Question about Frigidaire FSC23F7DSB Stainless Steel Side by Side Refrigerator
My refrigerator sounds like it is trying to keep kicking on. It will do it over and over and then finallly it will kick on. Has been doing it for months. Would could it be?
    President:
  • 1,430 Answers
The start relay is probally failing.
If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it’s bad is to shake it. If it rattles, it’s bad and needs to be replaced. If not, most of the time it’s ok. But rather than saying the compressors bad, you might want to replace it anyways because it don’t cost much. If you replace it and it doesn’t work then the compressor is bad and you’ll need you call a repairman. (Note that compressors are very costly and are normally not worth fixing).You can enter your model # at www.appliancehelponline.com for diagrams and illustrations. All parts come with installation instructions. Not all models are available.
Posted on May 05, 2010
Refrigerator model bx21vl does not cool. I can hear the compressor kick in but it kicks out in 5-10 seconds. Then after about 102 to one minute it kicks in and out again,
Compressor is tripping on overload. You may just need the overload and relay replaced due to a bad compressor relay. The relay is what switches the compressor from it's start winding to it's run winding. If you pull the relay off, shake it to see if you hear lots of rattling inside, that's a sure sign of a bad relay. I would replace both of them.
Here is the overload relay to order.
Here is the start relay to order.
Nov 27, 2012 | Refrigerators
When the condenser kicks on it will makes a buzzing/whing sound for the time it is on. When the condenser kicks off the sounds stops. It kicks on and off every couple of minutes.
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 11, 2011 | Frigidaire FRS26RLECS Side by Side...
The compressor does not kick on , but the fan keeps blowing
This sounds like motherboard problem. Try unplug your box for 3 mins. Then plug back in. This will reboot the motherboard. If not you may need to replaced it. Not cheap 250-300 dollars from GE. I hope this helps.
Aug 23, 2011 | GE GTS22WCP Top Freezer Refrigerator
A/C blows good cold air and everything works as it should, however when I turn the A/C on (doesn't matter what fan speed) I hear a constant clicking/ticking noise coming from what sounds like a fan
What you are most likely hearing is the compressor kicking on/off. The constant kicking could be a sign that there's insufficient refrigerant to keep the compressor running continuously without shutting on/off. Eventually, the compressor won't kick on at all, a safety feature designed to prevent doing damage to a compressor that's undercharged. Have the AC system checked.
Mar 29, 2011 | Kia Sorento Cars & Trucks
Loud humming noise
try using a spirit level to make sure unit is sitting square,the most common cause of noise.....(also make sure its not touching the wall....)
Apr 13, 2010 | Whirlpool ED2FHSS Side by Side...
Kenmore Coldspot compressor kicking on and off
It sounds like you may have toasted one of the starting componets. Either the start relay or the start capacitor has probably failed, causing the compressor to try to start, and then kick off on overload. Hope this helps
Sep 10, 2009 | Kenmore 50522 / 50524 Side by Side...
Will not cool,will not freeze. compressor will not kick on.
you can try a hard start kit(has a big start capacitor but if it was mine i would replace it)
Aug 13, 2009 | Whirlpool ED5FTGX Side by Side...
Kenmore AC Model 25370156000 keeps shutting off and on by itself
If you have just installed this unit in your window for the season, you may want to wait a day or so, for everything in the unit to settle, and try again. You make have shaken it up a bit too much. If not.....sounds to me like it is kicking out on high head pressure. This happens when refrigerant gets too low, or there is air in the refrigerant system. There is nothing you can do to solve this problem, except take it to a repair shop. If I am correct what happens is you turn the unit on, and the fan and compressor start simultaneously, then after a few seconds (maybe up to a minute) the compressor kicks off, and the air gets warm, then the compressor kicks on for a few seconds, and we repeat. This is actually a safety mechanism for the compressor motor so it does not run without refrigerant. (That would destroy the pump.)
Jun 04, 2009 | Kenmore 76129 Air Conditioner
Frigidaire FSC23F7DSB Stainless Steel Side by Side Refrigerator Logo
158 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
