Question about Labtec Pulse 485 Computer Speakers
My bass dosent work - Labtec Pulse 485 Computer Speakers
Hi, might as well give this a go. My Aria IGB35 (4-string) dosent work electrically. Thats all the info I'm able to give and dont wanna pay some guy 35 quid to fix something I could do myself. Any idea...
OK, plug in a cable, borrow a multimeter from a friend and meaure the output resistance on the other end of the cable, between the 2 connections on the plug. Should be between about 3000 to 15000 ohms with volume control flat out. Then report back here with your findings.
Apr 25, 2011 | Aria IGB 35 Bass Guitar
No bass
Your amp may bet set to "HPF" which is a high pass filter. It needs to be set to LPF
Apr 13, 2010 | Kicker 02S10L74 Car Subwoofer
Pyramid PB1500 vs. Metrik Rem. Bass knob????
Yeah it's probably not going to work because it's not even the same brand
Jan 18, 2010 | Pyramid PB1500 Car Audio Amplifier
Car stereo
check your amp to see if its on high or low setting in order for it to bump it needs to be on low thats all the bass settings and you shouldnt hear the words come out of your subs
Nov 01, 2009 | Car Audio & Video
Amp is on, but sub wont produce any bass
Make sure the subwoofer is set to low frequency, make sure subwoofer and bass are enabled on the headdeck. Make sure the gain is turned up on the amp, make sure the rcas haven't come out of the back of the head deck.
Aug 04, 2009 | JBL GTO14001 Car Amp
System has a buzzing sound dosent go away unless i turn bass all
Sounds as if you may have a bad ground. try running an external ground from the radio to a bare piece of metal underneath the dash.
Dec 30, 2008 | PPI Car Audio & Video
I have 1 sony xplod 12" 1300wat sub and a 1200w sony amp... how do i set the amp so that the bass hits but dosent distort
look for the potenciometer input for the sub woofer(gain) and turn to left,when the distors stop that is the point of work subwoofer
Aug 10, 2008 | Sony Car Audio & Video
Subwoofer not powering enough (Sounds like under powered 8inch)
get a nice monster subwoofer cable and a Subwoofer PowerCenterâ„¢ SW 200 with Clean Powerâ„¢ Stage 1 get it from like amazon and you'll definately see a difference and also put the sub in like a corner
Jun 08, 2008 | JBL S120PII Subwoofer
Labtec Pulse 485 Computer Speakers Logo
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
