Question about Sirius Starmate ST2 Satellite Radio Receiver
The plug where the power cord plugs in seems to have a loose connection. I keep losing power to the unit. any suggestions?
  • 4 Answers
Resoldering the 4 leads on the power connector did the trick for me.
Posted on Jul 15, 2010
  • 55 Answers
Just try to change the ac, maybe it is the one that is defective, or if your suspicion is right open it and solder the loose contact
Posted on May 06, 2010
What would cause my electric range to lose all power when using the oven?
One thing to check is the power where it plugs in to the wall. Remove plug and look at male blades on plug. See if any are discolored or burnt looking. If any are replace the cord on stove and have the plug in wall replaced too. If they are discolored or burnt you must replace both parts. You also try to jiggle plug around while it's plugged in to see if that has any effect.
If everything seems ok at outlet, UNPLUG UNIT and remove cover over terminals where line cord connects to stove. Check for burnt terminals ans burnt wires. Also make sure screws are tight.
Oct 24, 2014 | Kitchen Ranges
Toshiba satellite A200-27Z power cord led flasing failure to post will try any suggestions
Have you tried another Cord with the EXACT same power specs? Remove the battery. Has the cord/charger/transformer been damaged? Has the AC jack been damaged? Due to pulling on the cord while plugged in? At the AC jack "wiggle" the plug a bit to see if the plug and AC jack are making a good connection or Loose. Sounds like a loose AC connection.
Jan 10, 2013 | Computers & Internet
Power plug on chair losing power
The problem may be that the power cord's internals were broken by keeping the wire plugged into the chair at a bad angle That damaged the connection. If this is the case, you may need to purchase a new power cord.
Try shopping online for a replacement or calling the manufacturer.
Jun 01, 2012 | Pyramat Sound Rocker Gaming Chair
Our magellan keeps turning off. the plug seem loose. could it be the cord or is it the battery and can it be changed
Check your power cord. You may be losing power at the plug. When plugged in it may be losing contact with the recepticle. The power indicator light initially comes on but, breaks contact and therefore stops charging the unit. If this is the case you can sometimes plug into an adapter and get a tighter fit.
Apr 25, 2011 | Magellan Roadmate 1200 Car GPS Receiver
Every few months the compressor will not come on. It will try over and over but will not start. At the same time, the light does not come on when the door is opened. I can unplug the power cord and plug it...
Hi!!
The lighting circuit and the compressor electrical circuit are independent from each other once they go past the electrical terminal block, (where the power cord connects to, on the back of the fridge).
For the description of the problem, it sounds like you have a loose power cord terminal connection at the block, a defective power cord or power outlet.
Try connecting the fridge on the other power outlet (if it is connected to a regular dual outlet ), some times the contactors, over time, tend to loose the grip on the power cord plug and the contact is lost, when you remove the plug from the outlet and plug it back in, restores temporarily the contact again, or, the plug itself can be defective and loses contact. Replacing the power cord and using a different power outlet (even if it is a dual) will let you know if that where the problem was. If that doesn't solve the problem, let me know and will do some more troubleshooting.
Good Luck and keep me posted.
Jan 10, 2011 | Refrigerators
I have a Gateway T-6330u notebook. I have had problems with the battery cord before where it plugs into the computer. A piece broke off from the battery cord and was stuck in the computer. I talked with...
Seems more like a problem with the power receptacle where you plug the power cord into the laptop.In order to fix this problem, you will need to disassemble the unit to get access to the motherboard & replace the power receptacle with a good one.
Dec 29, 2010 | Gateway T-6330U Notebook
Hi I have a acer aspire 1694WLMi laptop which doesn't charge fully. Also when the ac adapter is connected the screen keeps flashing between battery mode and ac mode.
The source of the problem obviously is either the AC power cord or the battery, or it could be a combination of the two. In terms of the symptoms you describe, it could be a faulty AC cord. This could involve a few possiblities: loose connection between the AC plug and the AC adapter unit, a loose connection between the mini plug (the part that goes into your laptop) and the AC adapter unit, or the AC unit itself could be going bad.
Not sure how intermittent the flashing between battery and ac mode is. If you're talking very frequent such as once every minute or so, I would be suspicious of either the plug (both AC and input to laptop sides) or the connections between the AC adapter portion and the plug. Not sure how long you've had the laptop and cord, but it is possible that the cord has somehow worn out. This wearing out can be accelerated if you often use the AC cord and there is tension on it.
One finally suggestion of course is to either try a new cord. You can often find them on e-bay and can even purchase used ones for a cheap price. If you do, you will then obviously be able to confirm that the cord was the problem. One might think or say the battery is not charging fully and is the problem. True, the battery may be a problem, but the root cause may be the cord.
I Fix It
Aug 14, 2009 | Computers & Internet
My window unit fell out of the window and hung by the power cord that was still plugged into the wall. I was able to grab the cord and pull it back up. I reattached the power cord and now every time i turn...
Its most likely is not the switch. It is most likely the cord though. Due to the excess strain on the cord it has probably cut through the rubber coating on the wire and connected to the frame and grounded the hot lead. Fix the cord and you may have it handled.
Jun 15, 2009 | Frigidaire FAX054P7A Wall/Window Air...
Unit keeps losing power. Cord has power light and
I had the same problem. It was the pin inside the **** clamp that was broken. As I wiggled the plug in the unit the pin would dislodge. eventually the pin got lodged in the 12v power cord.
May 16, 2009 | Magellan RoadMate 700 GPS Receiver
Restarting while in use
Mine just started doing the same thing. I took apart the speaker power cord, but don't see anything wrong with it. I thought I saw the unit turn off/on one time when I moved the cigarette plug back and forth, but as I said the wires are fine. I have the power cord apart right now and have 12 volts hooked up to the wires directly and the unit has been sitting here for 30 minutes without resetting.
Oct 17, 2007 | Garmin StreetPilot 2720 GPS Receiver
Sirius Starmate ST2 Satellite Radio Receiver Logo
261 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
