Question about Casio FX-115ES Scientific Calculator
How do i put and x or y or m into and equation
I cant figure out how to put a linear equation in ex -7-3y= 11 solve for y
  • Casio Master
  • 8,073 Answers
Rename your variable (unknown) X, because the calculator takes X as the default unknown. It will ask you "Solve for X?"
the 7, the second minus sign, 3 and 11 use the relevant keys.
For the first minus sign use the negation key or change sign (-)
For the variable X, examine the calculator keys on the row where the parentheses are. To the right corner of the key area there is a symbol in the same color as the ALPHA key. I believe the X is under the right parenthesis, or thereby.
To enter the X variable you press [ALPHA][ )]. To enter the = sign, you press [ALPHA] [CALC].
To execute the solve command, press [SHIFT] [CALC] and you will be prompted " Solve for X?"
Posted on May 07, 2010
How to solve linear equation
For two linear equations, one can use
comparison, substitution, or addition/combination.
For more linear equations one uses the Cramer Rule that involves matrices and their determinants.
Sep 16, 2014 | Office Equipment & Supplies
Linear equations sharp el-531
You cannot solve linear equations on a SHARP EL531. If you would like a calculator that solves equations, you need to get a SHARP EL W506
Apr 08, 2014 | Sharp el-531x scientific calculator
How can i write this in my calculator example. 2x=10 the answer is x=5 but how can i put x in the calculator
What you want to do is solve the linear equation 2x=10 to find the value of the unknown x that makes the equality true. Solving an equation usually involves rearranging therms, factors and so on. However your calculator was not designed to handle the solution of equations, no matter how simple they are.
Some Casio scientific calculators can solve some types of equations (polynomials of degree 2 or 3, simultaneous linear equations in up to 3 unknowns). These are the FX-115 ES (Plus) and FX-991 ES (Plus C). Other equivalent models are sold in the world under different names.
Oct 16, 2013 | Casio FX350MS Scientific Calculator
Edit Casio FX - 9860G SD have complex equations??
Thhe Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Apparently it will take coefficients that are real, and will give a Ma Error if any coefficient is complex.
Addendum.
The calculator CANNOT solve equations with complex coefficient. YOU can however convert the system of linear equations with ccomplex coefficients ( of the type you show) as a system of 4 linear equations in 4 unknowns; Split x into a real and an imaginary part, split y into a real and an imaginary part. Substitute Real(x)+iIm(x) for variable x in the equations; substitute Real(y)+iIm(y) for y in the two equations; do the algebra. In each of the original equations split the Real and imaginary parts. You should be able to derive 4 linear equations in unknowns Real(x), Im(x), Real(y), and Im(y).
Use the linear equation solver to obtain the solutions. Recompose x=Real(x)+iIm(x), and y=Real(y)+iIm(y)
Alternatively, after you create the system of 4 linear equations you can use the matrix utility to find Real(x), Im(x), Real(y) and Im(y) and recompose the x and y.
Mar 17, 2012 | Casio FX-9860G Graphic Calculator
Casio FX - 9860G SD have complex equations?? edit
The Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Addendum.
Mar 17, 2012 | Casio Office Equipment & Supplies
How do I solve for y, 2y + (y-3)=18 - 2 (y+3). with the casio fx-300es? and if I cant whats the calculator that will. thanx
Do you really need a calculator to solve a linear equation?
Let us see how to solve it without a calculator.
Remove the parentheses fronm the second term on the left : y-3
Use the distributive property on the last term on the right side -2y-6
Take the term -3 to the right side, changing its sign in the process (becomes +3)
Take the -2y term to the left making it +2y.
3y +2y=18+3-6 or 5y=15 and the answer is straightforward .
As to your Casio FX300ES, it cannot solve equations because it does not have an EQUATION calculation mode. The Casios FX-115ES and FX-991ES have an Equation Mode. If you use any of the two to solve an equation in one variable (linear, quadratic or other) the unknown is taken to be x by default. You would have to change the name of the variable from y to x.
Sep 08, 2011 | Casio fx-300ES Calculator
How can I solve linear and non-linear equations
Set Computational mode to EQN by pressing [MODE][5:EQN]
Select the type of equations you want to solve
Select the relevant otion and get ready to type in the coefficients (the a's, the b's, the c's etc`.)
For more general non-linear equations, use the SOLVE feature.
Feb 11, 2011 | Casio FX-115ES Scientific Calculator
Give an example of a linear equation, solve it, and then check your work. Explain step-by-step what procedures you used and upon arriving at a solution, carefully check to see that your solution is correct...
4x+7=11 Solve for "x".
subtract 7 from each side of the equation
4x +7(-7)=11(-7) = 4x=4
divide both sides of the equation by 4
4x/4=4/4
therefore
x=1
Correct?
Dec 06, 2009 | 2006 Harley Davidson FXDI35 35th...
Solving simultaneous equation with scientific
Let us assume you have two simultaneous linear equations :
a_1*x+ b_1*y+c_1=0
a_2*x +b_2*y+c_2=0
where a_1, a_2, b_1, b_2, c_1,c_2 are coefficients (numerical or algebraic).
The problem is to obtain the particular values of the unknowns x and y for which the two equations are both satisfied: If you substitute the particular values of x and y you find in any of the two equations you discover that both equalities are true.
A small system of equations like the one above can be solved by some very simple algorithms (elimination, substitution, combination) which can be carried out by hand.
The solution of large systems of linear equations can be sought by making use of the concepts of matrices (plural of matrix), determinants, and certain rules called Cramer's rules.
Due to its repetitive nature, the algorithm ( a well defined, limited sequence of steps) is suitable for a calculating machine (computer or calculator).
Certain calculators have, embedded in their ROM, a program that solves linear systems of simultaneous equations. Usually you are asked to enter the values of the coefficients a_1, etc. in a set order, then you press ENTER or EXE (Casio) . If a solution exits (not all linear systems have solutions) the calculator displays it.
Hope that satisfies your curiosity.
Aug 12, 2009 | Sharp EL-531VB Calculator
Casio FX-115ES Scientific Calculator Logo
223 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
