Question about RCA RT2760 System
Static when playing music and speakers pop
When music is playing the speakers dont have good sound qulity and when i turn it up or down i get a poping sound from all the speakers and the sub. The sub cuts in and out as well. What do i do?
  • 55 Answers
Try to clean the volume control with contact cleaners
Posted on May 06, 2010
My right speaker isn't working...
If you hook what is now the left speaker does it work on the right hand channel? If not the cable to it is defective or the connections or the Amplifier is defective.
May 03, 2014 | Harman Kardon Audio Players & Recorders
Cracking and poping with Yamaha surround sound system
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Jan 03, 2008 | Pioneer VSX-54TX Receiver
Hello sorry to my english,anyway i have a iproblem to my sound it did not play a certain music cause it pop up certain problem. the pop up problem my computer dont have a sound device what should i do?...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 21, 2011 | Computers & Internet
The speakers made a repetitive popping and buzzing sound that seemed to strobe as soon as I plugged the entire system in. After awhile the popping stopped and the speakers began to play music, the display...
hope this helps
Mar 14, 2011 | Altec Lansing ADA 890 Computer Speakers
Static
Check the equalizer in Itunes to make sure you don't have it set to the highest values. This could be the reason why your speakers are playing the music with static.
Here is video that will help you access the equalizer: http://www.videojug.com/film/how-to-use-your-itunes-equalizer-2
Aug 30, 2009 | Dell A425 Computer Speakers
Onkyo SR606 - Loud Poping
It could be a number of things,
1. an electrical short in the house. Try plugging it into another circuit with an extension cord.
2. A bad RCA cable that is input from one of your sources.
3. its probably a bad unit if you have Zone one and two playing at the same time the same source, but it only happens on zone 1.
4. a bad speaker can make a poping like sound, does it happen on all speakers? unplug all but one and one at a time try to determine if the problem sticks, if not, then one of the speakers is out of phase or blown.
5. Playing music froma computer source will sometimes make a pop if your computer is slow or bogged down with checking emails..etc. mine sometimes studders PPPPPPPrioRRRRRity CCCCCLLLLLLLLEEEEERRRRANCCCEE AAAAAAALLLLPPPPPHAAAA OOOOOOONE.
it also pops real loud when booting or shutting down.
Personal note ........windows is such a hassle for Media systems.
I hope something here helps!
Charles
Dec 31, 2008 | Onkyo TX-SR606 Receiver
Popping noise while computer is powering down. Any suggestions?
Lower your main sound volume. Double click the speaker icon in the bottom right hand corner of your windows.(was it maxed out?)
go into control panel /sounds and select a lower bass setting in your sound settings. You usually have a choice of rock & roll ( lots of bass) opera setting, classical etc.. choose one with less bass.
Make sure your LINE IN is DISABLED. It may be causing this static feedback.
You may have blown your speakers by playing sound way too loud. You may need to buy new speakers.
Thank you and Good luck. *s*
Oct 24, 2008 | EliteGroup P4M800PRO-M478 Motherboard
Das TV make cracking and poping noise when you unhook it from receiver?
Sep 30, 2007 | Sony STR-DE197 Receiver
RCA RT2760 System Logo
136 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
