Question about Plumbing
The sink drain leaks
My kitchen sink drain leaks with the stopper in it which was just replaced in February 2010.
  • 349 Answers
Sounds like plumbers putty un drain flange to sink may need to be replaced or strainer may need to be tighten up a little to see if that stops the leak.
Posted on May 05, 2010
What would cause a gurgling sound at the kitchen sink when no water is running anywhere in the house?
the waste disposal system for your house was installed by a person who was not competent to do the job and didn't make allowances for sufficient air pipes in the system or placed them on the wrong side of the traps
I would have an engineer inspect the installation to pin point the problem so that what you have doesn't occur and if it is installed contrary to plan and engineering requirements seek legal redress from the plumber that did the job
Nov 15, 2015 | Dishwashers
Clogged drain on moen bathroom sink
There should be a stopper valve on the sink's downspout (the first section of drain pipe). You SHOULD be able to loosen the nut holding the stopper valve's lever inside the pipe. Once you remove that nut, you can pull the lever out - that releases the stopper inside the sink, so you should start with the stopper OPEN, and hold it open with a chopstick or pencil or other tool when you remove that lever.
The lever and the bottom of the stopper itself will be wrapped with masses of hair. That's normal. Clean it up and reinsert it, put the nut back on & snug it down, then readjust the stopper.
If that's not enough, you may need to open the trap (the gooseneck-shaped piece of drain pipe under the sink) to clean it out.
Apr 05, 2014 | Moen Tub Drain Assembly, Lift-N-Drain -...
When installing do you silicone each piece for example the faucet , the soap dispenser ,the sprayer , and the tap
Hi seawitch678,
If you have a granite or stone countertop/sink, use silicone as plumber's putty will stain the stone. Plumber's putty is petroleum based so it will not adhere to stone. Normally you should use what the manufacturer recommends and where they recommend. When installing a faucet, put either around the base of any piece that goes through the countertop.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 15, 2011 | Price Pfister Marielle Kitchen Faucet with...
My strainer/stopper is stuck in kitchen sink drain. How to remove it?
If it's not visible from above then you must remove the trap j-bend. Go under the sink and put a big bowl or tray under the trap because when you remove the j-bend water will come out. You'll need a 12" grooved pliers, like channel locks, to get the nuts off. There are two of them. If the trap is old brass or chrome you may end up cracking the j-bend. If it's white or black plastic you can probably remove the nuts by hand. Look in the j and pull out your stopper. If it's visible from above a long pair of needle nose pliers would work best to remove the stopper.
Jan 31, 2011 | Blanco Sink Waste Strainer / Stopper...
Very slow drainage of a small bathroom sink. Liquid Plumber does not help
probably hair stuck in the drain. did you remove the stopper "pop up" if no hair or blockage there or in the trap, then its further down, you will need a small snake. 1/4 inch cable works well in bath and kitchen drains.
you can purchase one at home depot.
Aug 05, 2010 | American Standard Home
Hair wrapped around the sink stopper. How do I remove the sink stopper to clean? it is hooked on to the little level to open or close drain but don't know how to get it off without breaking.
The lever it's hooked to under the sink it has a nut to loosen to pull lever back. Then the drain stopper will be able to be removed. Check out this link to get a look at the under neath to help you I hope.
http://www.diynetwork.com/how-to/how-to-replace-a-pop-up-drain/index.html
Jun 24, 2010 | Home
Bathroom sink needs new drain, leaks under counter
Is it a new sink? Most of the time if it's new you'll have to get more pvc pipe because the new tail piece that comes with the new faucets usually is either longer than before or shorter. Yes you can get another tail piece or you may be able to by a longer pvc piece to to hook up the the metal tail piece. Make sure you have the plastic seals inside the pipe where they attach together or it will leak. Once you have it all together close your stopper and fill the sink with water and then pull the sink stopper and watch for leaks if it dont leak then it wont leak.
Dec 30, 2009 | American Standard Cambridge 5' Americast...
Our bathroom pedestal sink is very slow drain and clogging -2 questiions: do you have to disassemble and take off sink mounts and remove from wall to get to elbow joint? I do not know how to disengage...
You shouldn't have to disassemble everything in order to get to the trap (elbow joint). Most pedestal sinks are designed so that you can get to the trap from the back (generally after getting down on your hands and knees and crawling around with a flashlight). Most sink stoppers that are worked from the faucet itself have a little bar that extends down the back of the sink behind the drain. It will clip with a little metal piece to a lever that sticks out the back of the drain before the trap. The lever goes through a hole in the drain and pokes into a hole in the bottom of your sink stopper. As you move the lever, you will notice that your stopper goes up and down.
Unclip the rod from the lever and you should be able to unscrew the lever from the back of the drain (don't loose the little gasket that sits inside the screw-cap as it keeps water from leaking out here). At this point, you can pull out the stopper and see what is going on. If cleaning off the stuff attached to your stopper doesn't solve the problem, you can then remove the trap to see if anything is clogging that. Hopefully, by this point, your sink clog has been identified and you just need to reassemble, making sure when you put your stopper lever back in that you actually get it into the appropriate hole in the stopper itself.
If this doesn't solve your problem, it's more serious and you probably want to call a plumber as the issue is either a clog farther along or a problem with the venting of the sink drain.
Aug 30, 2009 | Home
Vessel sink's drain is leaking
a waste with a over flow does not work well with a vessel sink because the sink is to thin
Jun 16, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Kitchen sink drain is leaking
Yes all can be replaced. They sell complete replacments at Orchards, Home Depot or Lowes. Just make sure you are getting the right parts.
Apr 18, 2009 | Eljer 212-1088-00 White Dumount Double...
Plumbing Logo
349 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
