Question about Sharp Viewcam VL-Z3U Mini DV Digital Camcorder
LCD PICTURE UPSIDE DOWN
When I'm taking pictures with the lcd screen the picture is upside down how do I fix that? I just bought the battery for it but not the little lithium one would that affect the lcd screen that way ? Cam corder vl-z3u
    Guru:
  • 1,049 Answers
This is a feature not a bug...The LCD is designed to flip the picture when you rotate the screen. This is so that you can see what you filming or be in the picture and see yourself filmed. I can't remember if it flips automatically or not. But, I would first try inverting and reverting the LCD screen to see if you can get it to detect orientation, then check and see if there is a setting to manually set the orientation of the LCD instead under the menu options.
Posted on May 05, 2010
LVDS issue with RCA 46 inch LCD TV
If you wish to get some details; check the site linked here. Pull up older posts.
Reasons for upside down picture are given.
Jul 13, 2016 | RCA Televison & Video
Hello, I have Samsung TV Model: UN60ES8000FXZA. I replaced the Main board, TV works fine, except the upside down picture. How to fix this problem, I need to get special codes.The same picture on the M
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 31, 2015 | Samsung Televison & Video
I replaced my main board on a 42lb45rq now my picture is upside down
Configure Windows "video" properties to have Windows "rotate" the picture 180 degrees, i.e., make Windows produce "upside-down" output, and the screen will "flip" that output.
Oct 30, 2014 | RCA 42LB45RQ 42 in. LCD HDTV
Display is upside down
hi,
it sounds like the tinny switch that detects the rotation of the LCD is blocked on the 180 degrees mode. it can be fixed but you need to disassemble the cam ! or may be try a little shock near the hinge... sometimes machines need a little kick !
Apr 04, 2014 | Sony Video Cameras
Thomson 27lcdb03b picture upside down
I would suspect main board more than one you replaced--not likely to get help as Thompson is not known for that--possible firmware upgrade seems likely.
On every set I have seen with upside down/inverted or reversed screen etc it has been either a firmware issue or a main board.
Jun 07, 2012 | Televison & Video
My Sceptre television picture is upside down, can you help me fix it? Also no matter what we program into the TV it keeps coming up " Program Locked" upside down of course any clue to my problem?
If you select "source" on your remote then enter 7343 it will bring up a factory menu. Go down to 'Other setting' , the setting 'scaler output' should be set to "Normal". This setting flips the display.
Mar 06, 2010 | Sceptre X37sv-Naga 37 in. LCD Television
Samsung LN40B530 40" 1080p LCD HDTV Picture rotated
how to rotate my samsung flat screen monitor turning up side down
Sep 08, 2009 | Samsung LN40B530 40 in. LCD HDTV
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Picture is upside down and backwards
I have the same problem. How and where does this come from? My camera was sitting in the dock when I noticed the problem!!
Nov 26, 2007 | Kodak EasyShare C315 Digital Camera
LCD upside down and backwards
look for a small pinhole somewhere on the camera body. then insert a pin to reset the camera. if no pinhole, remove batteries for a long time (about 24 hours) then try again.
May 31, 2007 | Olympus Camedia C-725 Digital Camera
Sharp Viewcam VL-Z3U Mini DV Digital Camcorder Logo
324 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
