Question about Dell 3100cn Laser Printer
Error 010-297 restart printer
  • 794 Answers
Hi belljohnson5,
The code is caused by a small switch under the fuser unit not sensing the fuser unit is in place. The blue plastic locking tab on the left side of the fuser has a small catch on the bottom of the fuser. The catch is supposed to slip thru a space in the steel plate under the fuser unit and secure the fuser in place. As the catch slides forward under the steel plate, it pushes on the trigger of the sensing switch, closing the sensing switch and letting the copier know that the fuser is in place. (there is also a similar locking tab on the right of the fuser but it doesn't trigger a sensor like the left one does) 1) The fuser gets very Hot!! Let cool for 10 minutes after turning off the power and unplugging the copier! 2) Pull the two blue locking tabs forward and remove the fuser unit. Reinsert and push back on the tabs to lock back into place. Sometimes just reinserting the fuser will allow the catch on the locking tab to function correctly and push the trigger on the sensing unit. Turn the copier back on and pray the error code doesn't reappear.. 3) Mine reappeared. Evidently the catch on the fuser unit was still not pushing the trigger forward, causing the copier to surmise that no fuser unit was installed. At this point, you should buy another fuser unit or take your copier to an authorized Dell repair center.
Hope this helps.
Thank you for using FixYa.
Posted on Jul 11, 2011
Y - CRUM Error / Error 093-950 Restart Printer
093-950 Y - CRUM Error
Error 093-950
Restart Printer
The yellow toner Smart Chip error is detected
Error with detecting or defective yellow toner cartridge. Replacing cartridge should correct it.
Paul
Nov 25, 2013 | Lexmark X560n Laser Printer
59.62 error
hp color laser jet 9500 error 59.62 how fix
Jan 28, 2012 | HP LaserJet 9500mfp Printer
CT sensor error Error code 092-310 error code 00002000 restart printer. please note will not restart also unpluged still no respond
The CTD Unit is a Sensor on or near the Transfer Belt Unit on your Dell Laser Printer. This error is advising that the sensor is dirty and may need cleaned.
If you receive one of these errors please clean the CTD Sensor on the Printer.
  1. CBR Tech Solutions orhttp://www.cbrtechsolutions.com
Apr 10, 2011 | Office Equipment & Supplies
004321 restart printer error
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer.
Nov 30, 2010 | Dell 3100cn Laser Printer
Getting 004-332 restart error
Hi
Error code: 004-332
1. This type of error code implies that you need to restart the printer again.
2. However, do check to see if toner cartridges are seated in the proper position.
3. Also ensure that they have been locked in.
Jul 14, 2010 | Dell 3010cn Laser Printer
No print catridge error showing on display
plz remove the catridge and reinstall the catridge properly then uninstall the printer driver and restart the system then after restarting the system then reinstall the printer driver and restart the system again then after restarting the system check
Jun 01, 2009 | HP LaserJet 3050 All-In-One Printer
900 service RIP software error on boot-up
removed memory off the system board restarted printer. came up to an error no memory found.
powered down and reinstalled memory on board in a different slot and restarted unit...
NO ERRORS......
May 24, 2009 | Lexmark C750n Laser Printer
Dell 3100cn Laser Printer Logo
91 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
