My maytag atlantis top loader makes a loud rough noise while agitating.
  • riza18 May 06, 2010
    the model number is mav6260aww
  • 3,230 Answers
Well first of all you can check out the Belts - there are two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer.
After then you can check bearing most of the time or more likely the transmission is going. Look to see if you have any oil leaking out of the transmission. If so, see if you can replace the seal that is leaking before the transmission goes completely. You can please tell us the brand and the model number for detailed solution......
Good Luck!!
Thanks
Posted on May 05, 2010
Washer makes loud grinding noise during agitation and does not agitate - it is a maytag atlantis.... fix or replace?
I suspect the thrust bearing kit is bad. This comes with great instructions and is easily replaced. I would recommend changing this before replacing the machine. You are not out much if it does not work, but I am confident you will get it going by replacing this! This is a VERY common problem with these washers and the new kit has been redesigned.
Kelly
Mar 21, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Agitator doesn't work but spin cycle works, makes a loud noise when in wash cycle but agitator is not working
This means that the transmission has failed, check the use and care guide some had a ten year warranty.
Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis washer. Washer makes noise that approaches grinding, and the agitator doesn't spin. Rather, isn't connected to the motor. Spins semi-freely by hand, with a rough motion and noise
Your unit is gear driven and is contained in a mechanism enclosure.The roughness your feeling when turning it are the worn-out gears.One cause is it might have ran out or dried out of gear lubricant.The motor drives a belt to run the gears so the motors are running fine.Your gear box is the problem.
Dec 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Won't start
if it filled proplerly and won't start now, it sounds like the door switch is broken, there could be something wrong with the rest of the electrical systems, however i would suggest the switch first. If there is a lot of noise like its trying to run, then its probably your transmission.
Jun 25, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Agitator now moving VERY slow one way, making loud grinding noise
Hi, this is a bad transmission gear box that is stripped at the moment. i recommend purchasing a agitator kit and a new transmission Assembly and clutch as well. this will fix your issues
Jan 28, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Agitator stopped moving back and forth
dismantle the agitator and see if the shaft of the gearbox is moving.its either the gearbox or the agitator
Feb 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
