Question about George Foreman G5 Indoor Grill
G5 Handles on plates
All of the handles (10 in all) have cracked and now will not stay in. I think the screws were put in too tightly originally. How do I get replacement handles?
  • 1 more comment
  • Anonymous Mar 31, 2008
    yeah I need handles for my grill
  • Anonymous Apr 07, 2008
    Need handles too for George Foreman G5
  • vito544 Sep 26, 2008
    same deal here, the plastic handle broke on the plate
Called salton and ordered new handles for the plates
Posted on Mar 27, 2008
SOURCE:
The handle to my door is flimsy. it stays in place but when i try to open my door it wont open and its very flimsy not tight at all. i need help. is it fixable and what part do i need and if you know the...
Is this a 2 or 4 door model? both would need the handle replaced from how you described...must remove the inside door panel to change out the door handle...there is one hard to see screw behind the arm rest...must be removed to remove this panel...the door handle is a dealer or junk yard part...2 bolts one at each end hold in place...put window up when changing...junk yard handles are everywhere including on line...dealer gets $30-$35 for $2. junk yard part...If 2 door...different handle, same availability...these handles are interchangeable with other similar GM cars...hope this helps:)
Dec 13, 2010 | 1994 Oldsmobile Cutlass Supreme
How do you remove the doors
There are chrome plastic trim pieces at the ends of the full length handles. Remove gently, they are pressed into the groove of the metal trim. Next either slide or pull the front facing trim outward from the metal... exposing 6mm or 1/4 inch sheet metal screws. Remove. The handles may also have a double stick tape at the attachment points. Replace this after cleaning the old residue off with goof-off. If the screws won't stay tight afterward, remove the trim and add Loc-tite -- blue, red, or GREEN depending on how you feel about it.
Dec 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I'm trying to remove the handles from my GE refrigerator
some handles have plastic inserts or caps which snap on to the main handle from outside to hide the screws...you can carefully pry open those caps with a knife or screwdriver to reveal the screws....some are only accessible by first removing the inside panel to reveal the screws from inside the door.....in either case the panels are usually just helld in place by snapping together or in channels or rails.....they can be pryed off but with care to avoid cracking them or breaking them because you need to re-use them when you put back the handles.
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Dont know how to get my pliers to lock need instructions
open your vice grips up and put them around the item you are working on then close the vice grips if they are loose around item screw the knob IN til it gets tight around item then open vice grips and give the knob one full turn and put back on item and squeeze the handles together it should lock if you cant squeeze the handles together then back the knob back out until you can get the handles to lock or screw in if still too loose.
Apr 02, 2009 | Irwin Industrial Tool Co No.10R - 3 10"...
Neff Oven handle loose
The door can be seperated by screw on the side of the door, Put lock washers to insure futer tightness.
Mar 12, 2009 | Ovens
Storm Door Attachment
you need to shim in the frame of the storm door
Feb 11, 2009 | Hardware & Accessories
Handle on kirby ultimate g won't stay upright
Just take the handle off, rermove the 2 screws on the front of the cover, remove the plastic piece on the back of the top, then remove the 2 screws and the top cover will come off. There are 2 screws holding the handle pivot on, remove those. Install the new pivot making sure that it alines with the transmissing on the left side, re-install the 2 screws and make sure they are tight. Then put the rest back together.
May 10, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Handles
Go to
www.esalton.com
Search for G5 grill, select your grill, at the bottom there is a button to click to see available parts
Jan 05, 2008 | George Foreman GR10AWHT Indoor Grill
Broken lock on grill plate
If you find a source for a replacement locking handle, we would appreciate you letting us know. Likewise, we will let you know if we find a source. Thanks, [email protected]
Aug 29, 2006 | George Foreman G5 Indoor Grill
George Foreman G5 Indoor Grill Logo
168 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Thomas F. Schneider
Mike
Gerry Harvey
Gerry Harvey
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
