Question about Lowrance GPS
Have a x510c fish finder, have not used in about a year,unit will not power up at all. i have took my other lowrance and hoooked it up to the same power station and it comes on so i have ruled out the inline fuse. i do keep my boat inside. unit worked fine last time i went out in boat
  • jeames May 05, 2010
    Trying to find out what is wrong with my fish finder, model x510c lowrance fish finder. Does not power up I have connect my other unit to the same connection and the other unit works. Is there a fuse inside the unit or is there something I need to do
  • jeames May 06, 2010
    First this is not a gps thisis a fish finder, boat sets inside my shop when not in use, power source is good, unit does not come on when plug ed up, other identical unit does work on same connections,of there is a internal fuse could seine tell me what tools I need to get to it
  • 2,335 Answers
These are the standard troubleshooting steps for the Lowrance X510c:
  1. Check the power cable's connection at the unit. Also check the wiring.
  2. Make sure the power cable is wired properly. The red wire connects to the positive battery terminal, black to negative or ground.
  3. Check the fuse.
  4. Measure the battery voltage at the unit's power connector. It should be at least 10 volts. If it isn't, the wiring to the unit is defective, the battery terminals or wiring on the terminals are corroded, or the battery needs charging.
Since you said another harness-compatible unit powers up fine, I understand that these seem moot. If you are comfortable opening up your unit, and have no warranty to invalidate, I recommend opening the 510 up and checking for a blown fuse near the power supply lines or elsewhere inside the units, or anything out of the ordinary such as loose cabling or components. Otherwise I recommend sending your lowrance for servicing.
I hope that helps.
____________________________________
Lowrance X510C Manual Download
Posted on May 06, 2010
    President:
  • 1,851 Answers
For extensive back ground on your unit CLICK HERE
Please go to that link and read page 100. I am thinking the internal unit has a weak point. Most likely just a loose connection. With electronics and water you can get internal condensation at the end of the year with no sunshine to help knock down the dew point,. I suggest a look at the internal fuse as well. Your unit is serviceable so I would pull it down and have a careful look see. If it isn't a visual fix I would take it to a qualified repair shop as the schematic is not coming up anywhere.
Posted on May 05, 2010
  • Gary Rice
    Gary Rice May 09, 2010
    You say the unit was working fine - now it doesn't and the only variable is it sat without working -so I will cut to the chase - the battery went bad is 99% the most likely problem.
  • 713 Answers
Hi,the battery could the be dead. Leave it to charge on the wall charger for several hours. Then try again. There is a way to do a hard reset,if that doesn't work try connecting it to your computer for few hrs,afterwards the gps device will come on.
Thanks and good luck
How do I turn on fish alarm on hds5x lowrance fish finder
If you turn on the "fish I.D. mode" in your sonar options then you will be able to turn on the fish alarm as well. Lowrance HDS 5x Gen2 Fishfinder
This a link to a pic file for your owners manual.
Go to page 67 to, see how to access and enable/disable alarms for your unit.
Nov 30, 2014 | Lowrance HDS5x Fishfinders
Tip
Lowrance X515C Manual Download
Download Lowrance X515C Manual
Models: X510C / X515C
Have you misplaced your Lowrance X515C Fish Finding & Depth Sounding Sonar Owners Manual?
Would you like a digital, searchable, pdf version of the Lowrance X515C Fish Finding & Depth Sounding Sonar Users Guide?
Follow this link (& click FREE) to download a pdf version of the Lowrance X515C Fish Finding & Depth Sounding Sonar documentation.
I hope that helps.
__________________________________________
on May 06, 2010 | Boating
Tip
Download Lowrance X510C Manual
Have you misplaced your Lowrance X510C Fish Finding & Depth Sounding Sonar Owners Manual?
Would you like a digital, searchable, pdf version of the Lowrance X510C Fish Finding & Depth Sounding Sonar Users Guide?
Follow this link (& click FREE) to download a pdf version of the Lowrance X510C Fish Finding & Depth Sounding Sonar documentation.
I hope that helps.
Where do I get a manual for lowrance elite 5 fish finder chart plotter gps
Just type this into your browser's searchbox. manualslib.com/manual/292954/Lowrance-Elite-5-Dsi.html
You should be able to pull up the manual there.I just did. Garcuda
Nov 23, 2014 | Lowrance Elite5x Color Fish Finder 102001
Lowrance Elite 4X fish finder that reads between 1.5' and 2.5'
Hey Anon
The transducer installation is more important than anything.. next to correct wiring! You must make sure the mounting is good,,, if its outside the hull, make sure its sitting 1/16th below the hull with no obstructions.. if its inside the hull, the medium you used to fix the puck to the hull must be porosity free and the puck sitting as level with the WATER as possible..
Now, take the manual to the lake with you and DO NOTHING but read the manual and apply what you read to the unit,,, read -repeat - read-repeat.. forget about fishing... now read-repeat and learn... IF nothing seems to be reading correctly.. its probably the transducer installation.. YOU DID use a/the transducer specifically for this unit!!
Jun 24, 2017 | Lowrance Elite-4x Fishfinder
Lowrance fish no display
its history buddy screens out time for a new one
Apr 18, 2013 | Lowrance Boating
X510c most of the time it reads 1.6 for the depth, it flashes 1.6 then it will go to the correct depth for a shqrt time then get stuck on 1.6 again some times other depths but mostly 1.6
Does this occur at any depths...over 20ft even.
The X510c will have problems keeping depth in shallow water...especially if it is muddy, weedy down there.
If the problem occurs even in depth over 20ft, then try resetting the unit:
1. Turn unit off
2. Press and hold ZIN, ZOUT, and PWR until you see the depth (flashing or not) in the top left corner.
If the problem still occurs, make sure the transducer is clean and still mounted so that it is sending the signal straight down to the bottom.
If the problem still occurs, make sure the power is good. You can have the voltage displayed on the screen through the overlay data menu.
Does the problem occur at any speed? If the problem clears up when you stop or slow down, the problem is due to cavitation and the transducer will need to be moved to a location where it is in a smooth flow of water at all speeds.
If none of this helps, there may be a malfunction with the X510c. You can try to update it but you will need to get the software update from someone at Lowrance support and then find a way to connect your X510c to a Lowrance unit that has a memory card slot via a NMEA 2000 network. I can help you with this if you need.
Other than that you can have the X510c returned to the factory for service.
Jul 09, 2009 | Lowrance Boating
Service and product manuals for the model x85
Here ya' go...all 51 pages of it for the x75 and x85:
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/X7585_91201.pdf
Good unit...I use to sell them when I had my flats boat dealership.
Good luck.....
Apr 06, 2009 | Boating
GPS Logo
90 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
