Toshiba TV 50h71 have the tv for repair already have this problem but don't remember it R243 and 244 are burn
  • audioshop May 05, 2010
    when power on the tv the 2 resistor r243 and r244 smoke and burn
  • 12,061 Answers
Service manual, below, this is what the engineers use to troubleshoot and repair this unit.
http://www.pacparts.com/reference/80/50H71.pdf
http://www.scribd.com/doc/7520950/Toshiba-CN27E90-TV-Technical-Training-Manual
http://www.smpcshop.com/42H81-43H71-43HX71-50H12-50H71-50H81-50HX81-53H71-53HX71-57H81-57HX81-61H71-p-3235.html
Above is the service manual, this has ALL parts,and circuit diagrams inside so you can fix, the other ones are for assistance to understand hoe to troubleshoot and hopefully repair.
Hi, well I applaud you for, wanting to repair your set, however make sure you are starting in the right place, The power supply, as, if, that isn't right nothing else can be. But you simply cannot do anything without a Service Manual. In this it has everything one needs to repair the set. OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins.
www.scribd.com/.../Philips-DPTV400-TV-Projection-Training-Manual
Posted on May 06, 2010
  • 10,515 Answers
Kindly Explain the Problem in Detail so that i could guide you.
Thanks!!
Posted on May 05, 2010
  • audioshop May 11, 2010
    F470 is also open
When watching our Toshiba 50H71 it just turns off then back on.
The power supply will need to be repaired. This is with any tv that turns itself off and then back on.
May 06, 2010 | Toshiba 55H70 55" Rear Projection...
Toshiba 50h71 red flashing light.. no pic / sound
you need to get a new tv lamp BULB.to cheak there is on the side a cover with one srew on do pull out the square box it has your bulb in it,you will no right away that it is broken.don't order it from repair shop it will cost 600.00 get from ebay it is only 225. with shipping.
Jun 27, 2009 | Toshiba 50H71 50" Rear Projection...
Fix 50H71 Rear Projection TV
Go to this site and leave an email indicating your model number and what the problem is, they should be able to help you with the problem.
http://servicemanuals.vstore.ca/
May 24, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71
the plug on p113 is not the problem I have the same tv and it has nothing plugged into it either :) I to am trying to locate the resistors that might be the problem. I replaced both chips and still have only blue vertical converge not working
May 20, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71 projection tv
You need to replace both of the convergence ICs they are number STK392-110 you can get new replacement ICs at the following link and they provide free instalation instructions so you can do the repair yourself which tkes about 30 minutes to do and saves you about 400 dollars. heres the link.
May 18, 2008 | Toshiba 50H71 50" Rear Projection...
Red picture toshiba model 50h71
try to turn down the screen control and see how the tv reacts.
Apr 10, 2008 | Toshiba 50H71 50" Rear Projection...
TV KEEPS SHUTTING OFF
It may be solder related, but it may be something such as aleaky diode causing secondary voltages to increase thereby shutting down your set for protective measures. I would recomend getting a service manual and some free support to help you diagnose this. You can get both at the following link.
Mar 19, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba Tv 50H71
This is like so many sets I have seen here. This problem has to do with the shutdown circuit turning the set off to protect it. As has been said many times this is a problem with the HV section which inclused the deflection, convergence, and horizontal output. These sections can not be repaired by someone who does not have electronics experience. I would suggest that you take this telvision to a repair shop in your area.
Sep 10, 2007 | Toshiba 50H71 50" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
