Question about Apple eMac G4 Desktop
MAC EMAC G4 & IMAC G5 power supplies
I am looking to find the specs on the power supplies for some MAC G4 and G5s. I am having trouble finding the wattage. Any suggestions?
  • Scott Calafiore May 08, 2008
    Thanks but unfortunately the wattage on the power supply is for the maximum DC output. The AC input will can vary based on the computer's performance. I need a to measure the AC input to the power supply to some system so I can measure how cost effective replacing them would be.
    Thanks, yes the voltage should remain fairly consistant usually servers are rated to handle 100-120v on US electrical systems. But the amps may seem to vary especially while the system is idle or in a power saving mode. The equipment you suggest seems like a good product but I am actually trying to cut costs with this I was looking into something a little more inexpensive. Tell me what you might think of this utility?
    http://www.supermediastore.com/kilwateld...
  • 22 Answers
Is this a tower or Imac?
Is there a reason other then curiosity you need to know?
All power supplies have it labeled on them what they are if you need it.
Posted on May 05, 2008
  • Eric Pritchett May 08, 2008
    Not to over simplify things but the power supply AC input is 110 volts if it is a US system. The input supply shouldn't change much from that. I have used a monitor that I will link for you that I use in lab type settings. I use this to monitor the current ups and downs during a day in a lab to see if a 15 or 20 amp circuit will work better. I prefer to use 15 because if there is a spike it is a little safer then a 20 amp on machines. I hope this helps some
    http://www.acscout.com/servlet/Page?temp...
    Interesting little product you found there. My only questions would be is this for work or home? If it is for work and multiple devices would doing 1 device at a time be cost effective? For home purposes I can see many benefits of a device like that though. Plus since I need approval to buy new equipment might be a good tool to use to show a savings over time. Sorry thinking out loud there. Either way the tool looks like it could be a low cost solution to your problem.
How do i find the specs for an imac g5 with only a serial number
go to far left corner (apple logo ) pulldown menu about this mac click on it and then more info.
Thats it done
also you can go-on line and download Mactracker for more info
Nov 13, 2014 | Apple iMac G5 Desktop
I have a Mac osx g9 and IO don't know how to install bluetooth do I have to buy something or download it?
Go to
Finder » Applications » System Preferences
Under the Internet & Wireless section there is a Bluetooth option. Click on this.
Make sure both 'On' and 'Discoverable' are clicked.
Dec 25, 2010 | Apple Bluetooth Card (Rev. 3) for eMac,...
Power mac g5 shows terrible damage in tower from leaking they swear mom board is fine but its hard to believe. are any of the other parts usable for a g3 to g5 imac or g4 powermac or emac
None of the parts are usable in any other machine.
The coolant from a liquid-cooled G5 PowerMac is toxic. If your G5 is leaking, disconnect the power cord IMMEDIATELY. Flush any skin exposed to the fluid with water for at least 15 minutes.
If you want to glove up and extract your hard drive from the machine so as to save your data, do it carefully. Other than that, my recommendation is to bag up the unit and handle it responsibly as toxic waste, using the same guidelines your area uses for antifreeze.
Oct 31, 2010 | Apple iMac G4 Desktop
Looking for instructions on how to install blue tooth card into e-mac g4
Here ya go.
should give you what you need
[PDF] iBook G4 (Late 2004) Getting Started (Manual) File Format: PDF/Adobe Acrobat - Quick View
install one, see “Installing an AirPort Extreme Card or Additional Memory” on page 51. ... You can also find information on the Apple Bluetooth ...
manuals.info.apple.com/en/ibookg4gettingstarted.pdf - Similar
Jul 12, 2010 | Apple Bluetooth Card (Rev. 3) for eMac,...
How do I add more memory to my iMac G5, 2004
Apple has made a support guide for this: Apple Support Guide.
The memory you are looking for is going to be; DDR2 SDRAM / 240-pin / 533 MHz / PC2-4200
The support guide shows you how to install the RAM into the iMac G5.
Jun 30, 2010 | Apple eMac G4 Desktop
Imac g4 won't start but shuts down when apple logo appears on screen
Are you sure the iMac is really shutting down or just turning off the backlight? The tell-tale sing would be to let the unit fully boot-up (wait 3 minutes) and the press the button the apple keyboard that ejects the CD-ROM. If the CD-ROM door opens, you iMac is running with disabled or broken backlight.
The inverter circuit on the iMac G4 is known to be weak.
There could be another problem, though. The iMac G4 is also known to have weak internal power supplies. Here's how you can tell:
Hold down the CMD OPT "O" and "F" keys at the same time while pressing the power button. This will tell the iMac that you want to boot into the Open Firmware shell, bypassing the Mac OS X startup. If this works, your power supply is good, the inverter is good and you have a problem with your Open Firmware boot string. To fix the boot string, Power on the unit while holding down the keys CMD-OPT-P-R to zap the parameter RAM (PRAM) and reset everything to defaults.
If you were not able to boot into the Open Firmware shell, your problem is either a failed power supply or a failed screen backlight. The last possible culprit is your iMac could suffer from "Bulging Capacitor Syndrome", where a batch of iMac G4s, iMac G5s another electronics were fitted with a bad batch of capacitors. Eventually, the caps will rupture and cause irreparable damage to the logic board. Only way to verify this is to pull the unit apart and visually inspect. If you see little green or blue cylinders that seem to be bulging or oozing a thick oily goo, that's your problem. Only recourse is to shop around on eBay and look for a replacement logic board.
May 30, 2010 | Apple iMac G4 Desktop
Imac g4 dead
Hello, The power supply is part of the motherboard in the iMac G4, so it's hard to change it. The repair would certainly cost more than the price of your iMac. You can try to take off the small battery, and reboot it to see if it changes. To open the mac lay it down, screen on the table (on a t-shirt). Unscrew the four screws (they wont come out, so just unscrew them. Pull the screws and take off the silver plate. Then you'll have access to the inside. Good luck
Jun 12, 2009 | Apple iMac G4 Desktop
Imac g5 is not turning on. LED1 stays on. I tried resetting the SMU and it didn't work. LED2 flashes on and off making a chirping noise. What could this be
Hello, Sorry to hear you are having troubles,
Is this a 17” iMac G5, if it is, and I think it is, unfortunately, this iMac model was generation 1 of the all in one flat screen design and it's a bit of a Lemon... The hard Drive overheats the video card and the power supply. With time, these 2 elements burn out.
What you have sounds like the power supply. it's a $300 repair, but, it might not be a good investment for you, the new power supply won't last much more than the first one and your video chip won't last much longer....
Best put the money and put it towards a new machine.
Sorry bout that.
Apr 01, 2009 | Apple iMac G5 Desktop
Problem with Apple imac Power Supply
The most common problem with imac G4/800's are failing logic-boards. This will cause the mac to not power up at all giving the impression that the PSU is broken.
If however, you are indeed certain that the fault is with the power supply, they are available from many stores online
Power Supply for iMac G4 15" LCD (700 & 800 Mhz) 661-3184 614-0147
Dec 09, 2008 | Apple iMac G4 Desktop
Panasonic pv-gs150 mac connection
For Macintosh
OS:
Mac OS X v 10.1–X v 10.3
CPU:
iMac, iBook or Power Book G4, Power Mac G4 or
Power Mac G5
RAM:
64 MB or more
≥The USB equipment operates with the driver
installed as standard in OS.
Sep 30, 2007 | Panasonic PV-GS150 Mini DV Digital...
Apple eMac G4 Desktop Logo
265 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
