The water will fill the tub, agitation will begin,
Washing Maching - The water will fill the tub, agitation will begin, but the water continues to run and will not stop unless the water is turned off at the shut off valve. Would this be the water inlet valve?
  • Washing Mach... Master
  • 43,501 Answers
Yes, you have it figured out...
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Posted on May 05, 2010
Testimonial: "Thank you Very MUCH for your help!"
Kenmore 80 series,CH2874165. Continues to fill with water and never starts to agitation. Will spin and drain no problem
In order for the filling to stop and the wash programme to begin, the brain needs to know there is enough water in the tub. There are a variety of methods of detecting the tub water level - pressure switch, float switch or electronic moisture detector.
These things tend to be placed outside the tub and connected by narrow hoses that sometimes perish and leak or become blocked with residue. Sometimes the switch itself fails...
May 29, 2017 | Kenmore Washing Machines
Agitating during water fill up
HI WHEN EVER THE AGITATOR WORKS WHILE FILLING THE TIMER IS FAULTY
May 03, 2014 | Washing Machines
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Jun 18, 2011 | Washing Machines
My GE Washing Machine fills up with water to the appropriate line and then begins the agitation cycle... The water immediately begins to drain to the point the water turns on to fill the tub again... this...
is the drain hose connected to a drain standpipe or laying in a utility tub , or a floor drain check owners manual for proper drain hose height and requirements if drain hose is lower than the height of washer it can auto siphon out of drain hose ,,,,, is the drain hose sitting in stand pipe freely or is it connected to stand pipe with no air gap
Jan 24, 2011 | Washing Machines
I have a Sears Kenmoore Series 70 model 100 washing maching. It's 14 years old. The problem is it will not dran water into the machine when I start my laundry. It goes directly into agitation. No water...
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Nov 30, 2010 | Washing Machines
No water during any cycle.
if no water is coming in how is it agitating?is it filling at the beginning,then it starts to wash the clothes,now does it drain and then it won't fill again,send the model number and more info,
Jul 02, 2010 | Kenmore 24032\24036 Top Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Water fill problem
did you clean the screens in back of water valve? normally a fault code appears if it's a fill issue also the tub will spin at beginning of fill to soak clothes first before beginning to agitate
Jul 17, 2008 | Whirlpool WTW6600SW Top Load
Simpson esprit washing machine
put a new pressure switch in it
Mar 25, 2008 | Washing Machines
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
