up when
Remove, clean and reinstall the muffler and spark arrestor, if no better the "L" needle may need adjustment.
Most chainsaws die because they are are run lean. I am going to inject a little Lou theory here. Air leaks and defective fuel delivery systems account for most chainsaw failures. Constant adjustment of needle valves can easily camouflage more serious problems that result in burning up your saw.
Lou
Mar 21, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What are the carb. settings for modfle 1950
Start with the "H" and "L" needle valves 1.5 turns CCW from lightly seated. then tune for performance like this:
Clean the air filter and spark arrestor; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run. If the saw cannot exhale it cannot inhale.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
Lou
Mar 08, 2010 | Poulan Pro Chain Saw 46cc 20"
It starts and runs right for about five minutes, then it won't rev. to the highest rpm's. Will start after that but won't run fast enough to cut.It's a Poulan 3416----16" 34cc
Remove the muffler and clean out deposits from the spark arrestor screen. Make sure the intake air filter is clean. If these two items are good, then the 'H' carburetor adjustment may be too rich--turn clockwise somewhat until the engine runs at full speed, but 4-stroking slightly. The engine should smooth out and 2-stroke with even a light cutting load. Make sure the chain is being properly oiled while running. Hope this helps!
Dec 24, 2009 | Poulan ES350 16" Chain Saw
Poulan Pro 220 saw starts & runs fine when finger on throttle, will not stay at idle. Rplaced plug & same issues.
All you need to do is try to adjust the throttle idle speed or else a cheat would be to tighten the cable which means the cable will be pulling very slightly the throttle which means it will remain running when u release throttle.
Nov 05, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Saw does not idle and is hard to start. It is a P3314 Poulan
You have gum in your carbeurator.
You can try a carb. cleaner that you add to the gas. I likve one called seafoam. You add one ounce per gallon of fuel.
Also, you must have a good clean spark plug, and a clean air filter. The spark, the fuel, and the air all contribute to an easy start and a good idle. If you havn't changed the spark plug lately do so, same with the air filter.
Jun 24, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan PP4218AV 18" Chain Saw Logo
364 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
