Question about Elna 7200 Computerized Sewing Machine
Needle hits the white plastic where the bobbin case sits.
Heard a loud noise while I was sewing and when I checked the needle was touching the white plastic where the bobbin case sits. Machine is Elna Quilters Dream 7200. I think I have a major problem on my hands. The needle never broke but I can't sew a stitch since the needle hits the plastic. When I took out the bobbin case and put the needle down and it goes around it seems the timing is off because the white plastic does not move to the correct place so the needle can clear. I'm bummed and just was wondering what could be the problem and how difficult it will be to fix. Thanks for your advice.
    New Friend:
  • 194 Answers
It may be as simple as you didnt get the needle pushed all the way up in the needle bar. Get new package of needles and try a new needle and make *sure* it goes up as far as you can push it. the reason I suggest a new pkg of needles is if one is bad in the pkg, they are probably all bad. If that doesnt fix it then the needle bar timing/height is off and need to be repaired/adjusted by a tech.
Posted on May 07, 2010
Needle not picking up bobbin thread and it makes funny loud noise
Sometimes both symptoms are a result of a bent, dull, or damaged needle. Try installing a brand new needle.
If it is still not picking up the bobbin thread and making a noise, take it for service. It most likely has a needle/hook timing issue and the noise could be the needle making contact with the needleplate or in the bobbin area. Continued use could cause the needle to break and flying pieces of needle, in most cases, are not a good thing.
Jun 18, 2016 | Brother Sewing Machines
After adding thread to the bobbin the machine is now making a loud noise it was not making before. What could be causing the the loud noise?
you may have over wound the bobbin
the bobbin may not be inserted correctly into the bobbin case
May 17, 2016 | Sewing Machines
Singer 2263 needle hitting something in bobbin area (loud thunk) and needle moves
try taking the bobbin out and putting it back in the bobbin
case if it's a top loading bobbin
if it's a side or front loading bobbin make sure the bobbin case is
inserted correctly
if the bobbin and bobbin case are inserted correctly then
it sounds like the sewing machine could have a timing
problem and needs to be checked at a sewing machine shop
Nov 12, 2012 | Singer 2263 Mechanical Sewing Machine
White 2037 Bobbin thread not spinning and noticed the needle hitting bottom of bobbin casing
it's sounds like the machine could be out of time & the machine needs to be checked at a sewing machine shop, to find out for sure.
May 10, 2012 | White Sewing Sewing Machines
Needle hitting bobbin case model 750
This is a timing problem the hook timing needs adjustment, and possible the needle timing also
Oct 12, 2009 | Sewing Machines
My MC9000 is jamming when I go to sew (normal sewing/default sett
You may have to replace the bobbin race. It is the round compartment (Black) that the bobbin sits in. If the needle has hit the race because of misthreading, it may have displaced it and put a hole in the race. Not very expensive to fix... want to say somewhere around $30
Apr 17, 2009 | Janome Memory Craft 9000 Computerized...
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Jan 17, 2009 | Singer 7462 Mechanical Sewing Machine
Needle hits bobbin outer casing
Your hook/needle timing is off and it needs to be seen by a technician before you damage the hook. Some dealers can do a 24 hour repair for an additional charge.
sewman7
Jun 07, 2008 | PfaFF Creative 7570
Loud noise while sewing
Could you let us know which machine this is.....
In the meantime....the damaged bobbin is not good, replace it/them........if you have a top loading drop-in bobbin, check for needle damage on the plastic bobbin case (remove needleplate to access).
If there is evidence of needle strikes, if mild, you could try to use very fine wet & dry emery paper to smooth, if severe, buy a new bobbin case.
There may be a load of lint under and around the bobbin case too, remove and clean up this area. If very dirty, use methylated spitit on cloth or cottonbud (QTip) to remove grime (don't soak)
Bargainbox
Jan 27, 2008 | Sewing Machines
Needle & Bobbin out of sync
This description sounds like the machine is out of time. The needle should match up with a cut out section in the bottom of the bobbin area. If it is hitting, the timing has slipped, probably from sewing on a fabric that was too heavy for the machine.
Apr 22, 2007 | Singer 7466 Mechanical Sewing Machine
Elna 7200 Computerized Sewing Machine Logo
225 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
