Question about Microsoft Broadband Networking MN-500 Wireless Base Station (L21-00001) Router
How do i set up a security for wireless
How do i set up a security for wireles router
Find network security key
You will need to open the setup page of the router and check the wireles settings.
Watch video
Jan 21, 2012 | Linksys Wireless-G Broadband Router
I have a netgear wireles usb adapter i put it on my desktop computer and i find asante pc wireless but they ask me for the network security key to connect
i believe that means you have a password*(security key) enabled on your wireless. You should be able to go to your routers web address...go to netgear.com and search around or read the manual. If someone like TWC or your ISP set up your wireless router, you can call them and they should give you the security key that was set up on your internet service.
Dec 29, 2010 | Computers & Internet
How to put password?
Hi Friend,
Please follow the steps in order to secure your network
1.Open router page (192.168.1.1)
2.Enter the username and password (default password is admin and leave the username blank)
3.On the router page click Wireless and fill the sections as mentioned
Wireless Network Mode-Mixed
Wireless Network Name-As per your choice
Wireless channel-6-2.437Ghz
Wireless SSID broadcast-Enable and click save settings
4.Click Wireles Settings and select the Security Mode as WEP
WEP encryption-64 bits 10hex digits
Key1-Enter 10 digit or 10 letter password(like your telephone number) and click save settings.
Turn off the router for 30 seconds and turn it on after that. Your network is now password protected.
I hope this will resolve the issue.
Regards
Chiranjeet
May 19, 2010 | Linksys Wireless-G Broadband Router
Security lock
you don't. Reset your router on default settings. Push reset button on the router.
Mar 03, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I have a qwest modem how do i put a lock so other people dont use my internet
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Jan 19, 2010 | D-Link AirPlus DI-524 Wireless Router
How you lock the wireles ruter
Are you trying to secure the wireless network ?
It is very simple.
Click Here for more info
Oct 13, 2009 | Airlink AR430W Wireless Router
When setting up sky broadband wireless inever had a wireless
if you have a softwere cd for the adapter place it in cd rom instaling it all,before you setup wireles instal router wired to configure security, then setup wireless connection.
Apr 03, 2009 | Computers & Internet
Password setup problems
ok this is simple but at the same time kinda confusing open an internet window and type in 192.168.1.1 the password on defalt is going to be eather password or admin and the username is admin after you get past the login it should take you to a setup page click on wireless at the top  after you click on wireless just under that click wireless security thats the settings to change the wireless security in there you can chose what type of secutiry you want i normaly use wap2 on TKIP after setting those type the password you want after that save it and close the window on all the computers that use wireless your going to have to disconnect them and reconnect them from the network it will ask for the password enter it and make sure it saves the password and your set if you have any problems in the process let me know if be glad to help
Please rate this
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
I need to secure an unsecure network.
You need to log into the router and go to the wireless settings. The to wireless security. There choose WEP, WPA etc. On the right hand side of the screen is definitions of these methods. Click on more for instructions of how to enable the security measures.
Dec 23, 2008 | Linksys WRT54GS Wireless Broadband Router...
Wirels connectiuon
you cannot just connect two routers one after the other- what you need to do is to set the wireless router as a "Wireless switch" - it means that it won't preforme as a router it will preform just as a broadcasting device.
you also need to set it to be on the same subnet that the first router is on- since you didn't specify the make and type of the first router it will be very hard to answer this question.
what I suggest is that you call the support of either the wireless router or the other router company and they let them know that you need to "set the wireless router as a switch to the first router" and they will be able to guide you how to do it.
May 18, 2008 | Edimax BR-6216Mg Wireless Router...
Microsoft Broadband Networking MN-500 Wireless Base Station (L21-00001) Router Logo
16 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
