Question about RCA Televison & Video
Mine is a drc358N. Itried to tape something, but it came out with blurry sound ans gray screemy fuzz...
  • 4,102 Answers
Hi the problem your having could be down to one of a couple of things.
first of all was the vcr working properly before you had this problem or has the vcr not been used for a while.
also have you tried playing a tape that you have not recorder yourself such as a film if you havent then give it a try and see what happens,
now here are the most likely cause of the problem you are having.
1. the tape you are using could have been used more times than it should and it could now be no longer any good to record on, so trying another tape would rule out this problem.
2. if a tape such as a film you bought from a shop plays perfect and the sound is perfect then this would indicate a problem with the tape your trying to record on or possibly a damaged recording head.
3. if all tapes on play back is bad then this points towards dirty head and cleaning it should solve the problem. Now to clean the head you have a couple of options, you could go out and buy a decent vcr head cleaning tape kit these you should be able to buy from most hardware stores, how ever these tend not to work most of the time and can cause the problem to get worse.
now the other option you have is to clean the head yourself, doing this will still not ensure it will work properly after as damage may have been caused to the head.
If you are ok with taking things apart and have basic skills for doing this then cleaning the head is something you can do yourself, if you are going to do this yourself then make sure you dont have the vcr plugged in whilst doing this as you can give yourself a nasty shock and cause harm to you and others around you.
Cleaning the head is no guarantee it will get it working as it was due to the fact that the head may need replacing.
The main reasons the head gets dirty or damaged is down to either dust if the vcr has been sitting for weeks without being used or if you have put a tape in that had been chewed up before or the tape may have had something sticky on it that has been transfered to the recording head.
Now below is a great guide for self cleaning of the head, but first of all let me explain about the head, once you have the vcr's outer case of you will notice the head its a big shiny wheel towards the back of the vcr where the tapes go in, now this head is what spins round as you rec or watch a tape so any dust or dirt or sticky stuff on here will cause the vcr not to play or rec properly or not at all, now when you look at the head it should be perfectly clean and shiny with no marks on it what so ever, apart for yours that is yours may have dust on it or a sticky patch,
now never touch the sides of the head that run along the tape with your fingers as you can and will damage it, when your cleaning the head you need to spin it slowly so you can hold the cleaning pad still and let the head turn and clean that way.
never rub the head with a cleaning bud as you will damage it, never move the cleaning pad or bud up and down whilst you are turning the head this will damage it beyond repair, when cleaning you hold the pad with the cleaning fluid on against the head flat so as your putting a small amount of pressure along the whole height of the pad from top to bottom no keep the cleaning pad still and then spin the head with your finger using the rim running along the top, doing this will ensure no damage is done, once you have done this you can spin it with your finger without the pad their to check for any sticky marks or dust or dirt, you need to get it perfectly clean so that their are no marks on it at all.
READ THE GUIDE BELOW FOR CLEANING
  1. Eject any tape from the VCR and unplug it from wall current.
  2. Unplug any other cables from VCR (Cable, Antenna, Audio/Video Cables, etc..).
  3. Place VCR on flat surface, such as a table covered with newspaper or cloth to protect table surface.
  4. With the appropriate screwdriver, remove VCR cover carefully.
  5. You will see a shiny round drum--this is the Head Drum. Take an isopropyl alcohol-dipped chamois tipped cleaning stick and place it on the Head Drum with light pressure.
  6. Manually rotate Head Drum with your free hand (it spins freely), keeping chamois stick stationary, allowing fluid to clean the drum (Never move the chamois stick in the vertical direction-you may snap off Head protrusions on the drum).
  7. With fresh chamois tips and alcohol, now clean the Stationary audio head, capstans, rollers, and gears. Check for dust. Do not get excessive fluid on any parts.
  8. Clean Belts and Pulleys using fresh chamois tips, once again, do not use excessive fluid.
  9. Clean dust off Circuit Boards using a mini-vacuum cleaner and/or compressed air (Use just enough force to remove the dust and dirt).
  10. Let machine site a few minutes after finishing above process.
  11. With the VCR still open, plug into wall and TV, turn on VCR and insert a recorded tape. (Do not touch any of the interior workings of the VCR or interior metal cabinet during this process).
  12. Press Play on VCR and confirm that everything is functioning correctly and picture and sound is restored.
  13. Repeat steps 1-10 if results are not satisfactory.
  14. Eject tape, Unplug VCR from wall, uplug all cables.
  15. Screw VCR cover back on and place back in original location with proper hookups.
Tips:
  1. Do not perform the above procedure if your VCR is still covered by Warranty or Extended Service Plan. Take unit to authorized technician instead.
  2. Make sure you have all the proper screwdriver(s), chamois, cleaning solution, etc... before starting Step One of this process. DO NOT USE Q-TIPS.
  3. Your Guide is not responsible for any damage to your VCR involving any steps in this process. If you have doubts about your skill after opening the cabinet, do not go forward. For more extensive information, check the resources below.
let me know how you get on or if you need further assistance ok, if you follow the guide you should find your vcr will be back up and running as if it was new
Posted on May 05, 2010
Video on my Sony VCR (SLV-780HF) goes gray after playing a tape a few seconds. What could be the problem?
The only real cure will be to clean the video head. If that doesn't work then I'm afraid that whatever recorded you EP mode tape was not set up well tracking wise. So other machines struggle to track the tape. Some VCR's will only playback SP or LP tapes and don't have EP mode. In which case you should check to see if these VCR's can play the EP tape and if they can't find one that can.
Dec 06, 2012 | Sony Televison & Video
Mini tape holder keeps opening and it displays error beeps... Has been used at beach on various occassions... Any help would be appreciated.. Is there anyway we could clean the inside mechanisms?
Sounds like a little sand and / or moisture made it's way into the camera. A call to the Sony Company Tech Support will let you know if one of the canned compressed air cleaners for computers would be advisable.
Another thought is to check if there is something in or near the hinge of the tape hatch apparatus. Sometimes I take one of those electronics foam "Q-Tips" and wipe out the area in case a piece of dust or fuzz or something is causing a malfunction.
May 14, 2011 | Sony Dvcam DSR-PD100 Camcorder
We have a Toshiba tv/vcr model # MV13M3. When we play a VCR tape the sound come thru just fine but there is only fuzz for a picture. Is there a tracking adjustment that could help?
The "fuzz" is because of no video signal from the heads. You can try a cleaning tape. If that fails, then the unit will need to be taken apart and a professional cleaning/realignment done. I would also suspect that the last tape that was used prior to this current one is probably suspect as the culprit here. The heads were likely contaminated by that tape.
Please keep us posted on your progress.
Dan
Sep 10, 2010 | Toshiba Televison & Video
A fuzz sound is coming across my speakers. How
Try and isolate the problem by disconnecting all components and reconnect them one by one. Fuzz could be comming from one particular component, or could be an internal fault in the bose amp.
Jan 14, 2010 | Bose (321GS) System
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
Horizontal lines on playback on my camocorder samsung sc-d353
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Feb 21, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
Emerson vhs/dvd palyer picture sucks when i record a vhs tape of something on tv
most vcr's use the channel up and down buttons on the remote for tracking control.
Nov 18, 2007 | Emerson EWD2204 DVD Player/VCR
Canon zr100 digital video camcorder won't record or show picture on screen
PLEASE USE MINI DV HEAD CLEANING CASSETTE & TRY , MAY SOLVE YOUR PROBLEM
Oct 20, 2007 | Canon ZR100 Mini DV Digital Camcorder
Recording tv from a vhs player
sound like you have a dirty video head, try cleaning the head with some isopropyl alchol. if it does not fix your problem, then you will have a bad video head. good luck
Feb 15, 2007 | Samsung DVD/VHS/MP3/SVHS Playback
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
