On the scanner and the plotter there is a exclamation point after the 24'' paper. The 24'' paper will not print, but all other paper does. any idea what the ! point means and is there an easy solution to the problem?
    Guru:
  • 1,049 Answers
It means that the paper is not available. A smaller size paper could have been loaded in the place of 24" roll, the plotter could have more paper trays/rolls configured than are actually installed, or the paper may not be what it says it is.
Posted on May 05, 2010
Image prints at the edge of the canvas
you should check the paper size loaded at the driver open devices and printers- choose HP DJ5500 driver - right click and open Printer properties-click the paper/sizes tab at the top-check that the paper size is set to ROLL- then set roll size ( 24"=A1--36"=A0---42"=A0/2A0)
now when you try to print make sure that the printing application ( EG paintshopPro) has the correct Page size (under document Properties)
and that your not strectching to fit or using the overprint commands within your printing application. the plotter should never be allowed to overprint as this model has no ay of clearing the excess ink that would be left on the platten
Dec 24, 2013 | HP Designjet 5500 (42 in.) InkJet Printer
The exclamation point light on our Lexmark printer E260dn continues to light up. Each time, we have to open the panel that covers the toner area and close that panel. Then our print job continues . . ....
you have to check paper settings (letter, A4..etc)
For examle - > if you trying to print A4 but printer expecting Letter this error will occur...
If you using Windows XP - .> click start button, then click on Printer and Faxes, select your printer and then click right mouse button on him, select Properties, then click Printing Preferences, now click on tab Paper/Quality and select right paper format...
Rate me if i'm usefull :)
Jan 14, 2011 | Lexmark E234 Laser Printer
I consistently get a paper jam error at the same point in a plot job i have re rendenderd the job to different size paper and reformatted the document several times, but the plotter crashes at the same...
I've had the same problem, and through some experimentation and reading in the service manual, I believe the actual cause is a failing CR motor, although I haven't yet replaced it. Try things that will reduce head speed and the speed at which it changes directions. For example, if you aren't using the entire width of the media, try adding a black line something similar to the print in the far margin to force the printhead to move farther. You can also try changing print modes. I've found that unidirectional printing is far more likely to have problems than bidirectional printing as well as the high speed 360x360 modes. Best luck is usually with 720x720 or 720x1440 in bidirectional mode, and if it fails, try changing the width of the print.You might also check that the printhead moves freely all the way across the printer. You could have a bad bearing. The printer detects a paper jam anytime the amperage goes too high on the CR motor, and it seems pretty sensitive.
Dec 11, 2009 | Epson Stylus Pro 10000 InkJet Printer
Printer keeps showing a stop job with exclamation point
Do you have a Mac OS X?
Maybe you just need to reinstall the driver. Download it through the following link:
http://www.techspot.com/drivers/driver/file/information/7584/
Let me know if it does not work and tell me what OS version you are using. Click on the Apple menu and select About This Mac to get the version.
Thanks.
Apr 15, 2009 | HP OfficeJet G55 All-In-One InkJet Printer
Printer cutting off 5 inches from finished size from InDesign
teresa_marti,
Try to rotate from lanscape to portrait, or if plotting form Acrobat check auto rotate and denter from the properties. Since it pltted before and no resizing was don it has to be the printer preferences.
randy320sgi
Jan 07, 2009 | Adobe InDesign
HP Designjet 500ps 24" Plotter- screen says to replace printheads
Printheads are available everywhere, you replace them your self. Machine will usually indicate just one bad print head at a time.
Dec 22, 2008 | HP DesignJet 500ps InkJet Printer
Are those papers printable on Brother HL-4050CDN ?
Hello !
If you want to print on canvas you need to use a plotter which use ink. An example is Roland or Epson. Personal i use Epson T5200 plotter and the result is awesome.
Apr 16, 2017 | Brother HL-4050CDN Printer
Paper feeding
I beleive it is the paper thickness lever on the right side when you lift up the scanner section.
Here is the setup guide:
http://files.support.epson.com/pdf/cx66__/cx66__pg.pdf
Please remember to rate Techs who assist you for free :)
Joe
Sep 12, 2008 | Epson Stylus CX6600 All-In-One InkJet...
k24674
jasbo
jasbo
