I haven't used my player for years. Although it turns on and off and the open/close and reject operate, nothing else does. I finally found it is necessary to hold in the chpreset button, up or down to get ch 3 for playing nothing happens after that. On my previous players it was only necessary to use the video remote to find channel 3 to use the player. When I try the same with this one ch 3 comes up for a second or two then defaults to ch 4 which give me a TV screen. I need step-by-step instructions.
  • jakdara May 05, 2010
    It's a Toshiba DVD player model SD-V55HTSU.
    President:
  • 1,768 Answers
1. I if the player is an earlier player it may not have the firmware issue and may not be able to be accommodate the auto channel switching.
2. You did not supply full information on the unit presented.
3. this may be due to a obsolete unit that is not compatible.
Posted on May 05, 2010
  • 566 Answers
Hi jakdara
I`m going to help you with your problem but first;
Can you tell me the brand name and model numbers of the equipment your trying to hook up ?
  • Jacques Marin
    Jacques Marin May 05, 2010
    Your a little too fast for me here, it has been 2 minutes since your last comment
    This is not a live chat
    Good luck
My DVD player on my Sony Dav-HDX274 5.1 Channel Home Theater System With Dvd Player won't open. When I push eject (on both the unit and remote) it will read open or close and although it sounds like it is...
It sounds that the laser pickup unit to your HTS is faulty. Contact any service technician to replace it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 16, 2014 | Sony Dav-hdx274 5.1 Channel Home Theater...
Philips DVP5140/37 disc tray won't open. Hello! I have tried unplugging from the power source and waiting 10 seconds as their website says to do. I hold down the stop button on the remote 5 seconds...
What could be done is to leave the set Switched ON for many hours even overnight and see how it can change if there is a possible fault on the motherboard, a change of value in electrolytic capacitors.
If there is no result then there is fault in the motherboard and you need to take consensus for an estimate.
Nov 05, 2011 | Philips DVP5140/37 DVD Player
Need code to unlock
Hi Margaret 366
Can't promise this will work as haven't tested it myself, but worth a try:
Open the Drive
Type 2403960
Press 9
Close the Drive
Turn Off
Turn On."
If this doesn't do the trick feel free to get back to me!
Thanks
May 06, 2011 | Toshiba SD2010 DVD Player
DVDs I burn will not play on other players. Players reject disc
Check that the burner is finalizing the discs. This can be set in Roxio or in the optical drive properties. In Windows 7, right click on the optical drive, choose Properties, then the Recording tab. Then the Global settings lets you choose to finalize the disc on eject. Try a different brand of DVD+R and check that the other players support DVD+R discs. (I know some DVD players only support DVD-R.)
I hope this helps.
Apr 15, 2010 | Roxio Easy CD & DVD Burning
I did not use my Zen MP3 4GB player for several months. On attempting to re-start it, I was unable to get anything except a blank -although lit - display screen. The player has been charged for many hours,...
try to drain the charge of the battery. the try to recharge it. most white screen issue of creative zen is due to power surge specially when it's connected to a usb port.
Aug 16, 2009 | Creative Labs Zen V MP3 Player
My DVD player has worked excellently for almost 10 years. Uncertain if that's the problem. All the buttons on the remote and on the front panel seem to respond--one way or another. This is a Sony CD/D
by a new player i recomend sony,there still the best. dont waste your money on blue ray,they will be obsolete in five years and they are very slow,ie. loading and reading discs, i know i sell them
May 19, 2009 | Televison & Video
CD changer problem disable play or reject CD function
I sould checkyou phone book to see if there is a bussiness that repairs car radios and cd players.
Other wise you should look into a new cd player at a local electronic store that sells car radios and cd players. The last option is to go to the dealer and order another one.
May 15, 2009 | 2007 Toyota Camry
My DVD Player does not reject a DVD. It gets stuck.
I had been closing the door at the DVD slot manually. I found that if I closed the DVD door with the close button, and then opened it with the open button, it no longer got stuck.
Jul 04, 2008 | Philips Televison & Video
VDSC307-4bss how to operate self-cleaning oven
I continued a search and found a manual on line... simple process to turn on self-cleaning operation... close the door and set to "clean" ... timer on this model is automatic... runs for 3 1/2 hours.. fan continues for an additional 30 minutes ... open the door and the oven is clean. Thanks
Mar 28, 2008 | Viking VCSO244 Dual Oven
Cyberhome 300 dvd player
try to pull the tray all way out by hand 1st knda resets it then hit close
Feb 03, 2008 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
