Question about Mag Innovision InnoVision XJ 717 Monitor
Picture has shrunk and has lines
Picture has shrnk and has lines
  • 109 Answers
Loose board solder...
Posted on May 09, 2010
My sky box picture has shrunk
check your aspect setting
Sep 09, 2014 | Televison & Video
My picture size shrunk
you have a bad cap in the vertical section depending on your skills as an electronic tech see repairman
May 19, 2010 | Funai F42PDME 42 in. Plasma Television
My toshiba 2577db has a blue line across
easy the vertical chip is dead /and or two
caps right next to it , total cost of part 8.00
so dont let them charge you to much if
you take it in to a shop
Jun 28, 2009 | Televison & Video
Picture colors not in phase
Make sure which color is not in line.
What u have said makes me believe U are having a dead vertiacal drive on one of the gun
Rifaa
Nov 13, 2008 | Sony KP-51WS510 51" Rear Projection...
Shrunk picture?????
enter the service menu mode and adjust the v.line adjustments
Aug 27, 2008 | Sampo SME-34WHD5 34" TV
Av-32f476 picture shrinkage
I had a Crummy Westinghouse TV that had a problem like this. JVC's are typically better built then a Westinghouse. My first educated guess - sounds like it's a voltage issue, most likely on the high voltage. Probably a capacitor on the power supply side of the motherboard or the capacitor in the flyback transformer. Just and educated guess.
Jun 23, 2008 | JVC AV32F476 32" TV
The picture has shrunk - maybe 720P vs 480P?
make sure your hd cable connection from your cable box is going to an hd connection to your tv.[via hdmi, dvi,or componant.] if you have a different hook up such as rca out or coax out, these are not hd connections and you are probably streching out the picture.look at the rear of the tv & cable box and see how the connections are.the hd hook up to the hd input should make the picture the right size only if it's set on the hd input channel.hook up the dvd player to a aux/line in or video/source input and try changing the picture size. you may have to play around with it till you get it the way you want.
hope this helps.
wg
Feb 06, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Picture fault
Hi.
What is picture like if you change screen size to 4-3  is this picture size ok & fault only shows in the wide screen formats.
Oct 10, 2007 | Televison & Video
Zenith IQB60M92W 60in Rear Projection
Sounds like some kind of local interference. The first thing I'd try is disconnect the antenna input. If the wavy line goes away, it's probably something coming in through the antenna. Then I would start shutting off the circuit breakers until I was down to just the one the set is plugged into. If it goes away I would start flipping the breakers on, one by one until the noise returned. If you can isolate it to one circuit, start looking at everything that is on that circuit. If all else fails, call a TV tech.
Oct 01, 2005 | Zenith IQB60M92W 60" Rear Projection...
Mag Innovision InnoVision XJ 717 Monitor Logo
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
