Question about Dell Inspiron 1525 Laptop Jet Black (15.4" Wide Screen with true life, built-in Webcam, Intel Pentiu... PC Notebook
I get error message: "The remote device or resource won't accept the connection" when I try to access the internet. (I am connecting to a new network at a friends house)
  • 32 Answers
Before connecting please turn off firewall in your laptop and in router and then try again and still problem is there then there might be policies which are restricting your laptop to connect with wireless connection.
Posted on May 06, 2010
When i my pc on it show me generic host problem after this msg windows stop network services?anyone tel me
You may occasionally get an error message that reads "This connection has limited or no connectivity. You might not be able to access the Internet or some network resources." It indicates that your PC is having a problem trying to access your network device to connect to the Internet. Very often, a bug that typically affects Windows XP Service Pack 2 causes this error message. This bug causes a loss of your network connectivity in workstations that use Microsoft's L2TP-based VPN (virtual private networking) client to connect to the NAT-based networks. You can fix the "Limited or No Connectivity" problem in a few steps. (If your connection works but you still get the error message, go to Section 2 to learn how to disable it.)
Review the following symptoms and determine if you experience any of them after you install the Windows XP Service Pack 2:
You get the error message "Limited or No Connectivity" when you attempt to connect to your network.
You have a problem connecting to your local area network or to the Internet.
You keep on receiving an error message: "Acquiring IP Address" message. If you experience these symptoms after installing Windows XP Service Pack 2, then this bug is causing the problem. In this case, go to Step 2; otherwise, skip to Section 3 Download the Microsoft patch (KB884020) from the Microsoft website. Run this update to install it. Create a registry fix by launching Notepad and typing: [HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Services\\IPSec] "AssumeUDPEncapsulationContextOnSendRule\"=dword:00000002 Save the file as FixReg.reg to your desktop. Double-click the saved file to install it into your registry. Restart your computer and the error message will likely be gone. If you still see the error message, follow the steps in Section 2. b> If Your Connection Works But You Still Get the Error Message b> Navigate to the "Start" button and select the "Control Panel." Double-click on the "Network Connections" icon. Right-click the "Local Area Connection" icon and select "Properties" from the popup menu. Click on the "General" tab. Uncheck the option that is labeled "Notify me when this connection has limited or no connectivity." Click "OK." b> If the Patch Doesn't Fix the " Limited or No Connectivity" Problem b> Check your DSL router for any malfunctions. Re-configure or power cycle your router. Check your computer's network card configurations and network cabling to ensure that the problem does not lie here. Check your firewall to determine whether it is blocking you from connecting to the network or to the Internet. Disable the firewall and attempt connecting to the network or Internet while with the firewall is disabled. If the firewall is causing connection problems, then reset or uninstall and re-install the firewall. Reduce your connection speed to 10 Mbps and test this to determine if it fixes the problem. To do so, navigate to the "Start" menu and select the "Control Panel," "System" and "Device Manager." Review the properties of your network card. Click the "Advanced tab." Locate the "Link Speed and Duplex" section. Change the settings from "Auto Detect" to "10Mbps/Full Duplex." Hope this helps.
Dec 24, 2012 | Computers & Internet
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
I got a new toshiba tablet thrive. I'm trying to go online but I can't. I don't know how to fix this. The settings say that I'm connected to my wifi but still I can't get online. I need...
congratulations, your new device meets with the features functionalities of networking, communications among several innovative impressions. First, lets get familiar with networking termnology. Online is another term of surfing the internet either by a computer or recent telephone devices. For example, devices that are online have features capable of recognising several similar devices with several feature functionalities. Already modern computers are internet compartible especially with the recent ingenuities are wireless adaptable least requiring cables to capture online or inter networking requirements.
Lets get started with the online experience.
1. New computers would require that networking features be turned on for the first time. For example, powering device should briefly allow the user to ascertain the networking panel area for ajustments. Especially with new devices, networking panel area should be capable of allowing the user enable recognition of several other devices within the vicinity similar to settings required by having many computers requesting network communications.
a. Prior familiarise with the devices user guides ascertaining about wiifii, wireless feature locations buttons.
b. powering on the computer device from where feature buttons observable can be enabled by check markers or buttons especially makes the networking functionality attainable.
2. Once the computers networking features are turned on especially that new user recognises that several devices would derive interconnective creates the online processes
a. usually new computers would have on the desktop an icon button that indicates internet explore navigation, especially of recent computers may be mozziler foxpro, google chrome also called network pages or browsers.
b. Locate the browser icons, a click on the button should display a page especially with new computers already with wireless signals features enabled should display a message.
for example, an aready existing computer with wireless resources is capable of being recognised on the new computers browser page as indication that the online process is successful. What makes the online process unattaionable? For example, the new computer may least attain accessibility another computer in situations that available devices in vicinity are subscriber line networks. What that means is that the local area vicinity computers or telephone devices that are wireless capable are subscriber device least allowing sharing resources. It may be possible in this situation that the new computer recognises available devices however least capable of attaining or displaying resources beyond the browser page. For example, a click on the browser on the computer desktop would display a page also with messages that a connection as not successful, aborted, disconnected or unavailable. Usually,attempting to connect a computer device or phone may require refering with internetworking provider that has several functions.
For example,
1. the local area where the new computer is being installed would have existing computers that have subscriber paid services least allowing that devices share resources without additional fees.
2. refering with the networking provider ascertains that the new computer may share resources from available computers at paid fees discussable. For example, in area that the local area devices have broadband resource sharing usually costs exuberantly. second, in a situation that the local area devices have networked betweet devices least allowing access may require acquiring modems or modulations devices as means toe belong to the several devices of networks. The advantages of modems is that, the new computer becomes capable of capturing an enormous amount of resources especially from several networked structures. modems have enormous functionalities, the possibilities are that the new computer may interprete programs, that may least becomes dicipered especially that networking involves several devices, computers microsoft, apple mac, or telephones from several technology companies. A modem adds to the interpretation capability of the new computer that may already be internetworking compartible.
Jul 20, 2011 | Toshiba Tablets & eReaders
Try restarting your router. If that doesn't work than check if you didn't accidentally hit the wireless button on your laptop as many people tend to do this and not realize it.
Apr 09, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Connecting to Internet using a dial-up modem
can you connect that modem first, to a phone line, and run a telnet or dial connection from control panel or accessory ?
Mar 20, 2008 | Computers & Internet
Dell Inspiron 1525 Laptop Jet Black (15.4" Wide Screen with true life, built-in Webcam, Intel Pentiu... PC Notebook Logo
50 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
