Question about Ingersoll Rand SS3J5.5GH Wb Ir Portable Air Compressor 5.5HP Honda Gasoline Engine Single Stage 8 Gal Twin k Wheelbarrow
Starts fine pressures up to 45psi then air vavle pops and compressor turns offs. it s a 5.5 honda wheelbarrol compresor that i bought new four yrs ago.
    Problem Solver:
  • 18 Answers
Maybe the gauge is bad. Try a new gauge.
Posted on Jul 10, 2010
POP OFF VAVLE ON HEAD KEEPS POPPING UP
The over-pressure relief valve may be defective if the valve is opening before the desired tank pressure is reached. If not, then the shut-off pressure adjustment (if there is one) may be set wrong. You'll need to find out from the manufacturer exactly what static tank pressure the compressor is designed to provide and then determine if it is working correctly. If so, then the relief valve might be defective. DO NOT attempt to defeat the relief valve under any circumstances - it can result in compressor damage or a dangerous tank failure.
Oct 06, 2014 | Porter Cable 175 PSI 80 Gal. Oil-Lube...
I have a 2003 chevy avalanche n my ac does not blow any cold air. The compressor keeps cutting on n off every couple of seconds. I bought some freon with the gauge n its reading 45psi when it turns on but...
new pressure switch ?, it sounds like your compressor may be going off on high head pressure, or something similar like a clogged line. That is about the best thing I can think of unless the compressor itself is having internal problems. If its cooling, then it may be a temp sensor on your coil, or line if you have one.
Aug 25, 2017 | Cars & Trucks
Hooked up new 4 wire fan 2 condensor with a new 2 cap fan runs fine but no compresor?installed as was told with nothing runnng 2 the new cap but the brown wires but compresor isnt kicking on
The compressor could be bad there is two ways to tell with an ohm meter check each lead off the compressor and to ground for continunity or a megometer . You can always try a hard start kit. It is a super capicator that multiplies starting voltage. Have you checked all connections? There might be a low\ high Pressure switch in the referigent lines if that is bad it won't allow the unit to start. Also is it a heat pump or straight a/c the heat pumps have circut control boards in the unit that control everything
Aug 07, 2011 | Goodman CLQ36AR49 Air Conditioner
Air compresor Craftsman 921.153101 it spound like is one but it wont run at all. It sounds like the motor is stuck
if its belt driven ,unplug it(safety first)remove the belt and try to turn the pump by hand.if the pump turn plug it back without the belt. and try it .if the motor doesnt run.check the contacts on your pressure switch.if they are ok and try again.if not you need a new motor.if the motor ,the pressure switch contacts,and the pump are fine.put the belt back back on bleed your tank to zero with an air gun and try to run it.if it work well till it cuts of check if your bleeder release air.you might have pressure stuck in your pump.the compressor needs to release pressure for a soft start.hope this help!
Apr 17, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
Cdewalt d55133 compressor. compresor fill air tank but when engine try to start again humms and the breaker come on and wont start
It sounds like the valve that releases the pressure out of the pipe that runs between the compressor and tank is not working once the tank is full and the motor automatically cuts off. This valve is attached to the Pressure control switch that switches the motor On & Off and usually has a small pipe going to it. You know the valve is working by the sound of a short spurt if air being released when the motor cuts off. If the valve is not releasing this air the compressor is trying to start under full load which the motor is not capable of doing, hence the humming and popping of breakers due to a current overload as the motor tries to start.
Aug 25, 2010 | Garden
Duo therm air conditioner that the compressor will not start
Hello,The freezestat should be closed.Try jumping that out .
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
I HAVE A PIECE OF EQUIPMENT THAT RUNS AT 75 PSI. I NEED TO BUY A COMPRESSOR THAT WILL HAVE A DUTY CYCLE OF 50%. HOW CAN I SELECT WHAT SIZE COMPRESSOR I NEED?
That is an extremely high pressure. I would firstly check to make sure that THAT is what you need, then MOST compressors have a regulator where you can adjust the pressure required.
It is not so much the pressure you need as the STORAGE of air that you need for a pressure that high. MOST tanks are around the 20 or so litre. To utilise a tool requiring the pressure of 75PSI I suspect you would need a tank of somewhere around the 2-300 litre size or maybe even bigger. But first just make sure that you DO need the 75PSI you mentioned.
Feb 10, 2010 | Air Tools & Compressors
Circuit breaker on my air compresor pops
does the breaker pop with an empty tank?
if so then you need to see if the unit turns free,try running the m/c disconnected from the pump unit,my guess is that your drive motor bearings or internal windings are at fault
hope this helps regards ian
May 03, 2009 | Air Tools & Compressors
Compressor tries to keep running pops the breaker
Inside the control unit is a spirally spring like diapragm, it holds a ball bearing that should shut off the compresor at max pressure. The ball bearing has probably fallen inside the tank. Now it won't shut off so it tries to keep runniong. The back pressure cause an overload on the compressor motor and so blows the breaker. You need a bigger ball bearing or a replacement diaphragm. However you cannot get parts as there is a safety recall see this site: http://www.cpsc.gov/cpscpub/prerel/prhtml02/02108.html
Apr 02, 2009 | Craftsman Air Tools & Compressors
Ingersoll Rand  SS3J5.5GH Wb Ir Portable Air Compressor 5.5HP Honda Gasoline Engine Single Stage 8 Gal Twin k Wheelbarrow  Logo
151 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
