Question about ViewSonic VX922 19" Monitor Flat Panel
My Viewsonic Monitor (VSC3C19 I think) comes on ok, but the display is quite dim and the monitor menu is permanently displayed at the Contrast option. If I press the up triangle on the monitor the contrast goes to maximum, then runs down to the lowest setting, and the menu stays visible. I can sometime exit the Contrast option so that the White Balance caption is displayed (but nothing else) then after a while the Contrast menu comes back!
  • 11,361 Answers
When you have strange problems like this, the first place to look will be the power supply/inverter board, look for caps with leaking/bulging tops.
Read more here:
http://www.badcaps.net/forum/showthread.php?t=6179
My pictures of failed Viewsonic due to bad caps.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on May 06, 2010
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
ViewSonic VA1926w monitor dims darker when there's dark content on the screen. I have 2 of these monitor connected to a Pro Mac. Only the right side monitor does this.
Its the dynamic contrast ratio (DCR) that dims the display when dark images are displayed.
For my VA1926w, pressing the right most button (up arrow), enables or disables DCR. Keep this disabled.
- Shalabh
Oct 08, 2012 | ViewSonic VA1926w 19-inch Wide LCD Monitor
19 inch lcd monitor has dimmed display
tried to adjust in the screen set up menu the brightness and contrast. if can not get with adjustment with very dim display replaced the back light ( cold cathode lamp).
Jul 22, 2012 | Computers & Internet
Display dim
Open the menu and change the brightness/contrast settings. If there is no change or if the picture seems dim, then it is a possible fault in the power section within the monitor or a fault in the display driver/convertor section.
Jan 07, 2011 | HP 1502 LCD Monitor
Contrast window pops up and dims the screen.
You are not alone. I have a Viewsonic monitor that does exactly the same thing. Wasn't sure if it was the monitor or a "bug".
Dec 10, 2009 | ViewSonic VX910 19" LCD Monitor
Monitor is blank
HI there,
Problem : no power
Action : * Make sure power button or switch is ON.
* Make sure A/C power cord is securely connected to the LCD display.
* :Plug another electrical device (like radio) into the power outlet to verify that the outlet is supplying proper voltage.
Problem : Power is ON but no screen image.
Action : * Make sure the video cable supplied with the LCD display is tightly secured to the video output port on the back of the computer. If the other end of the video cable is not attached permanently to the LCD display, tightly secure it to the LCD display.
* Adjust brightness and contrast.
* If you are using an Macintosh older than G3, you need a Machintosh adapter.
Hope this helps.
Have a goo day.
Dec 08, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
My view sonic not lcd, automatically menu dispaly will come and adjust it self and will not go. The menu display will is coming when i statrt and sits at centre and not going and adjusting all the...
Unplug power from monitor for 10 or more minutes , let monitor re set itself.. then try plug in the power again..
If this does not work, there may be a issue with your Video card in your computer itself.. Possibly connect monitor to another computer and check if it still does it ...
Oct 09, 2009 | ViewSonic Computers & Internet
Monitor problem
It seems that ur control panel on the monitor having some problem...U need to take it to service center....
Dec 02, 2008 | Computers & Internet
Monitor displays 'user mode' contrast icon @ 89%
Colin
If you can access the on-screen menu (see link below for manual) try and reset to factory settings.
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00385928/c00385928.pdf
If that doesn't resolve the problem, then also check and see if any of the control buttons are stuck, (Press button them flick finger away to try an release a stuck button)
If issue still exists, you can consult a TV repair shop, but essentially, then monitor is uneconomically repairable and it would be more cost effective to just replace it with an LCD monitor
Jul 24, 2008 | Compaq CV 7500 17" CRT Monitor
Monitor won't display resolution properly after Windows Update
I was having the same problem. Believe it or not I fixed it by unplugging the monitor, and when I restarted my PC I again had the 1440 × 900 option.
Regards,
Jeff
Nov 06, 2007 | ViewSonic VA1703wb Monitor
ViewSonic VX922 19" Monitor Flat Panel Logo
127 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
