Got my parents a 19" kenmark flatscreen for xmas. was turned off last night and wont come on again. Switch it on at the plug, standby light comes on (red). Press remote and it goes to green but that's all, no sound or picture. Wont go back to red either with remote or main on/off switch on tv.???????????????????? It did this once before and I can't remember what I did to rectify it and I can't find instruction booklet at the minute. HELP!!!!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 182 Answers
Manual is available from www.tvs-services.com
Posted on Aug 20, 2010
Why is my sylvania lc260ss1 flatscreen in standby.
Try unplugging it from power for a while, 10-15 minutes, then plug it back in and try it again. If it still doesnt work then chances are the power supply inside needs repair. The most common problem with LCD tv's is failing capacitors in the power supply, they appear to have power and the standby light comes on but they just refuse to turn on.
May 04, 2017 | Sylvania Televison & Video
Sony KL-50W2U rear projection TV stuck in standby
Try holding down the power button until it turns off and then turn it on again.
Nov 29, 2012 | Sony KL-50W2U
My Kenmark 19" tv won't
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem, do take in handling the fault, because it contains high voltage..
Good luck
Jun 07, 2011 | Televison & Video
LG 32LH2000 My TV was turned of last night in the usual way, the power turned off on the remote control, then the power supply switched off and the plug removed. This morning I attached the power...
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Apr 16, 2011 | LG 32LH20 32 in. LCD HDTV
Samsung flatscreen wont turn on but red light is on showing power ..my son used sleep timer last night
with tv in standby press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu DO NOT CHANGE ANY SETTINGS
look at list you will see reset
ONLY USE DOWN NAVAGATION KEY until RESET is highlighted
then PRESS RIGHT NAVAGATION KEY the tv will reset
PRESS STANDBY TO EXIT
the tv will need retuneing after
hope this helps
Dec 19, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
TV wont turn on. Standby light blinking 7 times in sequence.
It will most likely need the power on switch replaced its very common
Jun 21, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Wont turn on
pull the battery and try to power on. if no good test the power adapter with a meter - should give 18-19 volts. if it boots with battery off, power up and put battery back on to charge.
hope this helps
Jan 17, 2009 | Acer TravelMate 6460 (LX.TED0Z.071) PC...
Loewe Vitros 6370- won't turn on!
its a power supply problem.
Jan 13, 2009 | Televison & Video
Info on the lcd tv's
This might help you.
Proscan 19LA25Q 19" LCD HDTV at Crutchfield.com Proscan 19LA25Q 19' LCD HDTV: Detailed Info, Features and Specs, and Photos. ... Instruction Manual; Product Registration Card; Limited Warranty Card ...
www.crutchfield.com/ISEO-rgbtcspd/App/Product/Item/Main.aspx?i=68319LA25Q - 46k
Dec 16, 2007 | Proscan 19LA25Q 19 in. LCD Television
Televison & Video Logo
144 people viewed this question
Top Televison & Video Experts
