Question about Pioneer XM CD RC DET MOSFET50 MP3
I ask before and only answered have of the question i just need to know from my pioneer i have red,yellow and blue with stripe left to hook up now what colors do what hook into the harness with blue(not remote wire) red,yellow and 2 orange(lumination and negative dimmer)
  • jgra88869 May 06, 2010
    ok what about the rest of my question
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pioneer Master
  • 2,226 Answers
Red is ignition (switched) positive power source and yellow is constant (positive) power source.
Posted on May 06, 2010
Testimonial: "ok cool what about the blue wire with the stripe from the radio and yellow hooks into yelloe aed into red and leave the orange alone right"
  • kenw392
    kenw392 May 07, 2010
    if you're asking about the orange wires, you don't need to worry about them. otherwise, i'm afraid i don't understand your question.
Pioneer premier gm-x434 wiring diagram
Yellow - Constant (battery 12V)
Red - Accesory (switched) only 12 volts when car in accesory or on position
Black - Ground (chasis)
White/white with black stripe- Front left speaker (black stripe is negative polarity)
Gray/Gray with black stripe - Front right speaker (stripe negative)
Green/green w/ black - rear left
purple/purple w/ black - rear right
solid blue - power anteanna (not all have this wire)
blue w white stripe - remote turn on (used to turn amplifier on or power anteanna)
yellow w/ black stripe - mute (for cellphone handsfree kit)2_17_2012_9_02_19_am.jpg
Feb 17, 2012 | Pioneer Car Audio & Video
Deh 405 wire harness color codes. Need to know what each wire is to avoid incorrect hook-up. Thanks
These are the general wiring harness colors and their respective connections:
+12 Volt Battery Wire YELLOW (i.e. constand power for memory)
+12 Volt Ignition Wire RED (i.e. power only when key is ON)
Power Antenna / Amp BLUE/white stripe
Chassis (NEG) Ground BLACK
Front Left Spkr (+) WHITE
Front Left Spkr (-) WHITE/black stripe
Front Right Spkr (+) GREY
Front Right Spkr (-) GREY/black stripe
Rear Left Spkr (+) GREEN
Rear Left Spkr (-) GREEN/black stripe
Rear Right Spkr (+) PURPLE
Rear Right Spkr (-) PURPLE/black stripe
Cheers,
"If this has helped you, please rate this solution with thumbs up"
Jul 09, 2011 | Pioneer Car Audio & Video
Red,yellow and blue with stripe hooks to what into harness
some decks have a solid blue for power antenna and blue with white stripe for amp turn on. if you have neither a power antenna or amplifier, i would not worry about connecting those two wires. do makes sure they are capped off and have no bare wires showing, as they are hot when the stereo is turned on.
May 05, 2010 | Pioneer DEH-P2900MP CD Receiver...
I have an after market pioneer car stereo and not sure how to hook the red,yellow and blue with the stripe, to the wire harness with orange lummination and orange dimmer negative,yellow batt. and blue i...
red is usually ignition switched power from the fuse box and the yellow is continuous power to the deck. blue with the stripe is usually a voltage output from the deck to control the on/off of an external amplifier. If you hook the deck up and the memory stations do not save after vehicle on/off cycle of the ignition swap the yellow and the red wire and they should work. One is power all the time to allow the deck to store memory and the other is the main power to the unit.
Wiring diagram for pioneer deh-p41
Yellow for memory.
Red for power acc.
Black for ground.
Blue for remote turn on(amps and accessories).
Gray pair is for right front speakers, solid for positive,striped for negative.
White pair for Left front, again solid is pos, striped is neg.
Violet or purple for right rear, same with solid or striped.
Green pair for left rear, same solid/stripe configuration.
Nov 17, 2009 | Pioneer DEH-P410
Need wire configuration for pioneer deh 2100 cant figure out what color wires are what?
red- accessory
yellow-constant power
black -ground
blue with white stripe-romote ''if any
blue- power antenna
speakers wires'''''''''''''''''''''''
white - postive
white with black stripe-negative]-left front
gray-positive
graywith black stripe-negative]right front
purple-positive
purple with black-negative]right rear
green-poditive
green with black-neegative]-left rear
white
Oct 13, 2009 | Pioneer DEH-2100 CD Player
Need wire color codes for pioneer model DEH-P3001B
If you're installing this the easy way to go is go to like walmart and buy a stereo wiring harness for your specific vehicle. This plug plugs directly into your factory plug and has the wires that connect to your pioneer unit attached to it. All you need to do is match color to color. tracing wires to splice directly into your factory wiring can be a royal pain, trust me i've done it and it ain't fun... but for what its worth here you go.
Red...Accessory
Yellow...power
Black...Ground
Blue w/ white stripe...remote turn on
Blue...power antenna
Gray...Right front+
Gray w/black stripe...right front-
White...Left front+
white w/black stripe...left front-
Purple...right rear+
Purple w/black stripe...right rear-
Green...left rear+
Green w/black stripe...left rear-
Aug 30, 2009 | Pioneer DEH-P2900MP CD Receiver...
Ok, here is a list of the factory wires coming from the car that I have for hooking up a radio and there colors. Red wire with blue stripe, red wire with yellow stripe, brown wire with white stripe, brown...
Hello jlharris28, Here's the color code for the '92 Sentra: Radio Constant 12V+ Wire: Red/Black Radio Switched 12V+ Wire: Blue Radio Ground Wire: Chassis Radio Illumination Wire: Red/Blue Radio Dimmer Wire: Red/Yellow Radio Antenna Trigger Wire: N/A Radio Amp Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): Blue/White Left Front Speaker Wire (-): Blue/Yellow Right Front Speaker Wire (+): Brown Right Front Speaker Wire (-): Brown/White Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Red Left Rear Speaker Wire (-): Green Right Rear Speaker Wire (+): Blue Right Rear Speaker Wire (-): Pink It's better to use an aftermarket wiring harness that plug into the vehicle wiring. The Metra part number 70-1763 seems to be the correct one for your vehicle. Hope this helps.
Aug 12, 2009 | Car Audio & Video
I need speaker wire info for 97 jeep grand Cherokee please
HERE U GO. THIS IS ALL THE WIRE COLURS.
1997 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Red/Gray
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Orange
Car Radio Antenna Trigger Wire: Green/Red
Car Radio Amp Trigger Wire: N/A
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple/Yellow
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4′
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Blue/Pink
Feb 12, 2009 | 1997 Jeep Grand Cherokee
Wire codes for a pioneer deh-p4400
right rear- purple wires
left front- white wires
right front- gray wires
left rear- green wires
BLACK STRIPE NEGATIVE ON ALL
red- 12volts switche
black- ground
yellow- 12volts constant memory
Apr 28, 2008 | Pioneer DEH-P44 CD Player
Pioneer XM CD RC DET MOSFET50 MP3 Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
