Question about GE Profile PSS26NGS Side by Side Refrigerator
I need to replace the water tank disp asm in my GE
Our GE Profile side by side refrigerator water tank dispenser assembly leaks. I have ordered & received the replacement part but it did not come with instructions on how to remove the old part and install the new one. I would appreciate any help. Thanks. Part # WR17X11440.
dididsaythat
  • 291 Answers
SOURCE: Replacement of Interface Disp Asm. PSS26SGPA
Try using a putting knife, just apply slight pressure in different spots shoud just snap in.. cant break what already broke
Posted on Aug 21, 2007
  • 74 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Check the connector at the bottom of the freezer door first , you should also be able to hear the micro switch click when you press the paddle
Posted on Aug 28, 2008
Big Poppa Ma
  • 302 Answers
SOURCE: water dispenser on GE side
is there a kink in your water line?
Posted on Dec 06, 2008
  • 531 Answers
SOURCE: smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Posted on Mar 31, 2009
SOURCE: GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Posted on Jul 24, 2009
GE P5Hs6RGXBDSS sidexside with ice/water disp. Makes ice well but ice not propelled down shute. No blockage
Check to se that the auger is turning when you push the button for ice. If not, replace the auger assembly or the auger motor!!
Jan 31, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Replace an Interface Disp ASM on GE side by side
Part number WR55X10415 . Pull out from the bottom of the board , may have to use a small screwdriver to pry outward from the bottom to remove . Would suggest removeing top cap on freezer door and unplugging connector first .
Jul 18, 2009 | GE Refrigerators
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dipensers drips
replace the water disp solenoid,its located at the back of the fridge where the water line connects
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water dispenser on GE side by side not working. what should the refrigerator and freezer settings be? Can that be the problem?
Dispenser controls on any refrigerator actuate one of two things. Ice disp, or water disp. If the IM is not working also, then H20 valve is bad. If just the H20 disp feature isn't working in the door, try this: remove food and unplug unit for 24 hours. Then, plug back in and resume normal operation. If all checks ok, you have a frozen water tank, or frozen water line. Fix: on certain model ref's, there is a water tank service flash where an antifreeze insulation kit should be installed, contact Sears or your retailer for this information. On others, this is simply a freeze up caused by lack of H20 usage or temps in ref/freezer set too low. If this does not fix the water supply, and you still have ice production after 2-5 hours after restarting the ref, remove the dispenser cover and test the water supply actuator switch for continuity. of open after drepression, replace switch. If switch checks ok, then replace water valve as on side of the solonoid valve assy is not functioning. In rare cases, you may have to check or replace the wiring harness. This can be tested only after elimenating the disp switch test, and calling for H20 from the disp, voltage at the disp wires to the H20 valve, but no voltage recieved at the h20 valve, or by an ohm reading of the wires.
Jun 10, 2009 | GE GSS20IEP Side by Side Refrigerator
Smelly water dispensed from ge profile refrigerator
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Aug 16, 2007 | GE Profile PSW26P Stainless Steel Side by...
Ice & water dispenser not working
The control board is likely gone bad or a wire harness inside the front came loose. With all those indications, I'd lean toward a dead board.
Jan 07, 2007 | GE PSW26SGRSS Side by Side Refrigerator
GE Profile PSS26NGS Side by Side Refrigerator Logo
318 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
