Question about Whirlpool MH2155XP Microwave Oven
Won't heat everything else seem to work. but it won't heat
  • Whirlpool Master
  • 17,970 Answers
If your Oven does not heat, it only means that your microwave "magnetron" is not working. Try to look for a busted fuse if all the fuses are ok maybe the magnetron it self is defective.
When you run a microwave oven without any food inside, there is nothing to absorb the microwaves and they build up inside the cooking chamber. Eventually, something has to absorb them and that something is the oven's microwave source—its magnetron. The magnetron isn't good at handling excessive power that returns to it from the cooking chamber and it can be damaged as a result.
From comment to other experts of experimenting with microwave ovens, have only killed a magnetron once. But then again, I haven't run a microwave oven for more than a minute or two without anything inside it. If the oven works again after cooling down, then you're probably OK. The oven may have thermal interlocks in its microwave source to prevent that source from overheating and becoming a fire hazard. If the oven fails to work after an hour of cooling off, then you're probably out of luck. The magnetron and/or its power supply are likely to be fried and in need of replacement.
Also, check the fuse (generally 20AMP), the Transformer and the High Voltage capacitor.
Hope help.
Posted on May 05, 2010
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Kenmore 721.80403 microwave won't heat
If the turntable does move as well it is likely the inverter (power) or the Magnetron itself.
Nov 03, 2012 | Kenmore Microwave Ovens
GE profile mirowave JVM1350WW002 - won't heat
There three area's of concern, magnetron, "heats food" the high voltage diode, "sometimes crack" the high voltage capacitor, "usually shorts"
Mar 24, 2012 | GE Profile Spacemaker Over-the-Range...
My Maytag microwave stopped heating. Everything
Generally the magnetron (the part that heats the food) is the cause if everything else still works. Unfortunately replacing the magnetron is barely cheaper than buying a new microwave though you can check out repairclinic.com to decide whether you want to attempt replacing the part.
Let me know how this works out for you.
Benjamin
May 24, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
Everything works but the heat! Any suggestions?
door micro switch open/need to replace / if that open the magnetron will not power no heat will produce.
Jan 02, 2008 | Whirlpool MH1150XM Convection/Microwave...
Whirlpool MH2155XP Microwave Oven Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
