Question about Keurig Elite B40 Coffee Maker
I need a new replacement k-cup portion pack and filter assembly
My k cup portion pack and filter assembly cracked and I need to find a replacement part for the Elite B40 keurig brewer.
    Sniper:
  • 92 Answers
Replacement parts are hard to come by but the portion unit can be bought on amazon.
My filter was metal, so I'm not sure about something cracking...
ebay has many people selling broken units... good for parts...
Posted on May 06, 2010
  • 25 Answers
I know of this great site that sells keurigs products and PARTS check it out maybe this will help you find what you are looking for http://stores.ilikenew.com/-strse-Keurig/Categories.bok
Posted on Mar 17, 2011
Would like to purchase k-cup portion pack housing for
the b-40 model keurig coffee brewer.
Posted on Jul 01, 2011
How come the water from the water reservoir doesnt go up that is why no coffee goes out from the K-cup portion pack assembly housing?
Are you saying that you have this situation?
1. you have a K-cup machine that stopped working.
2. water is not being sucked up out of the water reservoir.
3. and no water is being pumped through the little K-cup
I don't know the answer, but am just trying to clarify your question, so that those who MAY know can better understand what you're asking. So, does that correctly describe your situation?
Mar 05, 2015 | Krups Small Appliances Espresso Machine
I have a 1992 Buick Park Avenue that runs rough (misses) till it warms up and then just occasionally. Changed fuel filter, but mechanic seems to think it is wires on the ECM Coil Pack causing problems. ...
If you are referring to the this wiring or hi-tension wires, you will have to replace them. After market parts sell them in pack. If you are referring to insulation on the coil pack itself you will have to replace the assembly. For the ordinary wiring you may replace each of the wire or make some splicing and replace portions of the wire. You will need to solder it and insulate the solders with electrical tape.
Jun 16, 2011 | 1992 Buick Park Avenue
When using MY K-Cup reuseable coffee filter, the coffee comes out the drip hole plus water comes out of the bottom front of the K-Cup Portion Pack Assembly Housing splashing down onto the counter. I made...
I googled this problem for 3 days. I was reluctant to try anything that would screw up my machine, as I have been very happy with it, except for the re-usable filter performance.
I wiggled the o-ring washer around top sharp thingie by maybe 1/8 inch and that fixed it. K-cups are running normal as well.
Jan 30, 2011 | Keurig 5048 My K-Cup Reuseable Coffee...
How do you empty it?
There is a black clip at the top of the dirt cup which holds the dirt cup in place on this vacuum. Pull back on this clip with one hand and with the other you will be able to remove the entire dirt cup assembly. Once the dirt cup assembly is off remove the lid, and take the bottom portion to the trash can and dump. Tap the side of the cup slightly to remove excess dirt. Romove the dirt cup filter inside and do the same. Replace the fiter and the lid and put it back on to the machine. You should replace the dirt cup filter every 6 months to a year. Part is below:
F1 Dirt Devil Replacement HEPA Filter Style F1, Dirt Devil Part 3-JC0280-000 Cost $ 15.95
Apr 27, 2010 | Dirt Devil Featherlite Bagless Vacuum...
K-Cups disappointing
I had same problem and called Keurig. They advised me that the gasket in the upper portion, where the top needle is needs to be brought down about half way, almost even with the bottom of the top needle. Be careful not to poke yourself. I brewed a cup with the resuable filter assembly and it worked great. It should stay in that position until you use an actual k-cup. When using it will push the gasket back up, as it needs pressure to puncture the hole. To go back to the resuable filter, you will need to lower the gasket again. She advised me that they are working on a fix for this issue and will notify you of any replacement parts, as long as they have your current contact info.
Feb 06, 2010 | Keurig 5048 My K-Cup Reuseable Coffee...
Bissell easyvac filters
Replace Filter
As you vacuum, dirt and debris are deposited in the Dirt Cup
while air passes through the filter before being returned to
the room. This process enhances the vacuum path while
dramatically reducing dust, dirt, and potential allergens from
the air you breathe. Replacing the filter periodically enhances
vacuum power and air quality. To replace the filter:
1. Remove the Dirt Cup.
2. Grasp the filter frame and pull it straight from the Cup.
Empty the Cup.
3. Replace the filter. Push new filter into place at the top of the
Cup, place the small tab at the bottom of the Cup into the
slot at the bottom of the Canister cavity, then press the upper
portion of the Cup into place until the lock button snaps
into place. Use only BISSELL Style 6, #32047 Filters
[package of 2] in your BISSELL EASY VAC™ Model 3101-0.
4. EASY VAC™PLUS Model #3102-0 features a high efficiency
3M Filtrete™ Filter. To keep your cleaner operating at peak
efficiency and to remove irritating allergens from your
home, you should change the FILTRETE™ filter every six
months. Use only BISSELL Style 6, #32046 Filters [package
of 2]. The cup-shaped filter lifts out from the top of the
Dirt Cup, and the new one fits into place.
You may purchase these filters
by calling
BISSELL Consumer Services
1-800-237-7691
Monday - Friday 8 a.m. — 7 p.m. EST
Saturday 9 a.m. — 2 p.m. EST
or from the BISSELL website —
http://www.bissell.com
Jun 29, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
Missing black portion pack assembly housing
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://stores.ebay.com/Igotsweetdeals
They have every Part for Keurig b30, b40, b60, b70, and b77. If it’s not listed currently and they can have it posted the same day! Even K-cup holder assemblies and water reservoirs!
Nov 22, 2008 | Keurig Special Edition B60 Coffee Maker
Keurig Elite B40 Coffee Maker Logo
683 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
