Question about Dryers
The buner is only igniting once or twice you can
The buner is only igniting once or twice you can see glow plug working but burner wont ignite just blowing cold air
  • Dryers Master
  • 43,501 Answers
If you have a gas dryerthe buner is only igniting once or twice  you can - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 06, 2010
50E47-70 unit intermittent failure. HSI glows, gas valve clicks, but burner does not light. Cycles several times but does not light then flue fan continues to run until furnace shut off. Sometimes...
Hello, sometimes even though the igniter is glowing it can be weak and not able to ignite the gas. Also, since the gas valve is clicking that means that it is receiving 24 volts but it is also possible that gas valve is sticking and not allowing gas to flow to tne buners everytime.
Sep 06, 2011 | Heating & Cooling
One burner wont light of the 3
Is the igniter not sparking or is gas not getting to that burner? Have you tried to match light that burner? Those three things is where you start troubleshooting the problem
If the igniter is not sparking, it could be that the igniter is covered with cooking grease or the wire to the igniter has come loose either at the igniter or the igniter module. And simply needs to be reattached (pushed back on).
If the burner won't match light, than it's not getting gas and should be removed and thoroughly cleaned. And while you're at it, remove and clean all the burners and the venturis valves.
Removing the buner burners on a Ducane grill is a bit of a task, so I have included a link to your Owners Manual to assist you. Pay particular attention to the section Annual Maintenance, starting on page # 28.
http://help.weber.com/manuals/ducane/2009%20Manuals%20pdf/Affinity_3100_4100_LP_OwnersManual_27010331_101508.pdf
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
May 10, 2011 | Ducane Affinity 3100
Oven will not heat
This can be caused by a weak/inop hot surface igniter or a defective gas control valve. First you will need to verify that the hot surface igniter is coming on(you should see it glow in the burner compartment). If it is not glowing then you will need to verify that the wiring harness has voltage to it when the oven thermostat is on. Also check the igniter for any cracks or damage and if found then replace the igniter. If it is glowing then one thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on,igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing after the igniter is fully on. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve sticks again after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad.
Apr 01, 2010 | Tappan TGF363 Gas Kitchen Range
No blinks normal running igniter glows gas comes on wont run
Check for 24 volts across the gas valve when Ignitor is glowing. If no, bad board. If yes, bad gas valve or blockage.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Mar 05, 2010 | Goodman GMS90703BXA Heater
Gas will not ignite. glow stick not coming on
Hello there:
Problem -
No flame, or no igniter glowing at all,
the most common thing to check is ) -
Inspect igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter when dryer should be calling for heat.
ThanFirst check and see if you have 110 volts coming to the gas valve at this type of a connector. If you have voltage, then unplug the dryer and check the parts I have pointed to. Some dryers have 3 coils instead of the 2 shown here. If you do not have voltage coming to the burner, then you will need to check the timer contacts that feed the gas burner, hi limit thermostat, operating thermostats, the safety switch on the motor, and any other point that you can see on your wiring diagram picture that feeds voltage to the burner. The coils on the gas valve are very bad for working once or twice and then quitting. If you find a open circuit on one of the gas coils, replace them all = less problems later on. If the glow coil does not work ( get red ), check it with a ohm meter for continuity. The next thing to check if the glow coil does not come on would be the radiant sensor. Inspect the igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter wire plug when dryer should be calling for heat. Sometimes the ( older style ) igniter is separate from the holder and the holder can no longer hold the igniter tight enough and the two parts burn/arc where they touch each other = new igniter and holder ( some manufactures have new kits to replace these older style parts ).
Ok hope this is very helpful for you>
Best regards Michael
Jan 09, 2010 | Maytag Dryers
Turn heat on, I hear it ignite and furnace runs and runs fine then usually there is a slight delay and blower turns on and blows heat, but now it does not, I put my hand up to a nearby vent to no heat and...
Jan 06, 2010 | Goodman GMS90703BXA Heater
Viking gas stove operators manual....I was working on my stove ...it was not lighting up....the stove......and I noticed that there was 2 burners...and when I replaced one of the ignighters and tryed the...
The way it works is the igniter gets voltage signal from the control and will start to glow. The gas valve for the burner and the igniter are wired on the same circuit. When the igniter starts to glow it takes all the voltage from the circuit. As the igniter increases in temp the resistence changes and the voltage starts to travel to the gas valve. Once the gas valve registers 3 to 4 volts it will open allowing gas to the burner for ignition. The igniter needs to reach approx 2200 degrees for this to happen. So it could be the igniter or the gas valve. The igniter should test approx 500 to 700 ohms with a ohm meter. The gas valve could also be sticking. If the igniter is glowing bright and you tap the gas valve with a wrench and it comes on then the gas valve is sticking and needs replacement(as long as the igniter tests good)...Hope that helps.
Oct 11, 2009 | Viking Ovens
Oven wont light
Gas or Electric? If Gas at the bottom of oven where Oven burner is there is a glow plug ,or some might call ignitor. When it get a signal to ignite gas that glow plug gets hot and ignites gas. and that does goes Bad .
Oct 10, 2009 | Imperial Commercial Cooking Equipment...
Gas dryer no heat frigdarie
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
Gas dryer with no heat: The parts that I have pointed out (click it )
with the arrows are the parts that you will need to check with an ohm meter if the dryer is not heating. First check and see if you have 110 volts coming to the gas valve at this type of a connector. If you have voltage, then unplug the dryer and check the parts I have pointed to. Some dryers have 3 coils instead of the 2 shown here. If you do not have voltage coming to the burner, then you will need to check the timer contacts that feed the gas burner, hi limit thermostat, operating thermostats, the safety switch on the motor, and any other point that you can see on your wiring diagram picture that feeds voltage to the burner. The coils on the gas valve are very bad for working once or twice and then quitting. If you find a open circuit on one of the gas coils, replace them all = less problems later on. If the glow coil does not work ( get red ), check it with a ohm meter for continuity. The next thing to check if the glow coil does not come on would be the radiant sensor. Inspect the igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter wire plug when dryer should be calling for heat. Sometimes the ( older style ) igniter is separate from the holder and the holder can no longer hold the igniter tight enough and the two parts burn/arc where they touch each other = new igniter and holder ( some manufactures have new kits to replace these older style parts ).
Does the igniter get red and stay red, or does it get red, you hear a click and it goes off, then a minute later its gets red again?....if so you possibly have a bad set of coil valves. If the igniter gets red and stays red constantly then its the flame switch that is bad and maybe welded closed.
Sep 11, 2009 | Frigidaire Dryers
Glow plug lights but does not fire gas everything
This is most likely faulty gas valve coils. These electrical coils are located just above the gas valves and when energized, these solenoids open the gas valves and permit the burner to light. If faulty, the gas valves cannot open and the burner cannot light. Due to the difficulty in testing these solenoids, it is recommended that both (all) be replaced at once if any are suspected of being faulty. Hope this helped and best wishes.
Aug 08, 2009 | Dryers
Dryers Logo
274 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
