Question about Maytag Atlantis MDE6400AY Electric Dryer
Makes a loud squeaking noise when drum is turning
  • 48 Answers
The felt on the front of the drum is probably worn out or the bearing on the rear of the drum is getting bad.
Posted on May 05, 2010
  • 833 Answers
SOURCE: When drum turns, it makes a loud squeaking noise.
Pil...this might be a dozen different things. It might be a slipping belt...either on the motor or on the drum. It might also be a dry bearing. Or...it might even be some sort of object that fell between the drum and the housing. With the power off, remove the back of the unit. Turn it on and listen but don't touch anything with the power on. You might be able to do this yourself.
Posted on Dec 18, 2007
Illeagle
  • 525 Answers
SOURCE: dryer squeak
Your issue is as follows;
"My G. E. dryer make squeaking noise when the drum is turning. However, it only during so, when load with cloths."
Based on the information provided above, I am unable to access my database to provide you with exacting information. You did not provide a valid model number, however, I have provided some common solutions to help guide you in your search.
My Solution is:
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Following the link below will provide some information on G.E. dryers.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=784658&PPStack=1
Following the link below shows disassembly procedures for most G.E. models.
http://www.repairclinic.com/0100_20.asp
Rear drum bearing: Most common failure Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
In an effort to improve the quality of my answers, please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 17, 2008
  • 132 Answers
SOURCE: dryer making loud squeaking noise
Replace all the drum rollers.
Posted on Mar 26, 2009
SOURCE: how to stop squeaking noise on dryer
The roller bushings/bearings and the motor need lubricating.
If you want help with how to do this, let me know.
Posted on Apr 30, 2009
  • 46 Answers
SOURCE: squeaking dryer drum when operating
sounds like you need to adjust the motor that turns the drum to tighten the drive belt..... you do this from the back or bottom...
Posted on May 25, 2009
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
My dryer is making a loud squeaking noise when i turn it on
I would suspect the belt to be making the noise. If you are handy with a screwdriver, unplug the dryer, take the back panel off and have someone rotate the drum while you listen for the squeak. If it is the belt, get a can of belt dressing from your local auto parts store and lightly spray it on while rotating the drum so you get all parts of the belt.
Mar 29, 2011 | Dryers
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
Dryer is not working makes loud noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Jun 18, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Whirlpool LEW0050PQ electric dryer makes a noise.
heatman101
sdfhywt4
May 22, 2010 | Whirlpool LEW0050P Electric Dryer
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
Squeaking dryer drum when operating
May 24, 2009 | Fisher and Paykel DG05 Gas Dryer
Squeaking noise
Noise from dryers can be eliminated through the following checks
* Level the dryer
* Check the drum belt
* Check the drum support rollers
* Check the idler pulley
* Check the glides
* Check drum bearings
* Check the blower
* Check the baffles
Apr 10, 2009 | Maytag Dryers
Maytag Atlantis MDE6400AY Electric Dryer Logo
334 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
