ADF rollers go up and down.
I have a Conon Laser Class 710 fax machine. The rollers in the ADF move up and down about 5 to 6 times when a document is placed in the feeder and the start button is pushed. After the 5 or 6 times the rollers stop and the error alert sounds. Can you tell why this is happening and how to resolve the problem?
  • ffee1 May 11, 2010
    Here is your solution
    » Brother
    » Canon
    » HP
    » Lexmark
    » Panasonic
    » Samsung
    » Sharp
    » Other
    a
  • 1,219 Answers
Did you try to clean the rollers?
Posted on Jun 25, 2010
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Canon 810 making squeky noise when pulling pages in during faxing and when making copies.
open the ADF clean properly the paper take up roller and the separation pad with alcohol.
Oct 26, 2010 | Canon Laser Class 810 Plain Paper Fax
Hp 1010 fax- Receiving end has an area approx 4" header that is blank and moves the document to 2 pages. Happens on my end when I copy.
adf rollers need to be replaced the doc is late going in to the adf that is why it has a header of blank thanks quikship
Nov 05, 2009 | HP 1010 Plain Paper Inkjet Fax
Document roller up & down
On the Canon copy machines when this happens, normally it is a bad wiring harness....sounds like your switch is good, but the signal for 'roller down' is not reaching the main board, thus it repeatedly cycles up and down. Try continuity test on the wiring harness from switch connector end to main board connector end...it's a pain to do this, however, when you find the open wire connection, it's worth it.
Oct 28, 2009 | Canon Office Equipment & Supplies
Canon image class 6550 adf area document to long error
You orginal feed rollers may be worn out. when this happens, the paper slips and the machine thinks the paper is too long.
You need to have the ADF rollers replaced.
Jul 06, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Paper will not feed via ADF in Canon laser class 510 fax. keeps saying reset document when we try to fax or copy using either ADF or scanner. Briefly received error E337 (or could have been E377).
there is probably something in the paper path, double check and make sure no piece of paper is in it.
there is a small lever in the adf this is the sensor it should be able to move freeely and have a spring action, is it stuck?
are the guides set, and set to Letter?
Aug 26, 2008 | Office Equipment & Supplies
No copy and send fax from adf unit
First try reseting the unit by holding the * key and the enter button and the same time turn it on until it starts beeping. This will rest the machine. If this does not work. you need ADF rollers the can be purchased for 20 to 25 bucks
May 08, 2008 | HP LaserJet 3380 All-In-One Printer
CANON PC-1080F feeder error message
Well, open the adf and see if there's anything jammed in there. While you are at it, clean all the white out off the rollers and the scan glass. Then make sure the ADF cover is snapped shut properly
Feb 27, 2008 | Canon PC-1080F Plain Paper Laser Fax
43 people viewed this question
jasbo
jasbo
