I have an HP Mini 1137 NR that I want to return to original factory status. I have the OS and driver DVD's but no DVD or CD drive on the unit. How can this be accomplished?
  • 5 more comments
  • gregg555 May 05, 2010
    Is it possible to use a DVD drive from a desktop instead of purchasing a USB device just for this application?
    OR Can you tell me how to make a flash drive bootable?
  • gregg555 May 06, 2010
    Geeze,
    Thanks for your help to this point, I have created a bootable flash drive and copied all the files from the HP Recovery OS disk to it. I have booted the HP Mini to the flash drive and I have both an A & B Drive available. The B drive contains all the files i copied from the OS disk so I tried to run setup.exe from the B drive and I get the error (This program can not run in DOS mode).
    What am I missing to get the windows setup going so I can format the drive....etc?
    Thank you
    Sorry to have made you explain all the stuff about how get the pc to boot to the flash drive. I used the FreeDOS example you suggested in the video earlier and had no trouble getting the PC to boot to the FreeDOS on the flashdrive.
    The problem i am having now is that I can't get the Windows setup to load from the flash boot.
    I can see the setup.exe file on the B drive but when I try to execute it I get this error: (This program can not be run in DOS mode) How can get the windows set up to run from the pc that has booted from the flash drive?
    thanks
  • gregg555 May 07, 2010
    Thank you for your suggestions, but I trying to avoid the purchase of the external drive for this one time use. I do know anyone who has one to borrow, and the reason I am reinstalling the OS on this machine is because it is infected with a virus that will not allow internet access, so downloading from the internet is not an option.
    I was really hoping that there would be a way to run the setup from the flash drive, I guess what you are saying is that there is no way to accomplish that feat?
  • gregg555 May 10, 2010
    This was the ticket, worked great uintil the install was finished. Now I have a message I'm not sure how to handle. The error message "Windows could not start because of a computer disk hardware configuration problem. Could not read from the selected boot disk. Check boot path and disk hardware"
    Further it goes on to say, "Please check the Windows documentation about hardware disk configuration and your hardware reference manuals for additional information"
    Any ideas?
  • gregg555 May 11, 2010
    Many options were received and all were helpful as I worked to a solution for this issue,
    Thank you
    Thanks you, the issue has been resolved, I do not see the usual button to accept the solution, so perhaps this comment will suffice.
    Thank you
  • 493 Answers
1. To perform a recovery with the recovery discs, you will need an external optical drive (purchased separately). For the manual of your device click here. Maybe you can borrow from a friend.
You can use RJ-45 to USB connection adapter to connect an external DVD drive.
2. If you want to install Windows XP Pro from internet (if you have CD key) you can download the full XP Pro software CD from here which I uploaded for you.
Then you do not need external DVD drive and your DVDs. (only connection to internet.)
(Or upload your DVD to internet from another PC and download to your PC from internet :) )
Hope this helps.
Good luck
Posted on May 07, 2010
  • 2 more comments
  • Ibrahim OKTAY
    Ibrahim OKTAY May 07, 2010
    You may try this link to make a bootable USB installer.
    Here is the another link for your info.
    Hope this helps.
  • Ibrahim OKTAY
    Ibrahim OKTAY May 10, 2010
    Hi Greg,
    OK, The solution is written in this link of Microsoft.
    If you can not do I will try it in my computer and try to explain you in simple way to solve it. (Editing boot ini file and setting the hardware configuration)
    Normally it is very easy but not to have the DVD/CD driver makes it hard. But you can do it anyway.
    Best
  • Ibrahim OKTAY
    And also did you try this without booting from USB:
    Try to log in Safe Mode (one of the selections). Press F8 during startup, Select "Last Known Good Configuration" option ( This option starts Windows by using the previous good configuration. Then install required drivers. And restart. This may work.
    (The F8 key may be different in your computer such as F2 etc.)
  • Ibrahim OKTAY
    Ibrahim OKTAY May 11, 2010
    Thank you my friend.
    Best wishes.
  • 10,515 Answers
You can install Programs from USB Flash Drives or External HDDs, or download the Trial program from the internet, and type your FULL VERSION product key .
And you can REINSTALL WINDOWS from a USB FLASH DRIVE or eHDD if you know how to make it a BOOTABLE DRIVE and know how to put the correct files on the drive .
You can get an External USB CD-ROM Drive and use that to install programs from Discs or to reinstall the OS as long as it is recognize by the BIOS and is set as the first boot device .
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 05, 2010
  • 3 more comments
  • taran_2005
    taran_2005 May 05, 2010
    Thanks for your response!!
    No, it is not Possible as for every DVD Set Up, there are Different Drivers, Compatibility and some other minimum requirements.
    USB being the best for the Model that you have. Many people are using the same method.
    For making the Flash Drive Bootable, you could Follow ;-
    http://www.bootdisk.com/pendrive.htm
    http://thepcspy.com/read/bootable_usb_fl...
    I have some Video's for you.
    The Above one are Generic Videos .
    Hope i helped you.
  • taran_2005
    taran_2005 May 06, 2010
    Booting from the USB flash drive
    Now that you have formatted your USB flash drive and installed
    the boot files onto it, the next thing that you must do is to configure
    your PC
    to allow you to boot from the flash drive. This is all done through the
    computer's BIOS Setup. I can't give you specific instructions for this
    part,
    because every computer is different. I can give you a few pointers
    though.
    You can access your computer's BIOS by pressing a specific
    key immediately after you turn the PC on. The key varies, but it is
    usually
    either [F1], [F2], or [Delete]. Once you are in the BIOS Setup, you
    should
    verify that all of your computer's USB options are enabled. This might
    include
    things like support for legacy USB devices or support for USB 2.0. If
    there is
    a time out setting for USB devices, you should set it to the max to
    insure that
    the system doesn't time out while waiting on the USB device to boot.
    Next, find the section on boot device priority. Normally, a
    USB flash drive (which is usually listed as USB-HDD, but may be listed
    as a
    removable device) will have a very low boot priority. If the USB flash
    drive's
    boot priority is lower than the hard disk (listed as HDD) then the only
    time
    the computer would ever boot off of the USB flash drive is if the system
    were
    to fail to boot from the hard disk. You must therefore rearrange the
    boot
    device priority so that the flash drive has a higher priority than the
    hard
    drive.
    Hope i helped you.
    Thanks
  • taran_2005
    taran_2005 May 07, 2010
    I read your Comment. I guess that would be the Only Option. It's very RARE that, you would get this Error Message. This Error Message means that you need to Completely Reinstall a Window Set Up. You need to have a Bootable Disk.
    http://support.microsoft.com/kb/240251
    Hope i helped you.
    Thanks
  • taran_2005
    taran_2005 May 11, 2010
    I am Sorry, is that a BUG? Because the Accept button should be there.
    If you still do not see that, Revert and i would be able to Report the same.
    Thanks and i am Happy that we were able to Resolve your problem.
    Take Care!!
  • taran_2005
    Thanks!!
    I checked and the Solution given by the Expert has been Accepted.
    Thanks!!
Hi, I have a HP mini 1000, running windows XP, how can I reset it to factory?
If you purchased it from new, you will have the XP installation disc. Place the disc in the DVD/CD drive. boot from it and choose fresh OS from the menu. That will place a new OS of XP in your machine.
You will lose all your programmes and data. All must be reinstalled afterwards.
Aug 20, 2016 | HP Mini 1000 XP Notebook
How to get driver for cd dvd unit
The optical disc drivers are part of the OS. The available drivers and software for Windows Vista, the original OS for the DV6748us are here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&product=3648284 . Select your version and click Next.
Windows XP and the subsequent versions of Windows all had the drivers for internal optical drives and most external drives in the Plug and Play control. You may need to go to the Device Manager and check the device status then manually update the driver. (For Vista, click Start > Control Panel (in the right hand column, then under Hardware look for the Device Manager link.) Expand the section for optical drives and look for a triangle with a red x or a yellow exclamation point. Right click on the device and click on the Update Driver button. If that doesn't work, try uninstalling the driver then shut down the computer. Check if Windows loads the driver correctly when you reboot. If you continue to have problems, the drive or cables might be bad. Consider getting a new optical drive (slim if you want to stay with an internal drive).
I hope this helps.
May 08, 2014 | HP Pavilion dv6748us Notebook
My daughter has a C551 NR running vista. The CD\DVD Rom stop working in Vista so I used an external CD drive to install Windows 7, works great. . I ordered a new drive upon HP recommendation 435778-001....
should recognize the cd rom /dvd unit automatically
lower picture is of the c300 cd unit
anything look different from the original ............lowest picture
CRX880A Compaq Presario C305LA C508US C551NR Optical Combo Drive CD-RW DVD- ROM
Apr 17, 2017 | Compaq Creative Sound Blaster PCI 128...
My HP G70-258US (Vista OS) hard drive will only run the computer in Safe Mode. The drive has failed the S.M.A.R.T. I have replaced the drive. After reinstalling the HP software on the new drive and...
i would advise a different os than vista but you can put the old hard drive back in run it in safe mode and by a cheap external hard drive case and transfer the files for the operating system to the new hard drive and then switch the drives back out
Mar 25, 2011 | HP G70-250us Notebook
_nec cd-rw nr-9300a stops working after eject (pc pauses very long for shutdown) in windows 7 but it operates well in windows xp
you might need to update the drivers for windows 7.
here are some other things you might try
make sure that the cd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
you only need to do this if you cant see your drive in my computer/windows explorer
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 24, 2011 | NEC MultiSpin NR-9300A (NR-9300A) CD-RW...
Dear sirs, I have been using an LG Portable Super Multi Drive GP08NU20 but suddenly my portable HP Mini 1000 (with OS Windows XP) is not recognizing it. When I go to "My PC" is not even...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 17, 2010 | LG GP08NU20 DVD±RW Burner
How to factory restore my compaq presario f700 with no CD-ROM
It depends on which OS and software came with the computer and the state of the computer. (In all cases do not use the Microsoft System Restore. This will return a computer to the last known good state (revert to a prior version of the registry) but not to the factory installed state.)
To do a recovery without starting Windows:
Some Vista and Win7 machines came with HP Recovery Manager. Press F11 during bootup (BIOS prompt) then if the hard drive is accessible, the Recovery Manager will start. Follow the on-screen directions. (If you changed the OS from originally installed version or repartitioned the drive, this is not available.)
For all other OS and recovery software options, you will need an external (USB) optical drive. The preferred option is a R/W DVD drive to create the recovery media yourself. (HP will send you recovery discs for a fee if the machine is under warranty.)
If you can enter Windows, click Start
Sep 25, 2010 | HP Compaq Presario F500 F700 and G6000...
HP PAVILION a6000n with lightscribe supermulti drive / cd writer---windows vista :: does not recognize dvd disc when inserted
If it fails to recognize and CD or DVD that's inserted you will need to reinstall the driver for your LightScribe. The factory drivers for your system can be found here:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=3548643
If it fails to recognize just one CD or DVD, chances are that the disc is defective.
Dec 02, 2009 | Cars & Trucks
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
