Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Looking for list of fault codes for dish drawer
  • Fisher and P... Master
  • 3,247 Answers
I hope this is what you are after
F1 Flood switch has been
activated.
Turn the water and power supply to the
DishDrawer® off and call your Authorized
Service Center.
F2 Motor problem. Call your Authorized Service Center.
F3 Temperature sensor failed. Ensure water coming in through the inlet
hose is not hotter than 65oC. You may
need to install a tempering valve on your
water supply.
F4 Faulty temperature sensor
or element
F9 Electronics malfunction. Call your Authorized Service Center.
U1 Fill Fault 1 Turn the DishDrawer® water supply on.
2 Ensure the spray arm can rotate about
the center, and if the DishDrawer® is
full of water, it will need to be emptied
manually.
3 Call your Authorized Service Center.
Posted on May 07, 2010
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
My dish draw **** up with a service code f 1 , what does this mean
This can mean several things. If you have double drawer dishwasher then you need to confirm if you get the F1 message in both drawers or just one.
If both drawers then it is caused by water leakage and flood switch activiates. If only in one drawer then the power supply to the other drawer is blown.
For single unit drawer it means flood switch triggered.
Dec 26, 2012 | Fisher and Paykel 24 in. DS-603 Built-in...
Top drawer on F&P dish drawer stuck on cycle & continuously beeping
You could isolate the top drawer by taking the controller power cable out. DIsconnect mains power to dishwasher, open top drawer and remove front cover carefull after removing 2 plastic pins on each side with plier. Controller box is on left top side, remove bottom connector and cover with insulation tape. Put things back and turn power back on.
But if you want to find the fault with top drawer then that is very trick if there is no fault code on panel except beeping First clean the top panel inside door with a clean damp cloth. If this does not change the situation, then it is very likely the controller is detecting some faulty sensor - and will need to find one by one. Are you ready for it?
Dec 17, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher& paykel F1 Fault code
F1 means u have a leak on the machine somewhere. they leak from , lid, drain hose , lid activatiors, the leak has flood sensor to come on. to stop the F1 code u have to repair leak. please reply 4 more help.
Apr 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F4 fault on fisher paykal dish drawer
F4 fault would inidicate the temperature sensor that senses the water temperature is faulty or the heating element is not working.
Looks like you will need a technician to visit and have a look.
Dec 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do i fix f1 fault code on fisher&paykel dd603 dish washer
Ah the F1 question... unplug the machine, you cannot clear this fault by pressing any buttons. What has happened is the flood switch had been activated, meaning there is water in the lower pan, under the lower drawer. You can try letting it dry-out for awhile but the cause of the flooding can be many things including bad lid lifts, a broken link support, a cracked drain line, too large of plates or someone put Dawn in it. Most likely your link support has broken and caused a dent in the lid which seals the drawer during washing. You need to have a Tech out to look at it; call F/P for someone authorized to fix it.
Jun 07, 2009 | Fisher DEIX2 Dryer
How to delete User fault codes
yes what is your email so i can send you the tep by step
Aug 02, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Water not draining from drawer
Could be the little non return valve mounted underneath the top drawer. Lie down on the floor under the top drawer, remove the main plastic pannel covering the bottom to expose the black drainage hose (you may need to cut away a cable tie). Remove the drainage hose from bottom of the drawer - at the start of the drainage hose there will be a small rubber type flap - if it looks broken or worn out, it will need replacing - call F & P for a replacement, approx $5 + postage for a pair (one for the top drawer and one for the bottom)
Hope this helps
Nov 03, 2007 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
570 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
