Question about Whirlpool Duet GHW9150P Front Load Washer
Inserting detergent/fabric softner/bleach
Ok- so i just got this washer from a friend, and im not quite sure where to put the liquid detergent... there is a lil plastic pulley slot that can be taken out, and is labeled, im not sure which way it should b inserted in...i need to kno where i pour the liquid detergent faqbhric softner and bleach? does it all go in the "maIN wash"
  • 141 Answers
First check in which tray the water is flooding then put in that tray and then start the main program
Posted on May 06, 2010
To use liquid detergent does the machine have to come with cup
ROFLMHO Thuli the lid /cap of the detergent bottle is your measure.and yes you just pour it into the water as you would use powder .bleach and fabric softeners are the only thing to keep seperate
May 26, 2015 | Washing Machines
I would like to know what laundry detergent and softner to use in my front load, and the right amount to use. I buy the H E products and some of them are really sudsy in the wash sink and I have this awful...
You should use HE detergent following the directions for that detergent. You can add liquid fabric softener. Make sure to fill the appropriate compartment to the Min line if you are doing a small load.
I've never used a washer that drained into a sink (always had a stand pipe). However, I suspect that the gummy residue is the excess softener that was removed in the rinse cycle. Try rinsing the sink with hot water after a laundry. This is part of the procedure to clean the inserts and detergent/bleach/fabric softener drawer when you get a build up in the drawer. In the future, use less fabric softener in the washer. Alternately, skip the fabric softener in the washer but use a dryer fabric softener.
The manuals for most Frigidaire appliances are available from http://www.frigidaire.com/manuals .
The direct link for the manual (in English) for the is: http://manuals.frigidaire.com/prodinfo_pdf/Webster/134609000een.pdf .
I hope this helps.
Jun 05, 2011 | Frigidaire ATF6000ES Front Load Washer
Just purchased daewoo washer DWD-WD1353RC..it seems the fabric softner is not dispensing and the detergent is barely used. I understand this machine usesHE detergents but it is using very little detergent...
this washer has different detergent concentration levels settings. 1.By holding delay wash then power button at the same time, while unit is off. then a C1,C2,C3 are main detergent concentration settings C1 being regular HE detergent and C3 being very concentrated some detergents tell you X2, X3 S1,S2 are softener B1,B2 are bleach 2. Then use buttons Delay wash to scroll for main detergent Extra rinse for softener Bleach for bleach 3. power button to exit and confirm
hope this helps also in manual and to clean tanks, Manual says to call a 1800# or find the instructions on the web. I've had this washer for a week no problems yet
Jan 31, 2011 | Washing Machines
Whirlpool Duet washer, dispenser problem with fabric softner
maybe it's clogged take the drawer out and see if the water flows out of that side ok. put into rinsea nd spin and it should put water into that side.
might take a minute
What happens let me know
make sure you have a towel ready
Feb 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Adding liquid to rinse cycle
on your h-3 the soap disp tray will allow you the add powder ,liquid, bleach, or fabric softner at the time you put soap in disp then the water valve will dispence at proper times in the wash cyc you don't have to stop the wash cyc
Aug 26, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
"fabric softner staining the clothes"
make sure you delute it with water. yes fabric softner will start to stain your clothes if you use too much of it. I would recomend stop useing it for a while. so you can clean the washer out. There is a product called Washer magic or Affresh that cleans out residues built up in your washer. or you can just run several loads of HOT water and bleach to clean it out. The hot water will melt the left over fabric softner in your washer. Fabric softner is kind of like hardend bacon fat thats what it looks like in your washer after time and if you do not clean your washer it builds up and builds up.
Also i do recomend alternating liquid detergent and powdered detergent. The reason why is powder leaves a residue that liquid takes away and vise versa. try this and let me know how it goes
Feb 12, 2009 | Maytag PAV2300 Top Load Washer
Whirlpool Duet dispenser problem
this is joyce
You need to call who ever you bought it from and tell them the problem that you are having, I have the same set and I am not having that problem at all. I love my set, just be sure to use the he detergent, or you will have problems that the manufactr will not help with.
thanks,
Dont overload machine the clothes wont smell clean.
joyce
Feb 06, 2009 | Whirlpool Washing Machines
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
GE FRONT LOADER WASHER Model#: WBVH5100HWW
You need to put the setting on whites in order for it to take the bleach. Not sure about the fabric softener. I use dryer sheets
Jan 19, 2008 | GE Model: WCVH6260HWW Kitchen Hood
Whirlpool Duet GHW9150P Front Load Washer Logo
112 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
