Question about Maytag PAV2300 Top Load Washer
Water drips into the tub when the washer isn't running
Water is dripping from the input lip. It drips from both sides of it. It is necessary to shut off the water when the machine isn't in use.
  • Maytag Master
  • 909 Answers
Your solonoid is in need of a service. Tilt the washer sideways after you unplug it and remove the water pipes. Once disconnected, undo a nut or two holding the plate in position.and remove water valve from machine. Possibly you can remove both water pipes from the valve assembly without going in from underneath. Once loose, use appropriate screwdriver or socket spanner and carefully strip the valve. Clean dirty area untill all particles are removed. reassemble and retry..
Posted on May 19, 2010
  • Maytag Master
  • 43,501 Answers
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Posted on May 05, 2010
Washer dripping water into tub
You have a bad water valve and that's why the water is still coming in after you turn the washer off. Replace the valve and you should be fine.REMEMBER to unplug the machine before doing anything.
Dec 08, 2015 | GE GTWN5050MWS 27" top-load washer with...
Water does not stop running into the tube
Sounds like a professional needs to diagnose and repair/replace the water valves.
Aug 23, 2012 | Frigidaire FEX831CS Top Load Stacked...
Washing machine drips water from top of tub.
THE WATER INLET FILTER IS MISSING , SO IT ALLOWS SOME FRAGMENTOF DIRTS INTO THE SYSTEM......U HAVE 2 LOSSE WATER INLET VALVE AND CLEAN
Feb 24, 2012 | Fisher and Paykel Washing Machines
Water is continually leaking into the tub from the inlets as a slow drip. This happens while the washer is off and continues forever unless the water supply is turned off. This is a stackable washer/dryer.
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Jan 06, 2011 | Washing Machines
GE WHDSR315 washer randomly drips still after done filling
you looking for a new water valve assembly...not very hard to replace..maybe a lil' messy
Aug 28, 2009 | Washing Machines
Leaks badly
Most dish washers do not seal at the bottom, the door lip just sits
in front of the tub lip and does not make a real tight seal like a refrigerator door, so unless water is spraying out the top and sides of the door,I would assume that it is either overflowing,or you are using the wrong detergent and it is just foaming to much inside the washer and going over the lip and dripping on the floor. Once the suds stop getting agitated then turn back to water and don't look like suds.
So if you watch the washer during the cycle and the water s only coming from the bottom it is the water level switch inside on right
in the front,looks like a mushroom, once the washer reaches a certain level of water this switch floats up and shuts off the water to stop it from filling anymore. If this seems to be the case just remove the front bottom kick panel and you should be able to see the switch, watch it when the washer is filling,you can also push up on the little arm and the water should shut off. Post back with any questions.
Apr 16, 2009 | LG LDF6810ST Stainless Steel Built-in...
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Water drips into tub when machine is not running
hi. thanks for the question. its strange that after you changed the valve . that its still doing it it .can only be a faulty valve. replace under warranty, in the mean time turn water off .the water should be shut off after every use anyway. we see some flooding from broken hoses, when nobody home. quite the mess .thanks the appliance doc please rate me
Oct 01, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Water drips in the tub
a faulty inlet water valve on the machine itself, just not seating properly allowing water to flow after shutting off, turning off water inbetween washes a good temp fix as well as a good habit to get into
Jul 09, 2008 | GE WPGT9350C Top Load Washer
Washer continues to drip into tub after cycle in complete.
contstant water dripping into tub sounds like a bad water valve, no repairing valve just replace it
Feb 25, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
701 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
