Question about Panasonic Computers & Internet
How do I replace the motherboard on a Panasonic CF-29
I need to replace the Motherboard on a Panasonic CF-29 and I have never done it before. Does anyone have instructions on how to do this?
    Problem Solver:
  • 17 Answers
If you are putting the same board in, it should be easy (see below). If you are putting a different board in, you will have to read the manual to make sure you have the correct connections.
- Remove power cable and all connections on back computer.
- Open computer and lay on side with MB on bottom and opened panel facing up.
- Remove any cards by removing the secruing screw on it. Label which slot you take them out so you can place back in the same way.
- Remove memory cards drawing a diagram where it/they came out. If there are more than one card and different, note which slot they came out of. Configuration is important in most systems.
- Remove cables going to hard drives, floppy drives, or optical drives. Leave the cable attached to each device but lable where it came off your MB.
- Remove fan assembly on CPU if it is in the way and unplug it noting where it was plugged in.
- Remove from 4 to 9 screws holding the board down and lift board out by pulling forward on the board so it removes itself from the back panel and then lift out.
- Swap the CPU over to the new board being careful not to touch the pins of the CPU to cause ESD damage. (Google it if you need to know what it is). You might want to put some more heat transfer gel on it to make sure the CPU cools properly. A lot of times that stuff dries up and won't cool your CPU properly.
- Install board reversing the steps above making sure the grounding prongs of back panel are not over the openings to the connectors.
Note, memory cards are usually keyed so you should not be able to put them in backwards but make sure you put them in the same slots.
- Try your 'smoke' test. If unit powers up and you have video, your on the home stretch. Check out your bios and ensure you have the latest by going to the manufacturer's website and looking up bios downloads and compare what you have to the latest bios. (This is only if you want to make sure your system it updated to the latest and greatest. Most people will not mess with it if it still works. Maybe that's good logic.) There should be directions there as to how to update your bios. Follow their instructions.
If all went well, you should be good to go. If you have a different MB, you will have to look up your connections at the manufacturer's site. The above steps should get you through the changeout process.
V/R
Wookie
Posted on May 06, 2010
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • Mar 10, 2014 | Panasonic Toughbook CF-30K (CF-30K3PAQAM)...
    ATV mounted CF 29 in Big Red cab blown motherbroad
    If your antenna is not grounded correctly as well as your PC power, you may be getting a loop of voltage through your controller interface trashing your motherboard.
    Jan 17, 2014 | Panasonic Toughbook 29 Touch (P/N...
    Sound card
    The sound system is part of the motherboard iirc.....Has your audio quit? (If it has no audio OUT, it could be the speaker OR make sure you didnt hit ALT F4 which kills audio out regardless of the level settings....dont ask me why I know :)
    Jun 25, 2013 | Panasonic Toughbook CF-29 Notebook
    Where is the fuse to the panasonic cf 29 laptop
    Here is the service manual for it. This should help
    http://www.scribd.com/doc/52162841/panasonic-CF-29-SM
    Sep 02, 2012 | Panasonic Toughbook 29 Touch (P/N...
    In the Toughbook CF-18 model, is it possible to upgrade the graphics/video card? If so, how is this done?
    No, the video chip is an onboard one, part of the northbridge chip of the motherboard. If the video has failed the entire motherboard will have to be replaced.
    Jun 02, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
    I require LAN drivers for my panasonic cf-29
    This depends on the specific model number:
    CF-29C/D -- Realtek RTL8139DL 10/100
    CF-29E/F -- Realtek RTL8139DL 10/100
    CF-29H/J -- Realtek RTL8139DL 10/100
    CF-29L/M -- Marvel Yukon 88E8053 10/100/1000
    CF-29N/P -- Marvel Yukon 88E8053 10/100/1000
    Dec 28, 2010 | Panasonic Toughbook CF-29 Notebook
    When I turn on my CF-29 it goes straight to a
    Have you tried hooking up an external monitor? If you hook it up and see video on that it's a screen issue. If you hook it up and it does the same white thing it's bad video on the motherboard.
    May 04, 2010 | Panasonic Toughbook CF-29 Notebook
    Need a motherboard for a cf 51. mine is a dl3up1481aaa. That number cannot be found. will anyother work in it's place.
    There's one on ebay right now ! check it out fast.
    http://cgi.ebay.com/Panasonic-Toughbook-CF-51-Motherboard-DL3UP1379AAA_W0QQitemZ360164329640QQcmdZViewItemQQimsxZ20090621?IMSfp=TL090621142002r28025
    Jul 14, 2009 | Panasonic Toughbook CF-51 Notebook
    On boot up a safeboot apears and asks for password i bought this secondhand and its been trouble from day one anyone out there please help also bios has had a password done as well so cant get into that...
    if you are able to open motherboard then simply remove CMOS bettry for 10 sec and put again then password will reset...if you dont open motherboard then ask me?????
    Apr 03, 2009 | Panasonic Toughbook CF-51 Notebook
    Cf 29 touchscreen
    The connection to the board should be under the panel with the speakers, at the top of the keyboard. (that's where it is on my cf72) Also check the connection on the touch screen by pulling the front case from around the screen. There are screws hidden under the small rubber bumpers on the lid.
    Jun 11, 2008 | Intel Motherboard
    Computers & Internet Logo
    2,363 people viewed this question
    Top Panasonic Computers & Internet Experts
    Oloyede Monsuru
    micky dee
    Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
