Question about Craftsman 8.50 Torque Rating Dual Rotating Tine Tiller
Craftsman rototiller mod. # 917-294260 won't go into gear
Runs but can't get it into gear
    Sniper:
  • 53 Answers
Try rolling it a bit. Sometimes the gear doesn't fully mesh correctly. As you try to shift push or pull the tiller juuuust a bit back and forth and try to shift as you do that see what happens. Or go into neutral and rock it then try again.
Posted on May 06, 2010
I need manual for 5 hp rototiller model 917293200
HP does not make rototillers! If it is a craftsman you can go to the sears website and get one.
Apr 16, 2017 | HP Garden
Where is filler plug on RT-5 rototiller gear box
I will research this. This is a Craftsman rototiller, correct?
Mar 09, 2016 | Cars & Trucks
I have a craftsman lt 1000 riding lawn mower and it runs, but it won't go into gear it goes into gear, but clutch won' engage the gear.
Look under the mower to see if the drive belt has come off or broke. It is the belt that runs from the bottom of the engine to the rear axle.
Oct 01, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Rototiller wonts change gears
Try rocking the wheel as you try to shift.
Apr 30, 2010 | Craftsman 8.50 Torque Rating Rear Tine...
Sears rototiller wheels locked up engine runs great
After taking the transmission/frame apart, the drive chain for the tires broke and wedged in the case. I cleaned the rest of the gear box and washed all of the gears and sprockets. Ordered up the chain, gasket and grease. I re-installed and greased all of the pieces and reassembled the case. I used a marine wheel bearing grease for the water resistant properties. I installed a zerk fitting right over the shifting lever. This should help keep the grease on the top end of all the gears. After a few hours it is good to go and works just like new.
Aug 20, 2009 | Craftsman Garden
Craftsman mod. 944.602521. Wont go into reverse?
mower will not shift gears, after being stored for winter. Old mower, but always stored indoors
Aug 17, 2009 | Craftsman Garden
My Sears rototiller model 917293310 is in neutral. It won't shift into any other gear. It starts just fine.
It could be the fork shifter of bracket inside that broke. Check her to get better idea and for parts
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917293310&productCategoryId=1508200&brandId=0247&modelName=TILLER&diagramPageId=00004&componentDescription=TRANSMISSION&documentId=P8120018&backToLink=Return%20to%20Sub%20Components%20list
Jul 18, 2009 | Craftsman Garden
Rototiller won't engage into gear
You will need to split the gear case if iam not mistaken it has chain drine the chain links break and you have to replace them
May 09, 2009 | Garden
Craftsman rototiller 3 5 model 917 299130 leaks
Sounds like you are speaking of the float bowl.
It should not have a hole in it.
You could purchase the part from Sears or a small engine shop.
If it were mine, I'd remove the bowl, clean it, and patch with a gasoline impervious material such as JB weld.
Apr 05, 2009 | Craftsman Garden
Rototiller transmission
I am having transmission problem (loud noises). I am looking for a repair manuel for a roper rear tine tiller. Model RT150GR chain drive.
Mar 27, 2009 | Craftsman Garden
Craftsman 8.50 Torque Rating  Dual Rotating Tine Tiller Logo
752 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
