Question about Casio CFX 9850GB Plus Calculator
How do I change the mode to polar on my CFX 9850GB Plus Calculator?
  • Casio Master
  • 8,073 Answers
  1. Turn calculator ON
  2. If you do not see icons press the [MENU] key.
  3. Use the arrow keys to move focus on the [RUN] icon.
  4. Press [EXE]
  5. In RUN screen press the [OPTN].
  6. After you press the down key once you highlight the line "Func Type"
Here is what you see.
The polar graph type is set by pressing F2:r=. In general r=f(theta). After the F2 key is pressed the Function type changes to r=
Now, if you press the MENU key and use arrows to focus on and select GRAPH, the function entry screen looks as in the picture How do I change the mode to polar on my CFX 9850GB - 824a5b3.jpgout the 2cos(3theta))
After you enter the function (use the (X, theta, T) key below the [ALPHA] to enter the theta variable) press EXE to validate.
After the r1=2cos(3theta) curve I opted to change the function to r1=2cos(5theta)
Press F6:Draw to draw the graph. Here is what you get.
Enjoy.
Posted on Jun 23, 2010
  • k24674 Jun 23, 2010
    You might have to play with dimensions of the window to see a better portion of the graph.
Convert a polar equation to a rectangular equation?
To convert a complex number (not an equation) from rectangular coordinates to polar coordinates you do as follows
2+3[OPTN][ F3 (CLPX)][F1(i)][F6 >][F3> r ,theta][EXE]
Nov 08, 2014 | Casio CFX-9850G Plus Calculator
How to use casio 9850GC PLUS to solve equations in polar form?
Put the calculator in Equation solving mode. Select F3:Solver. Enter your equation; use X as unknow (no need to use Theta, the name of the variable is irrelevant.) Besides if you use theta you will get a syntax error.
Jun 29, 2012 | Casio CFX 9850GB Plus Calculator
I have casio cfx 9859gb plus i dont know how to change from deg to rad pls help
Press SHIFT [SETUP] to bring up the setup screen. Move down to the line beginning "Angle" and select "Rad."
Nov 29, 2010 | Casio CFX 9850GB Plus Calculator
Casio CFX-9850GB Plus calculator will not switch on when AC/on pressed, all 4 AAA and 3v backup battery are new.
If it is just a matter of the screen being too dim, you can actually increase the contrast.
  2. Press [MENU] even if you do not see anything
  3. Press [ALPHA][COS] sequence to access the letter E.
  4. Press repeatedly the Right Arrow till the contrast is adequate.
Jun 14, 2010 | Casio CFX-9850G Plus Calculator
Casio cfx-9850gb plus calculators's graph messed up
Press the RESET button on the back of the calculator. Use a starightened paper clip.
May 05, 2010 | Casio CFX 9850GB Plus Calculator
Do i have only one type of exponencial regression o my 9850gb plus?
Th CFX-9850GB Plus is programmed to perform 10 types of regressions, namely
LinearReg: Linear y=ax+b
Med-Med also linear y=ax+b
QuadReg :Quadratic y= ax^2+bx+c
Cubic: y=ax^3+bx^2+cx+d
Quartic: y=ax^4+bx^3+cx^2+dx+e
LogReg, logarithmic: y=a+b*ln(x)
ExpReg, exponential y=a*e^(bx)
PowerReg, power: y= ax^b
SinReg, sinusoidal: y=a*sin(bx+c) +d
LogisticReg, logistic; y= c/(1+a*e^(-bx))
There may be more regression models appropriate for more advanced (specialized) statistics but the ones in the list are all the CFX-9850GB plus offers. However, since the calculator knows a programming language, you may want to implement a particular model.
Hope that helps.
Oct 24, 2009 | Casio CFX 9850GB Plus Calculator
Generating random numbers
Turn calculator ON, press MENU if you see no icons. Use arrow key to highlight the RUN application. Press OPTN, press F6 to pan right. Press F3: Prob, then F4:Ran# then EXE to execute.
Each time you press EXE a new random number is generated. You might want to fix the number of decimal digits to less than the 10 digits displayed by default.
By default number generated are between 0 and 1. If you want numbers between 0 and 100 you enter Ran#(100).
Hope it helps.
Oct 20, 2009 | Casio CFX 9850GB Plus Calculator
To change the mode from rad to deg
Turn calculator ON. Scroll menu icons to RUN. Press [EXE].
Press [SHIFT][SETUP] . Scroll down to 5th line. Press F1. Angle changes to Deg. Press [EXE].
Sep 24, 2009 | Casio CFX 9850GB Plus Calculator
Calculation with angle
You perform all calculations in complex mode. When you need to convert to angle amplitude, in the [RUN] screen press [OPTN][F3:CMPLX]
To obtain the angle press [Arg] ( complex number) [EXE]
To obtain the magnitude, amplitude press [Abs] (complex number) [EXE].
Since the [ANS] memory keeps only the last value calculated, you may have to store your result (the complex number) in a variable.
1+ 1 i [white right arrow under tan key to store] [ALPHA] H
Display shows 1+1i. Then
[Abs] [ALPHA] H [EXE] gives 1.414213562
[Arg] [ALPHA] H [EXE] gives 45
Hope it helps.
May 22, 2009 | Casio CFX 9850GB Plus Calculator
Casio CFX 9850GB Plus Calculator Logo
187 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
