Curser frozen on the desktop after booting up the computer
I cannot move the curser once the computer has booted up to produce the desktop on the screen.
  • 54 Answers
Check if it is working in the recovery manager or not. if not, then its a hardware fault. if yes then do a hard reset and check if it works, and also try to do a bios default.
for more info, mail me at L2support.hp@gmail.com
Posted on May 06, 2010
I was installing avir virus protection on my hp pavilion. It stopped working an error message said something about memory. The curser than slowed, everything disappeared and only the wallpaper was on the...
That means the Antivir corrupted system files that are responsible for the booting process. This is what you need to do...
Boot the computer until it comes to a point where you can only see the cursor. Then press CTRL + ALT + DEL. This will open the TASK MANAGER. In the Task manager, go to FILE and then click on NEW TASK and then type the following EXPLORER.EXE
This will make your desktop icons appear. Once they do appear, go to control panel and uninstall the antvir.Then restart and Install a different antivirus like Kaspersky
Sep 16, 2013 | Computers & Internet
My acer laptop's curser is frozen. hard booting doesn't help. any suggestions?
press ctrl+alt+del and pull up the task manager, it should show you if it is responding and give you the option of ending whatever is interfearing with it.
Aug 08, 2011 | Computers & Internet
When i boot my pc up (windows vista) it goes through the motions of booting up i see all the bios stuff on the screen as it scrolls through but then the screen goes blank however i can see my curser in the...
I'm afraid that in this situation, the operating system will have to be installed from a DVD. If you can't get to the 'recovery console' or the 'restore' area, then that's the only way I know that it can be reinstalled.
Unfortunately, many newer computers don't come with the backup disks or recovery disks, and you should make your own whenever the computer is first used.
Good luck on this repair or reinstallation of windows vista.
Nov 10, 2010 | Computers & Internet
How do i reset or fix a stuck cursor a frozen lap top dell inspiron E1505 it booting up and coming on but the cursors not moving, it seems like everthing works except the curser
Try uninstalling the drivers for the mouse first, then reboot to see if that works. Don't worry, the drivers will reinstall automatically upon reboot.
Hope this helps. :)
Sep 29, 2010 | Computers & Internet
Dell 8400 Refurbished by with WinXP Pro preinstalled will not boot up. Gets past Dell XP Logo, then goes to blank screen with curser...however, keyboard locks up and can not get any further? What's th
windows is not loading properly.
if you're not worried about anything on the computer:
insert the recovery CD, boot the system to the CD, and reinsatll windows.
May 19, 2009 | Dell Dimension 8400 PC Desktop
My ViewSonic computer monitor keeps displaying a Vga Not Support Message upon booting then the message Out Of Range comes up on a completely dark screen. Need Help
It sounds like the computer is trying to use a resolution that the monitor cannot handle. Boot into safe mode by pressing the f8 key during boot up and select safe mode. Once booted, right click on the desktop and select properties. In settings lower the resolution by moving the bar to the left and reboot.
I would move it all the way down, you can then move it up a step at a time once you are in normal mode again.
Hope this helps
May 02, 2009 | ViewSonic VA721 17" LCD Monitor
Computer shows invalid system disc,wont let me do anything else
This might be simple.
Assuming your son didn't make any internal changes to your computer. The problem may be that he changed your boot sequence to boot to floppy or CD instead of the Hard Drive.
Do the following:
As your computer is starting you will briefly have the option to hit F8 (I think F8 Might be another) for "start up menu or options".
This will take you to a screen of text where following the on screen text areas and moving the curser with the keyboard arrows and enter or escape check your boot sequence (the order of where your computer is to look for start up information)
It should read as follows:
#1 HDD1 (this text may vary)
#2 CDROM drive
#3 FLOPPY (if you have one) or other removable drive
If your son changed this and forgot to it back your computer may be trying to get start up information from a CD or Floppy instead of your hard drive.
Once you've changed this (assuming you needed to change it) following the instructions use the key to "save changes and exit"
Your computer should now boot up correctly.
Let me know if this helps
Jan 02, 2009 | Compaq Presario 5000 PC Desktop
Mouse Cursor Frozen
Try putting the computer into safe mode by shutting down the computer. Turn the computer back on. At beginning of the boot process press and hold the f8 button and select safe mode from the menu.
When the safe mode is done booting up, try moving the mouse around. If it works, restart the the computer under normal Windows startup procedures.
Jun 13, 2008 | E-Machines eMachines Desktop PC
Mouse and Keyboard not recognized
i think ur computer hangup after booting
there may be some problum in ur op system . it hase virous.
2nd u test ur mouse and keyboard to another computer if they work correctly u have to reinstall ur op sys
u can call me 91-9329204658 india
Jun 01, 2008 | E-Machines eMachines Desktop PC
My computor seems to have frozen up the cursor is not moving
You should try starting in safe mode. Shut down the computer completely - switch of - wait a minute and then switch on...
To get into the Windows XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the Windows Advanced Options Menu . Use your arrow keys to move to "Safe Mode" and press your Enter key.
Once you are in safe mode you shold be able to investigate the problem.
Let me know how you get on.
Apr 16, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
