Question about Baby Trend Expedition LE Jogger
How can i fix the front alignment on a baby trend jogging stroller? the stroller goes to the left instead of straight. I bought it used for a good deal, everything else on it is great, just it pulls to the left and it makes it hard on my arms to push. How can i fix it at home?
SOURCE: Baby Trend Expedition Jog Stroller
http://www.babytrend.com/download/2007061310319100A_Instructions.pdf
Posted on Apr 06, 2008
  • 9 Answers
SOURCE: baby trend expedition double jogging stroller
No but if you just sort of push on one side of the handle bar it will pull it to turn without lifting the front.
Posted on Oct 25, 2008
lingIT
  • 105 Answers
SOURCE: Baby Trend Jogging Stroller - Need Replacement covers
they have available parts as per their website. you can visit their nearest store branch or order online
http://www.babytrend.com/products_detail.php?CategoryID=0005.0002.0000.0000&LampID=948
Posted on Apr 30, 2009
SOURCE: How do I adjust the seat to upright position in
On mine, I push the seat forward to the position I want, then there is a string behind the seat at the top with a toggle on it that I pull until it's tight and push the toggle up as close as I can to the seat to secure it in place.
Posted on Sep 03, 2009
trials78
  • 28 Answers
SOURCE: The back rear tires will not keep air in them. How
More than likely there's a leak, maybe small but enough to cause a flat.
As for tubes your local bike shop may carry the 12" or the 16" depending on the stroller make and model. Check the side of the tire to see if you can identify the size, if not the stroller manufacturer or the site should give you more information.
The tires with these jogging strollers come off fairly easily with any regular bicycle tire levers. Although it's possible to take them off by hand, if it's difficult any bicycle shop would carry standard bicycle tire levers. I personally recommend the life time warranty tire levers by Pedro. They are very strong and designed to take off some of the beefiest mountain bike tires.
It would also be good to have spare tubes. You can find bulk tire tubes on eBay for cheap!
Posted on Nov 07, 2009
When I rollarblade, the front wheel shakes a lot.
I bought this stroller at toys are us. And the front wheel warbles when we are not going straight. The inner part is not right. It isn't even a year old. What can be done.
Jul 06, 2012 | Baby Trend Expedition LE Jogger
I have a baby trend phantom jogging stroller, the front wheel vibrates alot unless its locked in to place, any suggestions
try to screw it well. or maybe some one put a big weight on it and the tube were the wheel is on has bended.
Jul 30, 2010 | Baby Trend Phantom - Black/ Grey Jogger...
Baby trend double jogger stroller pulls to the left when front wheel is in locked position AND front wheel wobbles (cannot push through it)when on swivel.
Hey! I just fixed my shaking wheel! There is a red lever above the swivel wheel. I pushed it up. And guess what... I can jog with my stroller!
Jul 03, 2010 | Baby Trend Expedition Double Jogger
On amazon for sure... take a look here Allen Sports Bike Trailers Joggers. I hope this was helpful. cheers
Mar 27, 2009 | Baby Trend Expedition LE Jogger
I just need a part
Any bike shop or better yet walmart
Nov 20, 2008 | Baby Trend Expedition Double Jogger
Baby trend expedition double jogging stroller
Aug 25, 2008 | Baby Trend Expedition Double Jogger
Stroller pulls to the left
It's a wheel alignment issue - I had the same issue & my husband fixed it. Try removing the front wheel & reattaching it. If that doesn't solve the problem, keep adjusting the front wheel slightly until the stroller no longer veers.
Jan 10, 2008 | Zooper Cool Zone Buddy Stroller
Stroller pulls to the right.
The following is from the instruction manual for the Expedition LX. It should be very similar to the Expedition LE.
"Stroller pulls to one side:1. The stroller is sensitive to the air pressure in the tires. If the rear tires do not have equal pressure, the stroller will feel like it is pulling to the side with the tire with the lower tire pressure. Check that the rear tires have the same pressure. Add air pressure to a maximum of 25 pounds using a bicycle style hand air pump.2. The alignment of the front wheel of the stroller can also cause the stroller to pull to one side. The stroller is designed so that the front wheel can be adjusted to correct for any alignment problem. Page 3 of the instructions
shows an expanded view of the front fork assembly. To align the front wheel, first loosen the wheel via the quick release handle as in step 2 of the instructions. Grab the front wheel directly in front of the stroller and push the wheel in the opposite direction of the pulling problem. You will notice that the axle will move within the slot on the fork. Move the wheel to the side a small amount. Retighten the quick release handle. Give the empty stroller a push across an empty smooth surface (let go of the handle) and note if the stroller now runs straight. Re-adjust the axle a small amount at a time until the stroller runs straight. Please note that a very minute
movement of the axle will affect the tracking of the stroller. Once you have aligned the front wheel, you can mark the holding plate position with a marking pen if you detach the front wheel on a regular basis. Please note that the hole in the fork is designed to allow the stroller to be adjusted to pull to the right, go straight, or pull to the left. If you continue to have difficulty with tracking, please call our customer service department at (800) 328-7363 for assistance."
Mar 30, 2007 | Baby Trend Expedition LE Jogger
Wheel alignment
Just take it to your local bike shop. They should be able to fix it. The wheels/tires are basically small bicycle wheels/tires.
Mar 29, 2007 | Baby Trend Expedition Double Jogger
Baby Trend Expedition LE Jogger Logo
117 people viewed this question
Top Baby Trend Baby Gear Experts
Jennifer Rock
Jennifer Rock
Scott Jelt
Scott Jelt
Mike
Are you a Baby Trend Baby Gear Expert? Answer questions, earn points and help others
