Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Belkin router can't connect to internet
Not experienced computer user connected modem to main computer then installed set up software in my laptop using flash drive just copied files on to the flash and installed. Modem plugged in , router plugged in and lit strength shows as "excellent" but cannot connect to internet.
    New Friend:
  • 10 Answers
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
Posted on May 05, 2010
Hello, I do not know much about troubleshooting internet connections. I just rely on Microsoft's "Diagnose Problem" option and most often than not, it works. But when I replaced our old...
Thank you for using fixya.
Being that your other computers in the network are working properly, you should switch the ip settings on your comnputer to automatically detect. That way your computer does all the routing and ip setting,
After you have set that back. Remove the power of your router, remove the power of your modem, and restart your computer.
Once your computer is back up, turn on modem, then the router.
It sounds very simple, but in most cases, it solves the problem.
Hope this information is helpful
Jul 18, 2011 | Belkin Basic Wireless Router
The globe light is blinking. We can connect to Belkin but page not found comes up. The message that comes up says IP address does not match. We have 3 laptops, and none of them are allowing us to have...
  • Connect your computer directly to your cable or DSL modem. If you see a log-in screen for your Internet Service Provider, make a note of the user name and password.
  • Unplug your router and your cable or DSL modem.
  • Plug your modem to your Belkin router's "WAN" port. Connect your computer to one of your Belkin router's numbered ports.
  • Turn on in your modem and wait 10 seconds. Plug in your router and restart your computer.
  • Select "Start," then "Control Panel" and then "Network Connections." Right-click "Local Area Connection" to bring up your network connection properties.
  • Click "Internet Protocol (TCP/IP)," then "Obtain an IP Address Automatically" and then "Obtain DNS Server Addresses Automatically."
  • Open your web browser. If you are prompted for a user name and password, enter the information you recorded in Step 1
  • Dec 29, 2010 | Belkin F5D8236-4 Router
    Installation of belkin router failed
    You need to configure your router.
    For that Connect your router to computer with ethernet cable then you can access it with following default link.
    http://192.168.15.1
    or
    http://192.168.2.1
    If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
    Then it ask for user name and password.
    Type user as "admin" and password as "admin" or "password" or blank.
    Then you can see configuration page of router.
    Click on WAN settings and set those settings as your internet service provider settings.
    Enable DHCP if you want to get ip from router.
    Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
    Then you can connect your wi fi network with that code.
    Let me know if you need further assistance.
    Thanks for using FixYa.
    May 08, 2010 | Belkin (F5D5231-4) Router
    No internet connection
    Router set up is very easy. You will need to access the router set up interface to make changes on the router.
    If you are not able to go online using the router then you will need to check the settings of the router.
    First make sure that your computer is able to go online when connected directly to the modem without the router.
    If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.find network key.
    Router set up for Cable Internet service provider :
    This connection type uses the MAC address of the main computer to identify your connection. They generally register the MAC address of the main computer. So the MAC address is everything in this connection type. Now we set up router using the MAC address of the main computer. Main computer is the computer which was able to go online through the modem. Use only the main computer to set uo the router.
    Connect the modem and the computer to the router . Check the IP address on the computer.
    According to the Default gateway value open the set up interface of the router. Once you open the set up interface, you will need to clone the MAC address of the computer. Then change the wireless settings on the router and your router is ready to go.
    Router set up for DSL Internet service provider.
    What is DSL connection?
    DSL (Digital Subscriber Line) is a high-speed Internet service that competes with cable Internet to provide online access to local customers. DSL operates over standard copper telephone lines like dial-up service, but is many times faster than dial-up. In addition to being faster than dial-up, DSL does not tie up the phone line. Coexisting with telephone service in this way allows users to surf the Net and use the phone at the same time.
    There are two types of DSL connection
    1 ) PPPOE : In this connection type you will get user name and password from the Internet service provider. Your computer will not be able to go online when connected to the modem only. You can open the router set up and change the Internet connection type to pppoe and type the user name and password for the ISP. After that change the wireless settings of the router and it will be ready to go.
    2) DHCP : In this connection type your computer will be able to go online when you connect it directly to the modem.
    you don't require the user anme and password for the ISP.
    In this connection your computer will get a private IP address from the router. According to this the IP address of your router will change. Change the wireless settings of the router and it will be ready to go online.
    Click Here for more info
    Dec 18, 2009 | Belkin Computers & Internet
    I cannot get my Dell Inspiron Laptop to connect with Belkin router, any idea why??
    Are you trying to connect to the wireless network on the laptop ?
    It is very simple.
    first you will need to make sure that you have all the wireless settings of the network.
    Click Here for more info about wireless network connections
    Oct 17, 2009 | Belkin (F5D5231-4) Router
    Cannot connect to internet
    call ur isp ...ask for
    1. ip address
    2.subnet mask
    3.default gateway
    4.dns
    or
    1.ppoe - username and password
    connect ur belkin to the computer
    1. start - run - cmd - enter
    u get a command prompt screen
    2. type ipconfig
    u will get the default gateway
    close that black screen
    3.open the internet explorer
    4. type the default gate way in the address bar
    5. it will ask for the user name and psw for belkin
    6. check ur manual for default user id and the psw
    7. u can see the main page of belkin
    8. enter the first set of settings or the second set
    save
    ==============i hope this will help u
    Jun 04, 2009 | Belkin (F5D72304F5D7000) Router
    Belkin N Modem Router If main PC which is ethernet wired to the modem router is swtiched off, laptops cannot access the internet. Does this mean that the PC to which the modem router is connected has to...
    it will as long as the modem/router is connected to a phone line, instead of the pc, the only cable connected to the pc should be a ethernet cable; or you have the pc networking set that it connects via another pc instead of through a gateway, re run the wireless network wizard.
    Sep 05, 2008 | Belkin Computers & Internet
    Set up my belkin g router
    You may have to configure the belkin router depending on the type of ISP that you have.
    Basically, you can do these to configure your router:
    1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
    2. turn off the modem, router and the computer for 30 seconds
    3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
    Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
    Can't go online from Main Compter after Installation
    Does your router tell you it has an internet connection? (you can check this from the routers status page on it's web interface). If not, unplug the router and modem, then plug in the modem (wait approx 10 seconds). Once the modems status lights are static, plug in the router, and check the internet connection.
    May 23, 2008 | Belkin (F5D7230-4) Router (587009)
    Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
    310 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
