Question about Sta Rite Sta-Rite Max-E-Therm Low NOx Pool and Spa Heater - 333K BTU Heavy Duty / Natural Gas
My Sta-Rite SR400NA says service system when I turn it on. Last year I had to get a different motherboard because it malfunctioned.Whats the problem now?
  • 83 Answers
SOURCE: sta-rite gas heater won't ignite
I am not sure if either of these issues have been solved, but with the AGS light on, you will need to check the flow of water first. If it is below what is needed for the heater, this will light up. If the water flow is fine, then check the water temp on the display panel. If it is readin higher than that of the ACTUAL pool water temp, you need to replace the Thermister.
If the water temp displayed is about that of the pool water, then the Automatic Gas Shutoff will be the next thing to check and replace.
You can tell IF a Sta-Rite heater has been converted by the model number. The Convesion Kit is supposed to come with a sticker stating that the heater has been converted, but there are two options for the kit and the one without the sticker is cheaper.
If you take off the top two halves of the heater, on the Junction Box there should be a Tri-fold card there. Unfold it, if the model number ends with NA it is a Natural Gas Heater, LP would be Propane.
Posted on Jul 10, 2009
  • 990 Answers
SOURCE: Sta-rite pool heater shuts down as soon as the
Between the two water pipes on the left side of the manifold is a two inch plug. When you take this plug out the thermal regulator assembly will come with it.It consists of "O" rings, a spring and what looks like a thermostat in a car. This is the probal bad part although it could be the spring also. You can get these parts seperatly or in a kit. If this is an older heater the kit is the way to go so you get all the nessary "O" rings and you will be covered on everything you need.
Posted on Dec 08, 2009
  • 990 Answers
SOURCE: Water Temprature read 126 on heater and will not Fire
This is a problem with your thermister (heat sensor) You will find this on the left side of the water manifold about half way down. I'm not sure but I think it is a small tube that slides into the manifold and if you follow the wires back to the board it just plugs in. The part is reasonable priced for a heater part and very easy to install. Good luck.
Posted on Dec 21, 2009
jharwell668
  • 640 Answers
SOURCE: shows r 5 code when power is turned on. sta-rite
The R5 is a sequence code in the boot up sequence where your error is occuring. There is nothing in the users manual for these pool heaters that explains this error. Your best bet, unfortunately, is going to be to call Sta Rite. Here is their customer service number: 1-800-831-7133
Posted on Aug 19, 2010
  • 5 Answers
SOURCE: I have a e05 error
check the sensor that is on the exaust
Posted on Sep 09, 2010
Sta rite sr400na led11 red
check safety circuit and high limits also check gas pressure
Nov 11, 2013 | Sta Rite Sr400na Max E Therm Pool & Spa...
Shows r 5 code when power is turned on. sta-rite
May 08, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Sta rite heater won't start
TURN THE BREAKERS OFF FO R 20 SEC IF PROBLEMS PERSIST SEE CODE A POST
Dec 06, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Heater won't maintain program high temperature
Not sure which one is correct but here is a link to the Pentair/sta-rite site so you can get the information.
Sta-rite Heaters
Feb 22, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Testing
jump for test if bad check gas pressure
Oct 21, 2008 | Sta Rite STA-RITE SENSOR,FLUE TEMP -...
Sta Rite Sta-Rite Max-E-Therm Low NOx Pool and Spa Heater - 333K BTU Heavy Duty / Natural Gas Logo
53 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
