Question about Canon PowerShot A85 Digital Camera
Pink/purple melting effect
When I take the first 1 or pics of the day/event, the pics comes out with a pinkish haze. Usually it it also makes a pink/purplish melting effect on half of the picture. It looks like whatever I'm taking a picture of is in an pinkish ice cave or something..
It prints out that way also.
Please help.
Thanks!
  • Anonymous May 10, 2008
    pink and purple melting effect
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Mar 27, 2008
SOURCE:
Why am I getting a pink or purple haze when taking picture white or blue sky background.
1. Check the WB (White Balance) setting of the camera. Default is AUTO.
2. In certain environments it can be necessary to set the WB to another value.
Sep 18, 2010 | Olympus SP800UZ Digital Camera
Picture color is pinkish and out of focus
there might be a problem with ur monitor.
Step 1 - check these pics on sumone else's comp or open sum other jpegs just to check
Step 2 - If the pics are fine on sum other comp then ur monitor needs attention
Otherwise
use Adobe photoshop
adjustments ----> color balance to get rid of pink tint
Apr 05, 2010 | Canon PowerShot A95 Digital Camera
Camera takes pictures with pinkish sheets layers,sometimes melted
Melted shadowed and blurred pinkish pictures are symptom of defective CCD sensor.
The CCD sensor is the devices that captures light to generate picture. In your camera this part is faulty and must be replaced.
Sep 07, 2009 | Canon PowerShot S500 IXUS 500 Digital...
Purple/pink haze on a samsung tv
is it a tube or flat screen? if tube could be sign tube is going bad- can try to degauss it- if its a panel does the picture look cartoony? we call it solarization- may be a problem with settings in the service mode- may need new main board
Aug 19, 2009 | Televison & Video
When printing pictures, they are discolored
You are running low on your color ink cartridge. It cannot mix the primary colors right anymore and the color images start getting a pink-purple tinge to them. Get a new set of cartidges and install them and this should fix the problem fine. Hope this helps.
Mar 26, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Powershot A75 with pink/blue streaks
I have similar problem.highlights overexposed,with streaks of pixels running vertically.overall pinkish hue
Sep 07, 2008 | Canon PowerShot A75 Digital Camera
My pictures and display are pink
if resetting the camera does not solve this, then repair
Jul 29, 2008 | Olympus SP-350 Digital Camera
Overexposed
try it in auto mode if it is the same condition do u feel change in color like white turning pink or purple or sort of over exposed pics as u said then i worry that ur CCD HR is going to faulty in coming days later on pics will get pink and purple and then ccd stops working completely , i hope this is not the case do let me know if i can help u
Jan 07, 2008 | Fuji FinePix S1 Pro Digital Camera
Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Mar 27, 2007 | Philips 28PW6506 28" TV
Canon PowerShot A85 Digital Camera Logo
197 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
