Question about Maytag MSD2756G Side by Side Refrigerator
Maytag RSW2400E side-by-side refrigerator ice maker won't refill
Everything else seems to work but the ice maker won't refill.
Can I swap the leads on the dual solenoid valve (water and ice supply) to see if that is my problem before I order the part?
    President:
  • 1,561 Answers
I advice you swap the leads on the dual solenoid valve because it is possible thats the problem.
If it did not still work, you can get a technician to help look into it before ordering for another because it might just be a little fault that will not cost you much.
But if the only alternative is get another one, then go for it.
Take care.
Posted on May 05, 2010
Ge refrigerator ice maker has stopped making ice
The water valve on the back of the refrigerator is bad, one controls water for the ice maker and one controls water for door water
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
May 11, 2014 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
The water was turned off the the ice maker and then turned on a few days later.....now the ice maker will not make ice......it will not fill up with water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} put water in it and see if it dumps the ice after it’s frozen. I
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 14, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
MAYTAG MSD2641KEB SIDE BY SIDE, DOES NOT MAKE ICE ANYMORE. I HAVE ALREADY DEFROSTED THE FREEZER ONCE, BUT THIS HAS NOT HELPED. WATER IS VISABLE IN SUPPLY HOSE AT THE BACK.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
Oct 21, 2009 | Refrigerators
Kenmore refrigerator side by side ice maker not making ice.no water going to the ice maker??.
Sep 09, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag MSD2754GR - Ice Maker quit working.
Aug 29, 2009 | Maytag MSD2456G Side by Side Refrigerator
No ice
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will make the switch to start the cycle.
Aug 19, 2009 | Refrigerators
The ice maker quit working but I still get water from the door dispenser. It's a Maytag model MSD2456DEW
I know this is late but I will tell you that most times the water control valve on the rear of refrigerator is the reason for the ice maker not to refill. Yours uses a part number 61005626 dual water control. One side for dispenser and the other side for the ice maker. You may test the ice maker to insure that it works by filling with tap water. Let freeze and if it dumps the then ice maker will try to refill after each cycle. If the water control valve works it will refill. Let me know if you still need assistance. Thank You, Sea Breeze
Aug 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
Maytag plus MSD2756GEQ ice maker not working
I had similar problem in that the fan in the freezer that blows freezing air into freezer and over to fridge was not working. Fridge was running warm (over 40 deg and freezer up near 20) Service call around $160 with new fan.
Feb 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker been working fine, just stopped?
If no ice is being made at all it is probably one of three problems. The ice maker itself needs replacing. The water inlet valve needs replacing. Or the freezer is not 10 degrees or less. You will need to test the water valve solenoids. If you have water in the door then there will be two solenoids. One for the ice maker water and one for the water in the door. They are both mounted on the same assembly. The easiest way for you to test is with a meter. You want to check for continuity on the solenoid for the ice maker. If no continuity, it is bad. If you have both water in the door and ice maker and no meter you can swap the two quick disconnects on the two solenoids and then see if you still get water from the door by now using the other solenoid. If you do not, then you know that, that solenoid is bad. If the soloind is good then you probably have a bad ice maker not calling the ice maker fill valve to allow water.
Jan 10, 2009 | Maytag MZD2766GES Side by Side...
Maytag MSD2756G Side by Side Refrigerator Logo
214 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
