Question about Sceptre 17" LCD Monitor
Order of the connectors on the X7G-NAGAVI?
Anyone tell me the order of the connectors on the side of the board for the X7G-NAGAVI? Had to move while it was apart and now I dont rememter the order for the 4 connectors on the side. (pink/white wires)(blue/black wires).
  • 11,361 Answers
OK, you will have four connectors (each one with pink and white wires), there are two set of the connectors, two are above the transformer, two below the transformer. The monitor uses four lamps, two for the top side of the screen, two for the bottom side of h screen. You can plug either one of the pair of the connector to the top group of the connector, same for the bottom group of the connectors.
http://s807.photobucket.com/albums/yy352/budm/Sceptre%20X7G/
Posted on May 05, 2010
Kenwood Electric Oil Heater. Model EW7507EK. Can anyone tell me what color order of wires onto the circuit board? I feel like an silly for not taking a photo before starting the repair. F3-5
Look carefully on the board itself. Sometimes the wire color codes are labeled right next to the connector. If not, there may be some other letter codes and these should match the ones on the thermostat.
Dec 22, 2016 | Kenwood EW7507EK Oil Radiator
Hi. Can anyone tell me how you take the top off a Hotpoint CDT40G dryer?
there is two screws at the back top each side remove them then lft slightly and with the heel of your hand hit it forward you will find it will move forward and lift off.
Sep 17, 2014 | Hotpoint Dryers
Jvm1650bh05 control panel
"F3" means you have a shorting membrane keypad.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
It is part number WB07X10961 and you can get order it from the Pros here for $106.61 (subject to change).
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven at the link above.
Here is a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame. Be careful - the display is glass.
Some connectors on the relays have a lock:
Jun 09, 2013 | Microwave Ovens
X7G shows video for 1 second then goes black, any replacement boards available?
Hate to tell you that replacing parts on a monitor would be very hard not only to find the parts but it would be very costly, I would recommend scrapping it and buy a 90$ refab off tiger direct or something, the only thing you can really fix on a monitor is perhaps a dead pixel, other than that its not worth it.
Mar 21, 2010 | Sceptre X7G-Naga 17" LCD Monitor
I need to locate the 4 wheel drive control module on a 2002 Chevy Silverado. can you tell me where to look
  1. Remove the IP trim bezel.
  2. Pull out the lamp switch, 4WD shift buttons, cargo lamp and air deflector louver assembly in order to disconnect the electrical connectors.
  3. Disconnect all the electrical connectors from the lamp switch, cargo lamp and 4WD shift buttons assembly.
  4. Remove the lamp switch, 4WD shift buttons, cargo lamp and air deflector louver assembly from the vehicle
  5. Remove the electrical harness retainer from the IP support beam.
  6. Disconnect the 2 electrical connectors from the transfer case shift control module.
  7. Move the electrical harness to the left side in order to make room to turn the transfer case shift control module.
  8. Rotate the transfer case shift control module about 45 degrees counter clockwise while pulling out at the same time until the module is approximately 90 degrees from the original position.
  9. Pull out the module from the vehicle
Jan 02, 2009 | 2002 Chevrolet Silverado
Remote control cable
Within the same manual, you'll find a section that may say: Additional Accessories.
The cable should be listed as an accessory item to order.
Contact Kenwood and ask them how to order the cable.
Oct 22, 2008 | Radio Communications
Sceptre monitor x7g-nagaVI
Problem is 2 Capacitors on the power inverter board, at 1000 uf 16 volt. This one was on the model xg7-naga V 17 inch monitor.
Jan 14, 2008 | Sceptre 17" LCD Monitor
Sceptre X7G nagaVI problem
For most of the problems above you will find it is bad capacitors on the power board sending unstable power accross to the controller board.
For the last posted problem (Comment by Guest, posted on Jan 02, 2008) you have a dodgy inverter circuit that needs to be repaired.
Both faults should be fairly cheap to have taken care of at your local TV repair shop. You may need to call a few in your area not just for a quote, but also to see if they are willing to work on an LCD monitor.
Hope that helps you all =)
Dec 21, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Sceptre 17" LCD Monitor Logo
88 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
